[petsc-users] Problems about Assemble DMComposite Precondition Matrix
Mark Adams mfadams at lbl.gov
Mon Nov 5 09:22:29 CST 2018
DMComposite is not very mature, the last time I checked and I don't of
anyone having worked on it recently, and it is probably not what you want
anyway. FieldSplit is most likely what you want.
What are your equations and discretization? eg, Stokes with cell centered
pressure? There are probably examples that are close to what you want and
it would not be hard to move your code over.
On Mon, Nov 5, 2018 at 10:00 AM Yingjie Wu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear Petsc developer:
> Hi,
> I have recently studied the preconditioner of the program, and some
> problems have arisen. Please help me to solve them.
> At present, I have written a program to solve the system of non-linear
> equations. The Matrix Free method has been used to calculate results. But I
> want to add a preprocessing matrix to it.
> I used the DMComposite object, which stores two sub-DM objects and a
> single value (two physical field variables and one variable). I want to use
> MatGetLocalSubMatrix to assign each physical field sub precondition matrix.
> At the same time, because my DM object is two-dimensional, I use
> MatSetValuesStencil() to fill the sub matrix.
> At present, I just want to fill in a unit matrix (for global vectors) as
> the precondition matrix of Matrix Free Method (just to test whether it can
> be used, the unit matrix has no preprocessing effect). But the procedure
> was wrong.
>            yjwu at yjwu-XPS-8910:~/petsc-3.10.1/src/snes/examples/tutorials$
> mpiexec -n 1 ./ex216 -f wu-readtwogroups -snes_mf_operator -snes_view
> -snes_converged_reason -snes_monitor -ksp_converged_reason
> -ksp_monitor_true_residual
>   0 SNES Function norm 8.235090086536e-02
> iter = 0, SNES Function norm 0.0823509
> iter = 0, Keff ======= 1.
>   Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
>                  PCSETUP_FAILED due to FACTOR_NUMERIC_ZEROPIVOT
> Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
> SNES Object: 1 MPI processes
>   type: newtonls
>   maximum iterations=50, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=0
>   total number of function evaluations=1
>   norm schedule ALWAYS
>   SNESLineSearch Object: 1 MPI processes
>     type: bt
>       interpolation: cubic
>       alpha=1.000000e-04
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
>     maximum iterations=40
>   KSP Object: 1 MPI processes
>     type: gmres
>       restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>       happy breakdown tolerance 1e-30
>     maximum iterations=10000, initial guess is zero
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>     left preconditioning
>     using PRECONDITIONED norm type for convergence test
>   PC Object: 1 MPI processes
>     type: ilu
>       out-of-place factorization
>       0 levels of fill
>       tolerance for zero pivot 2.22045e-14
>       matrix ordering: natural
>       factor fill ratio given 1., needed 1.
>         Factored matrix follows:
>           Mat Object: 1 MPI processes
>             type: seqaij
>             rows=961, cols=961
>             package used to perform factorization: petsc
>             total: nonzeros=4625, allocated nonzeros=4625
>             total number of mallocs used during MatSetValues calls =0
>               not using I-node routines
>     linear system matrix followed by preconditioner matrix:
>       type: mffd
>       rows=961, cols=961
>         Matrix-free approximation:
>           err=1.49012e-08 (relative error in function evaluation)
>           The compute h routine has not yet been set
>       type: seqaij
>       rows=961, cols=961
> It seems that there are elements on the diagonal line that are not filled,
> but I don't understand what went wrong. Part of the code of my program is
> as follows. I added all the code to the appendix. I have tested that for
> the entire Jacobian matrix assignment unit matrix (no submatrix, direct
> operation of the global preprocessing matrix), the program can run
> normally. However, since the problems developed later may be more complex,
> involving multiple physical fields, it would be easier to implement
> submatrix.
> /* set DMComposite */
> ierr =
> DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,20,24,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,&user.da1);CHKERRQ(ierr);
>   ierr = DMSetFromOptions(user.da1);CHKERRQ(ierr);
>   ierr = DMSetUp(user.da1);CHKERRQ(ierr);
>   ierr = DMCompositeAddDM(user.packer,user.da1);CHKERRQ(ierr);
>   ierr =
> DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,20,24,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,&user.da2);CHKERRQ(ierr);
>   ierr = DMSetFromOptions(user.da2);CHKERRQ(ierr);
>   ierr = DMSetUp(user.da2);CHKERRQ(ierr);
>   ierr = DMCompositeAddDM(user.packer,user.da2);CHKERRQ(ierr);
>   ierr = DMRedundantCreate(PETSC_COMM_WORLD,0,1,&user.red1);CHKERRQ(ierr);
>   ierr = DMCompositeAddDM(user.packer,user.red1);CHKERRQ(ierr);
> /* in FormJacobian(SNES snes,Vec U,Mat J,Mat B,void *ctx)  */
> ierr =
> DMCompositeGetLocalVectors(user->packer,&vphi1,&vphi2,&vlambda);CHKERRQ(ierr);
>   ierr =
> DMCompositeScatter(user->packer,U,vphi1,vphi2,vlambda);CHKERRQ(ierr);
>   ierr = VecGetArray(vlambda,&lambda);CHKERRQ(ierr);
>   ierr = DMDAVecGetArray(user->da1,vphi1,&phi1);CHKERRQ(ierr);
>   ierr = DMDAVecGetArray(user->da2,vphi2,&phi2);CHKERRQ(ierr);
>   ierr = DMCompositeGetLocalISs(user->packer,&is);CHKERRQ(ierr);
>   ierr = MatGetLocalSubMatrix(B,is[0],is[0],&B11);CHKERRQ(ierr);
>   ierr = MatGetLocalSubMatrix(B,is[1],is[1],&B22);CHKERRQ(ierr);
>   for (j=ys; j<ys+ym; j++) {
>     for (i=xs; i<xs+xm; i++) {
>       row.j = j; row.i = i;
>       unit = 1.0;
>       ierr =
> MatSetValuesStencil(B11,1,&row,1,&row,&unit,INSERT_VALUES);CHKERRQ(ierr);
>       unit = 1.0;
>       ierr =
> MatSetValuesStencil(B22,1,&row,1,&row,&unit,INSERT_VALUES);CHKERRQ(ierr);
>   ierr = MatRestoreLocalSubMatrix(B,is[0],is[0],&B11);CHKERRQ(ierr);
>   ierr = MatRestoreLocalSubMatrix(B,is[1],is[1],&B22);CHKERRQ(ierr);
>   unit = 1.0;
>   row1  = 960;//last row global index
>   ierr = MatSetValues(B,1,&row1,1,&row1,&unit,INSERT_VALUES);CHKERRQ(ierr);
>   ierr = VecRestoreArray(vlambda,&lambda);CHKERRQ(ierr);
>   ierr = DMDAVecRestoreArray(user->da1,vphi1,&phi1);CHKERRQ(ierr);
>   ierr = DMDAVecRestoreArray(user->da2,vphi2,&phi2);CHKERRQ(ierr);
> Thanks,
> Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181105/935a5746/attachment.html>
