[petsc-users] Matrix-free preconditioner using shell matrix
Praveen C
cpraveen at gmail.com
Wed May 23 00:24:14 CDT 2018
Thanks a lot Barry. I sorted out the user context problem with your help. But I have to fix some other issues to make it work.
Best
praveen
> On 19-May-2018, at 10:31 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> On May 19, 2018, at 11:42 AM, Praveen C <cpraveen at gmail.com> wrote:
>> Thanks a lot.
>>> On 19-May-2018, at 9:16 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>> Praveen,
>>> Ahh, we didn't have support for passing PETSC_NULL_MAT from Fortran for this routine. I have added it in the branch barry/fix-null-matrix-set-jacobian/maint which after testing will go into the maint branch.
>>> Could you please try this branch and let us know if it resolves the problem (or a new problem pops up)?
>>> Barry
>>> Unfortunately handling null objects from Fortran requires us to manually tweak the Fortran interface functions and sometimes we forget or don't realize they need fixing until someone reports a problem.
>> I meanwhile passed a Mat object to TSSetRHSJacobian function. It seems that with -snes_mf and PCSHELL, my RHSJacobian is never invoked. Is this the correct behaviour ?
> Yes, if you want your function to be called you need to use -snes_mf_operator instead.
>> In RHSJacobian, I am storing the current solution into my usercontext so that I can use it in my shell preconditioner
>> subroutine RHSJacobian(ts, time, u, J, P, ctx, ierr)
>> call VecCopy(u, ctx%p%v_u, ierr); CHKERRQ(ierr)
>> end
>> However, since my RHSJacobian is never invoked, I dont have access to the current solution needed in my ApplyPC. How can I access the current solution in my ApplyPC function ?
>> Another issue I am facing is this. I attach my user context to the PC
>> call TSGetSNES(ts, snes, ierr); CHKERRQ(ierr)
>> call SNESGetKSP(snes, ksp, ierr); CHKERRQ(ierr)
>> call KSPGetPC(ksp, pc, ierr); CHKERRQ(ierr)
>> call PCSetType(pc, PCSHELL, ierr); CHKERRQ(ierr)
>> call PCShellSetContext(pc, ctx, ierr); CHKERRQ(ierr)
>> call PCShellSetApply(pc, ApplyPC, ierr); CHKERRQ(ierr)
>> Inside my ApplyPC, I access ctx using
>> subroutine ApplyPC(pc, x, y, ierr)
>> use petscpc
>> use mtsdata
>> implicit none
>> PC :: pc
>> Vec :: x, y
>> PetscErrorCode :: ierr
>> ! Local variables
>> type(tsdata) :: ctx
>> call PCShellGetContext(pc, ctx, ierr); CHKERRQ(ierr)
>> end
>> But the ctx I get from above is not correct, since it does not have the data I stored in my original ctx.
> This won't work. You need to use a pointer for the context not an entirely new context argument. See
> src/mat/examples/tutorials/ex6f.F90
> for how to use derived data types and pointers with contexts in Fortran.
> Barry
>> I am rather clueless at this stage.
>> Thanks for your help.
>> Best regards
>> praveen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180523/65b33b3c/attachment.html>
