[petsc-users] Correct use of PCFactorSetMatOrderingType
Edoardo alinovi edoardo.alinovi at gmail.com
Tue Nov 6 09:28:46 CST 2018
Dear Hong and Matt,
thank you for your kind replay. I have just tested your suggestions and
applied " -sub_pc_type ilu -sub_pc_factor_mat_ordering_type nd/rcm" and, in
both cases, I have found  a deterioration of performances with respect to
doing nothing (thus just putting default PCBJACOBI). Is it normal? However,
I guess this is very problem dependent.
Edoardo Alinovi, Ph.D.
DICCA, Scuola Politecnica
Universita' di Genova
1, via Montallegro
16145 Genova, Italy
email: edoardo.alinovi at dicca.unige.it
Tel: +39 010 353 2540
Il giorno mar 6 nov 2018 alle ore 16:04 Zhang, Hong <hzhang at mcs.anl.gov> ha
scritto:
> Edoardo:
> You can test runtime option '-sub_pc_factor_mat_ordering_type' and use
> '-log_view' to get performance on different orderings,
> e.g.,petsc/src/ksp/ksp/examples/tutorials/ex2.c:
> mpiexec -n 2 ./ex2 -ksp_view -sub_pc_type ilu
> I do not think the ordering inside block for ilu would affect performance
> much. Let us know what you will get.
> Hong
> Dear users,
>> I have a question about the correct use of the option
>> "PCFactorSetMatOrderingType" in PETSc.
>> I am solving a problem with 2.5M of unknowns distributed along 16
>> processors and  I am using the block jacobi preconditioner and MPIAIJ
>> matrix format. I cannot figure out if the above option can be useful or not
>> in decreasing the computational time. Any suggestion or tips?
>> Thank you very much for the kind help
>> 1, via Montallegro
>> 16145 Genova, Italy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181106/1afa75b8/attachment.html>
