[petsc-users] Problems about Assemble DMComposite Precondition Matrix
Yingjie Wu yjwu16 at gmail.com
Mon Nov 5 08:59:31 CST 2018
Dear Petsc developer:
I have recently studied the preconditioner of the program, and some
problems have arisen. Please help me to solve them.
At present, I have written a program to solve the system of non-linear
equations. The Matrix Free method has been used to calculate results. But I
want to add a preprocessing matrix to it.
I used the DMComposite object, which stores two sub-DM objects and a single
value (two physical field variables and one variable). I want to use
MatGetLocalSubMatrix to assign each physical field sub precondition matrix.
At the same time, because my DM object is two-dimensional, I use
MatSetValuesStencil() to fill the sub matrix.
At present, I just want to fill in a unit matrix (for global vectors) as
the precondition matrix of Matrix Free Method (just to test whether it can
be used, the unit matrix has no preprocessing effect). But the procedure
was wrong.
           yjwu at yjwu-XPS-8910:~/petsc-3.10.1/src/snes/examples/tutorials$
mpiexec -n 1 ./ex216 -f wu-readtwogroups -snes_mf_operator -snes_view
-snes_converged_reason -snes_monitor -ksp_converged_reason
-ksp_monitor_true_residual
  0 SNES Function norm 8.235090086536e-02
iter = 0, SNES Function norm 0.0823509
iter = 0, Keff ======= 1.
  Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
                 PCSETUP_FAILED due to FACTOR_NUMERIC_ZEROPIVOT
Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
SNES Object: 1 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=0
  total number of function evaluations=1
  norm schedule ALWAYS
  SNESLineSearch Object: 1 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  KSP Object: 1 MPI processes
    type: gmres
      restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object: 1 MPI processes
    type: ilu
      out-of-place factorization
      0 levels of fill
      tolerance for zero pivot 2.22045e-14
      matrix ordering: natural
      factor fill ratio given 1., needed 1.
        Factored matrix follows:
          Mat Object: 1 MPI processes
            type: seqaij
            rows=961, cols=961
            package used to perform factorization: petsc
            total: nonzeros=4625, allocated nonzeros=4625
            total number of mallocs used during MatSetValues calls =0
              not using I-node routines
    linear system matrix followed by preconditioner matrix:
      type: mffd
      rows=961, cols=961
        Matrix-free approximation:
          err=1.49012e-08 (relative error in function evaluation)
          The compute h routine has not yet been set
      type: seqaij
      rows=961, cols=961
It seems that there are elements on the diagonal line that are not filled,
but I don't understand what went wrong. Part of the code of my program is
as follows. I added all the code to the appendix. I have tested that for
the entire Jacobian matrix assignment unit matrix (no submatrix, direct
operation of the global preprocessing matrix), the program can run
normally. However, since the problems developed later may be more complex,
involving multiple physical fields, it would be easier to implement
submatrix.
/* set DMComposite */
ierr =
DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,20,24,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,&user.da1);CHKERRQ(ierr);
  ierr = DMSetFromOptions(user.da1);CHKERRQ(ierr);
  ierr = DMSetUp(user.da1);CHKERRQ(ierr);
  ierr = DMCompositeAddDM(user.packer,user.da1);CHKERRQ(ierr);
  ierr =
DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,20,24,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,&user.da2);CHKERRQ(ierr);
  ierr = DMSetFromOptions(user.da2);CHKERRQ(ierr);
  ierr = DMSetUp(user.da2);CHKERRQ(ierr);
  ierr = DMCompositeAddDM(user.packer,user.da2);CHKERRQ(ierr);
  ierr = DMRedundantCreate(PETSC_COMM_WORLD,0,1,&user.red1);CHKERRQ(ierr);
  ierr = DMCompositeAddDM(user.packer,user.red1);CHKERRQ(ierr);
/* in FormJacobian(SNES snes,Vec U,Mat J,Mat B,void *ctx)  */
ierr =
DMCompositeGetLocalVectors(user->packer,&vphi1,&vphi2,&vlambda);CHKERRQ(ierr);
  ierr =
DMCompositeScatter(user->packer,U,vphi1,vphi2,vlambda);CHKERRQ(ierr);
  ierr = VecGetArray(vlambda,&lambda);CHKERRQ(ierr);
  ierr = DMDAVecGetArray(user->da1,vphi1,&phi1);CHKERRQ(ierr);
  ierr = DMDAVecGetArray(user->da2,vphi2,&phi2);CHKERRQ(ierr);
  ierr = DMCompositeGetLocalISs(user->packer,&is);CHKERRQ(ierr);
  ierr = MatGetLocalSubMatrix(B,is[0],is[0],&B11);CHKERRQ(ierr);
  ierr = MatGetLocalSubMatrix(B,is[1],is[1],&B22);CHKERRQ(ierr);
  for (j=ys; j<ys+ym; j++) {
    for (i=xs; i<xs+xm; i++) {
      row.j = j; row.i = i;
      unit = 1.0;
      ierr =
MatSetValuesStencil(B11,1,&row,1,&row,&unit,INSERT_VALUES);CHKERRQ(ierr);
      unit = 1.0;
      ierr =
MatSetValuesStencil(B22,1,&row,1,&row,&unit,INSERT_VALUES);CHKERRQ(ierr);
  ierr = MatRestoreLocalSubMatrix(B,is[0],is[0],&B11);CHKERRQ(ierr);
  ierr = MatRestoreLocalSubMatrix(B,is[1],is[1],&B22);CHKERRQ(ierr);
  unit = 1.0;
  row1  = 960;//last row global index
  ierr = MatSetValues(B,1,&row1,1,&row1,&unit,INSERT_VALUES);CHKERRQ(ierr);
  ierr = VecRestoreArray(vlambda,&lambda);CHKERRQ(ierr);
  ierr = DMDAVecRestoreArray(user->da1,vphi1,&phi1);CHKERRQ(ierr);
  ierr = DMDAVecRestoreArray(user->da2,vphi2,&phi2);CHKERRQ(ierr);
Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181105/59aceb11/attachment-0001.html>
static const char help[] = "Solves PDE optimization problem using full-space method, treats state and adjoint variables separately.\n\n";
/*T
   requires: !single
T*/
#include <petscdm.h>
#include <petscdmda.h>
#include <petscdmredundant.h>
#include <petscdmcomposite.h>
#include <petscpf.h>
#include <petscsnes.h>
       w - design variables (what we change to get an optimal solution)
       u - state variables (i.e. the PDE solution)
       lambda - the Lagrange multipliers
            U = (w u lambda)
       fu, fw, flambda contain the gradient of L(w,u,lambda)
            FU = (fw fu flambda)
       In this example the PDE is
                             Uxx = 2
                            u(0) = w(0), thus this is the free parameter
                            u(1) = 0
       the function we wish to minimize is
                            \integral u^{2}
       The exact solution for u is given by u(x) = x*x - 1.25*x + .25
       Use the usual centered finite differences.
       Note we treat the problem as non-linear though it happens to be linear
       See ex22.c for the same code, but that interlaces the u and the lambda
typedef struct {
  DM          red1,da1,da2;
  DM          packer;
} UserCtx;
extern PetscErrorCode FormInitialGuess(UserCtx*,Vec,Mat,Mat);
extern PetscErrorCode FormFunction(SNES,Vec,Vec,void*);
extern PetscErrorCode FormJacobian(SNES,Vec,Mat,Mat,void*);
extern PetscErrorCode Monitor(SNES,PetscInt,PetscReal,void*);
int main(int argc,char **argv)
  PetscErrorCode ierr;
  PetscInt       its;
  Vec            U,FU,vlambda,vphi1,vphi2;
  Mat            A1,A2;/*Matrix for storage initial guess*/
  Mat            B;
  SNES           snes;
  UserCtx        user;
  PetscViewer    viewer;
  char           file[PETSC_MAX_PATH_LEN];/* input file name */
  PetscBool      flg;
  ierr = PetscInitialize(&argc,&argv,(char*)0,help);if (ierr) return ierr;
  /*Read the file and store them in the matrix*/
  ierr = PetscOptionsGetString(NULL,NULL,"-f",file,PETSC_MAX_PATH_LEN,&flg);CHKERRQ(ierr);
  if (!flg)
    SETERRQ(PETSC_COMM_WORLD,1,"Must indicate binary file with the -f option");
  ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&viewer);CHKERRQ(ierr);
  ierr = MatCreate(PETSC_COMM_WORLD,&A1);CHKERRQ(ierr);
  ierr = MatSetFromOptions(A1);CHKERRQ(ierr);
  ierr = MatCreate(PETSC_COMM_WORLD,&A2);CHKERRQ(ierr);
  ierr = MatSetFromOptions(A2);CHKERRQ(ierr);
  ierr = MatLoad(A1,viewer);CHKERRQ(ierr);
  ierr = MatLoad(A2,viewer);CHKERRQ(ierr);
  ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
  /* Create a global vector that includes a single redundant array and two da arrays */
  ierr = DMCompositeCreate(PETSC_COMM_WORLD,&user.packer);CHKERRQ(ierr);
/*  Set neutron flux DM   */
  ierr = DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,20,24,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,&user.da1);CHKERRQ(ierr);
  ierr = DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,20,24,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,&user.da2);CHKERRQ(ierr);
  ierr = DMDASetFieldName(user.da1,0,"phi1");CHKERRQ(ierr);
  ierr = DMDASetFieldName(user.da2,0,"phi2");CHKERRQ(ierr);
  //ierr = DMDASetFieldName(user.red1,0,"lambda");CHKERRQ(ierr);
  ierr = DMCreateGlobalVector(user.packer,&U);CHKERRQ(ierr);
  ierr = VecDuplicate(U,&FU);CHKERRQ(ierr);
  /* Form initial Guess lambda, phi1, phi2 */
  ierr = FormInitialGuess(&user,U,A1,A2);CHKERRQ(ierr);
  /* create nonlinear solver */
  ierr = SNESCreate(PETSC_COMM_WORLD,&snes);CHKERRQ(ierr);
  ierr = DMCreateMatrix(user.packer,&B);CHKERRQ(ierr);
  /* This example does not correctly allocate off-diagonal blocks. These options allows new nonzeros (slow). */
  ierr = MatSetOption(B,MAT_NEW_NONZERO_LOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
  ierr = MatSetOption(B,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
  ierr = SNESSetFunction(snes,FU,FormFunction,&user);CHKERRQ(ierr);
  ierr = SNESSetJacobian(snes,NULL,B,FormJacobian,&user);CHKERRQ(ierr);
  ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
  ierr = SNESMonitorSet(snes,Monitor,&user,0);CHKERRQ(ierr);
  ierr = SNESSetDM(snes,user.packer);CHKERRQ(ierr);
  ierr = SNESSolve(snes,NULL,U);CHKERRQ(ierr);
  ierr = SNESGetIterationNumber(snes,&its);CHKERRQ(ierr);
  /* Output the data */
  ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"wu_testtwogroups",FILE_MODE_WRITE,&viewer);CHKERRQ(ierr);
  ierr = PetscViewerPushFormat(viewer,PETSC_VIEWER_BINARY_MATLAB);CHKERRQ(ierr);
  ierr = DMCompositeGetLocalVectors(user.packer,&vlambda,&vphi1,&vphi2);CHKERRQ(ierr);
  ierr = DMCompositeScatter(user.packer,U,vlambda,vphi1,vphi2);CHKERRQ(ierr);
  ierr = VecView(vlambda,viewer);CHKERRQ(ierr);
  ierr = VecView(vphi1,viewer);CHKERRQ(ierr);
  ierr = VecView(vphi2,viewer);CHKERRQ(ierr);
  ierr = SNESDestroy(&snes);CHKERRQ(ierr);
  ierr = DMDestroy(&user.red1);CHKERRQ(ierr);
  ierr = DMDestroy(&user.da1);CHKERRQ(ierr);
  ierr = DMDestroy(&user.da2);CHKERRQ(ierr);
  ierr = DMDestroy(&user.packer);CHKERRQ(ierr);
  ierr = VecDestroy(&U);CHKERRQ(ierr);
  ierr = VecDestroy(&FU);CHKERRQ(ierr);
  ierr = VecDestroy(&vlambda);CHKERRQ(ierr);
  ierr = VecDestroy(&vphi1);CHKERRQ(ierr);
  ierr = VecDestroy(&vphi2);CHKERRQ(ierr);
  ierr = PetscFinalize();
  return ierr;
PetscErrorCode FormInitialGuess(UserCtx *user,Vec U,Mat A1,Mat A2)
  PetscInt       xs,xm,i,N;
  PetscInt       ys,ym,j,M;/*y direction index*/
  PetscInt       id;
  PetscScalar    *lambda,**phi1,**phi2;
  PetscScalar    *initial_phi1,*initial_phi2;
  Vec            vlambda,vphi1,vphi2;
  PetscFunctionBeginUser;
  ierr = MatSeqAIJGetArray(A1,&initial_phi1);CHKERRQ(ierr);
  ierr = MatSeqAIJGetArray(A2,&initial_phi2);CHKERRQ(ierr);
  ierr = DMCompositeGetLocalVectors(user->packer,&vphi1,&vphi2,&vlambda);CHKERRQ(ierr);
  ierr = DMCompositeScatter(user->packer,U,vphi1,vphi2,vlambda);CHKERRQ(ierr);
  ierr = DMDAGetCorners(user->da1,&xs,&ys,NULL,&xm,&ym,NULL);CHKERRQ(ierr);//get two direction index
  ierr = DMDAGetInfo(user->da1,0,&N,&M,0,0,0,0,0,0,0,0,0,0);CHKERRQ(ierr);
  if (xs == 0 && ys == 0) lambda[0] = 1.0;
  for ( j=ys ; j < ys+ym ; j++ ){
       for ( i=xs ; i < xs+xm ; i++ ){
          id = j*xm + i ;
          phi1[j][i] = initial_phi1[id] ;
          phi2[j][i] = initial_phi2[id] ;
  ierr = DMCompositeGather(user->packer,INSERT_VALUES,U,vphi1,vphi2,vlambda);CHKERRQ(ierr);
  ierr = DMCompositeRestoreLocalVectors(user->packer,&vphi1,&vphi2,&vlambda);CHKERRQ(ierr);
  PetscFunctionReturn(0);
      Evaluates FU = Gradiant(L(w,u,lambda))
PetscErrorCode FormFunction(SNES snes,Vec U,Vec FU,void *dummy)
  UserCtx        *user = (UserCtx*)dummy;
  PetscInt       xs,xm,i,N;
  PetscInt       xints,xinte,yints,yinte;
  PetscScalar    *lambda,**phi1,**phi2,*flambda,**fphi1,**fphi2;
  PetscScalar    dx,dy;
  PetscScalar    dotphi;//wu-define
  PetscScalar    rightside,e,b,c,dd,a;
  PetscReal      phi1boundary,phi2boundary;
  Vec            vlambda,vphi1,vphi2,vflambda,vfphi1,vfphi2;
  ierr = DMCompositeGetLocalVectors(user->packer,&vfphi1,&vfphi2,&vflambda);CHKERRQ(ierr);
  ierr = VecGetArray(vflambda,&flambda);CHKERRQ(ierr);
  ierr = DMDAVecGetArray(user->da1,vfphi1,&fphi1);CHKERRQ(ierr);
  ierr = DMDAVecGetArray(user->da2,vfphi2,&fphi2);CHKERRQ(ierr);
  dx    = 5.0;
  dy    = 5.0;
  phi1boundary = 0.0;
  phi2boundary = 0.0;
  /* residual f_lambda */
  if (xs == 0 && ys == 0 ) { /* only first processor computes this */
    dotphi = 0.0;
          dotphi += phi1[j][i]*phi1[j][i] + phi2[j][i]*phi2[j][i] ;
    flambda[0] =  dotphi - 1.0 ;
  /* bottom boundary */
  if (ys == 0) {
    j     = 0;
    yints = ys + 1;
    /* bottom edge */
      /*phi1 field*/
      rightside = phi1boundary;
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
      fphi1[j][i] = a * phi1[j][i] - rightside;
      /*phi2 field*/
      rightside = phi2boundary;
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
      fphi2[j][i] = a * phi2[j][i] - rightside;
  /* top boundary */
  if (yints == 1) {
    j     = ys + ym - 1;
    yinte = ys + ym - 1;
      /*phi1 field*/
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
      /*phi2 field*/
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
  /* left boundary */
  if (xs == 0) {
    i     = 0;
    xints = xs + 1;
    /* bottom edge */
    for (j=yints; j<yinte; j++) {
      /*phi1 field*/
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
      /*phi2 field*/
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
  /* right boundary */
  if (xints == 1) {
    i     = xs + xm - 1;
    xinte = xs + xm - 1;
      /*phi1 field*/
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
      /*phi2 field*/
      b         = 0.0;
      c         = 0.0;
      dd         = 0.0;
      e         = 0.0;
      a         = 1.0;
  /* inner points */
  for (j=yints; j<yinte; j++){
    for (i=xints; i<xinte; i++){
      /*phi1 field*/
      rightside = - (0.0121 + 0.0241) * phi1[j][i] + lambda[0] * 0.0085 * phi1[j][i] + lambda[0] * 0.1851 * phi2[j][i] ;
      b = 1.0 / ( dx * dx / (2* 1.267) + dx * dx / (2* 1.267 ) ) ;
      c = 1.0 / ( dx * dx / (2* 1.267) + dx * dx / (2* 1.267 ) ) ;
      dd = 1.0/ ( dy * dy / (2* 1.267) + dy * dy / (2* 1.267 ) ) ;
      e = 1.0 / ( dy * dy / (2* 1.267) + dy * dy / (2* 1.267 ) ) ;
      a = b + c + dd + e ;
      fphi1[j][i] = a* phi1[j][i] - b* phi1[j][i-1] - c* phi1[j][i+1] - dd* phi1[j-1][i] - e* phi1[j+1][i] - rightside ;
      /*phi2 field*/
      rightside = - 0.121 * phi2[j][i] + 0.0241 * phi1[j][i] ;
      b = 1.0 / ( dx * dx / (2* 0.354) + dx * dx / (2* 0.354 ) ) ;
      c = 1.0 / ( dx * dx / (2* 0.354) + dx * dx / (2* 0.354 ) ) ;
      dd = 1.0/ ( dy * dy / (2* 0.354) + dy * dy / (2* 0.354 ) ) ;
      e = 1.0 / ( dy * dy / (2* 0.354) + dy * dy / (2* 0.354 ) ) ;
      fphi2[j][i] = a* phi2[j][i] - b* phi2[j][i-1] - c* phi2[j][i+1] - dd* phi2[j-1][i] - e* phi2[j+1][i] - rightside ;
  ierr = VecRestoreArray(vflambda,&flambda);CHKERRQ(ierr);
  ierr = DMDAVecRestoreArray(user->da1,vfphi1,&fphi1);CHKERRQ(ierr);
  ierr = DMDAVecRestoreArray(user->da2,vfphi2,&fphi2);CHKERRQ(ierr);
  ierr = DMCompositeGather(user->packer,INSERT_VALUES,FU,vfphi1,vfphi2,vflambda);CHKERRQ(ierr);
  ierr = DMCompositeRestoreLocalVectors(user->packer,&vfphi1,&vfphi2,&vflambda);CHKERRQ(ierr);
PetscErrorCode FormJacobian(SNES snes,Vec U,Mat J,Mat B,void *ctx)
  UserCtx        *user = (UserCtx*)ctx;
  PetscInt       xs,xm,i,N;
  PetscInt       ys,ym,j,M;
  PetscInt       row1,col1;
  MatStencil     col[5],row;
  Mat            Bll,B11,B22,B12,B21;
  IS             *is;
  PetscScalar    unit;
  // unit = 1.0;
  // row1  = 0;
  // for (int i = 0; i < 961; i++)
  //   ierr = MatSetValues(B,1,&row1,1,&row1,&unit,INSERT_VALUES);CHKERRQ(ierr);
  //   row1++;
  // ierr = MatGetLocalSubMatrix(B,is[2],is[2],&Bll);CHKERRQ(ierr);
      unit = 1.0;
      ierr = MatSetValuesStencil(B11,1,&row,1,&row,&unit,INSERT_VALUES);CHKERRQ(ierr);
      unit = 1.0;
      ierr = MatSetValuesStencil(B22,1,&row,1,&row,&unit,INSERT_VALUES);CHKERRQ(ierr);
  unit = 1.0;
  ierr = ISDestroy(&is[0]);CHKERRQ(ierr);
  ierr = ISDestroy(&is[1]);CHKERRQ(ierr);
  ierr = ISDestroy(&is[2]);CHKERRQ(ierr);
  ierr = PetscFree(is);CHKERRQ(ierr);
  ierr = DMCompositeRestoreLocalVectors(user->packer,&vlambda,&vphi1,&vphi2);CHKERRQ(ierr);
  ierr = MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  ierr = MatAssemblyEnd  (B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  if (J != B) {
    ierr = MatAssemblyBegin(J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
    ierr = MatAssemblyEnd  (J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
PetscErrorCode Monitor(SNES snes,PetscInt its,PetscReal fnorm,void *dummy)
  Vec            vlambda,vphi1,vphi2,U;
  PetscReal      *lambda;
  PetscReal      keff;
  ierr = PetscPrintf(PETSC_COMM_WORLD,"iter = %D, SNES Function norm %g\n",its,(double)fnorm);CHKERRQ(ierr);
  ierr = SNESGetSolution(snes,&U);CHKERRQ(ierr);
  keff = 1.0 / lambda[0] ;
  ierr = PetscPrintf(PETSC_COMM_WORLD,"iter = %D, Keff ======= %g\n",its,(double)keff);CHKERRQ(ierr);
  //ierr = VecView(vphi1,PETSC_VIEWER_DRAW_WORLD);CHKERRQ(ierr);
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181105/59aceb11/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181105/59aceb11/attachment-0003.obj>
