[petsc-users] Correct use of PCFactorSetMatOrderingType
Zhang, Hong
hzhang at mcs.anl.gov
Tue Nov 6 10:15:20 CST 2018
Edoardo:
Interesting. I thought it would not affect performance much. What happens if you use -sub_pc_type lu'?
Hong
Dear Hong and Matt,
thank you for your kind replay. I have just tested your suggestions and applied " -sub_pc_type ilu -sub_pc_factor_mat_ordering_type nd/rcm" and, in both cases, I have found a deterioration of performances with respect to doing nothing (thus just putting default PCBJACOBI). Is it normal? However, I guess this is very problem dependent.
Edoardo Alinovi, Ph.D.
DICCA, Scuola Politecnica
Universita' di Genova
1, via Montallegro
16145 Genova, Italy
email: edoardo.alinovi at dicca.unige.it<mailto:edoardo.alinovi at dicca.unige.it>
Tel: +39 010 353 2540
Il giorno mar 6 nov 2018 alle ore 16:04 Zhang, Hong <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> ha scritto:
Edoardo:
You can test runtime option '-sub_pc_factor_mat_ordering_type' and use '-log_view' to get performance on different orderings, e.g.,petsc/src/ksp/ksp/examples/tutorials/ex2.c:
mpiexec -n 2 ./ex2 -ksp_view -sub_pc_type ilu -sub_pc_factor_mat_ordering_type nd
I do not think the ordering inside block for ilu would affect performance much. Let us know what you will get.
Hong
Dear users,
I have a question about the correct use of the option "PCFactorSetMatOrderingType" in PETSc.
I am solving a problem with 2.5M of unknowns distributed along 16 processors and I am using the block jacobi preconditioner and MPIAIJ matrix format. I cannot figure out if the above option can be useful or not in decreasing the computational time. Any suggestion or tips?
Thank you very much for the kind help
1, via Montallegro
16145 Genova, Italy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181106/879df622/attachment-0001.html>
