[petsc-users] Matrix-free preconditioner using shell matrix
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sat May 19 12:01:15 CDT 2018
> On May 19, 2018, at 11:42 AM, Praveen C <cpraveen at gmail.com> wrote:
> Thanks a lot.
>> On 19-May-2018, at 9:16 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>   Praveen,
>>   Ahh, we didn't have support for passing PETSC_NULL_MAT from Fortran for this routine. I have added it in the branch barry/fix-null-matrix-set-jacobian/maint  which after testing will go into the maint branch.
>>   Could you please try this branch and let us know if it resolves the problem (or a new problem pops up)?
>>    Barry
>>   Unfortunately handling null objects from Fortran requires us to manually tweak the Fortran interface functions and sometimes we forget or don't realize they need fixing until someone reports a problem.
> I meanwhile passed a Mat object to TSSetRHSJacobian function. It seems that with -snes_mf and PCSHELL, my RHSJacobian is never invoked. Is this the correct behaviour ?
   Yes, if you want your function to be called you need to use -snes_mf_operator instead.
> In RHSJacobian, I am storing the current solution into my usercontext so that I can use it in my shell preconditioner
> subroutine RHSJacobian(ts, time, u, J, P, ctx, ierr)
>    call VecCopy(u, ctx%p%v_u, ierr); CHKERRQ(ierr)
> end
> However, since my RHSJacobian is never invoked, I dont have access to the current solution needed in my ApplyPC. How can I access the current solution in my ApplyPC function ?
> Another issue I am facing is this. I attach my user context to the PC
>       call TSGetSNES(ts, snes, ierr); CHKERRQ(ierr)
>       call SNESGetKSP(snes, ksp, ierr); CHKERRQ(ierr)
>       call KSPGetPC(ksp, pc, ierr); CHKERRQ(ierr)
>       call PCSetType(pc, PCSHELL, ierr); CHKERRQ(ierr)
>       call PCShellSetContext(pc, ctx, ierr); CHKERRQ(ierr)
>       call PCShellSetApply(pc, ApplyPC, ierr); CHKERRQ(ierr)
> Inside my ApplyPC, I access ctx using
> subroutine ApplyPC(pc, x, y, ierr)
>    use petscpc
>    use mtsdata
>    implicit none
>    PC             :: pc
>    Vec            :: x, y
>    PetscErrorCode :: ierr
>    ! Local variables
>    type(tsdata)   :: ctx
>    call PCShellGetContext(pc, ctx, ierr); CHKERRQ(ierr)
> end
> But the ctx I get from above is not correct, since it does not have the data I stored in my original ctx.
    This won't work. You need to use a pointer for the context not an entirely new context argument. See
src/mat/examples/tutorials/ex6f.F90
for how to use derived data types and pointers with contexts in Fortran.
  Barry
> I am rather clueless at this stage.
> Thanks for your help.
> Best regards
> praveen
