[petsc-users] Placing FindPETSc.cmake
Jed Brown jed at jedbrown.org
Fri May 11 17:10:53 CDT 2018
Evan Um <evanum at gmail.com> writes:
> Matt and Jed,
> Thanks for your comments.
> I still have a trouble in using FindPETSc.cmake. I removed the directory:
> (i.e. canceling cp - r /home/evan/petsc//lib/petsc/
> conf/rules /home/evan/petsc//lib/petsc/conf/petscrules) and explicitly set
> SET (PETSC_ARCH "arch-linux2-c-debug all").
No " all".
> Now, FindPETSc.cmake does not recognize PETSC_DIR and PETSC_ARCH. When I
> read the comments inside FindPETSc.cmake, the twos should be refined by
> FindPETSc.cmake. BTW, I have my petsc at /home/evan/petsc. So all are
> defaults.
> Thanks for your kind help.
> Evan
> cmake_minimum_required(VERSION 3.10)
> project(hellopetsc)
> list (APPEND CMAKE_MODULE_PATH /home/evan/CLionProjects/hellopetsc)
> SET(CMAKE_CXX_STANDARD 11)
> SET(CMAKE_C_COMPILER mpicc)
> SET(CMAKE_CXX_COMPILER mpicxx)
> find_package(PETSc COMPONENTS CXX)
> add_executable(hellopetsc main.cpp)
> /home/evan/opt/clion-2018.1.2/bin/cmake/bin/cmake -DCMAKE_BUILD_TYPE=Debug
> -G "CodeBlocks - Unix Makefiles" /home/evan/CLionProjects/hellopetsc
> CMake Error at FindPETSc.cmake:140 (message):
>   The pair PETSC_DIR=/home/evan/petsc PETSC_ARCH=arch-linux2-c-debug all do
>   not specify a valid PETSc installation
> Call Stack (most recent call first):
>   CMakeLists.txt:12 (find_package)
> -- PETSc could not be found.  Be sure to set PETSC_DIR and PETSC_ARCH.
> (missing: PETSC_INCLUDES PETSC_LIBRARIES PETSC_EXECUTABLE_RUNS) (found
> version "3.9.1")
> -- Configuring incomplete, errors occurred!
> See also
> "/home/evan/CLionProjects/hellopetsc/cmake-build-debug/CMakeFiles/CMakeOutput.log".
> See also
> "/home/evan/CLionProjects/hellopetsc/cmake-build-debug/CMakeFiles/CMakeError.log".
> [Finished]
> On Fri, May 11, 2018 at 2:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, May 11, 2018 at 5:06 PM, Evan Um <evanum at gmail.com> wrote:
>>> Hi Jed,
>>> Thanks for the comment. I added the module but still saw errors (before I
>>> arrived here, I had to do cp - r /home/evan/petsc//lib/petsc/
>>> conf/rules /home/evan/petsc//lib/petsc/conf/petscrules).
>> That is wrong. It means PETSC_ARCH is (null) instead of the correct string.
>>    Matt
>>> They are supposed to be defined by FindPETSc.cmake. How could I solve
>>> these errors?
>>> Could you also explain a little bit about how to use pkg-config to find
>>> PETSc? Thanks!
>>> Evan
>>> project(hellopetsc)
>>> -DCMAKE_BUILD_TYPE=Debug -G "CodeBlocks - Unix Makefiles"
>>> version "3.9.1")
>>> -- Configuring done
>>> -- Generating done
>>> -- Build files have been written to: /home/evan/CLionProjects/hello
>>> [Finished]
>>> On Fri, May 11, 2018 at 12:08 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> Yes, it depends on this module from the same repository.
>>>> Note that you can use pkg-config to find PETSc these days.
>>>> > Hi Stefano,
>>>> > Thanks for your comment. Now, cmake was able to locate FindPETSc.cmake
>>>> file
>>>> > in my project directory, but I see a new error.
>>>> > Evan
>>>> > Messages
>>>> > CMake Error at FindPETSc.cmake:123 (include):
>>>> >   include could not find load file:
>>>> >     FindPackageMultipass
>>>> >   CMakeLists.txt:10 (find_package)
>>>> > CMake Error at FindPETSc.cmake:124 (find_package_multipass):
>>>> >   Unknown CMake command "find_package_multipass".
>>>> > See also
>>>> > See also
>>>> > CMakeLists.txt
>>>> > See also
>>>> > See also
>>>> > [Finished]
>>>> > On Fri, May 11, 2018 at 11:34 AM, Stefano Zampini <
>>>> stefano.zampini at gmail.com
>>>> >> wrote:
>>>> >> CMAKE is case sensitive on this. You should use find_package(PETSc ….)
>>>> >> > On May 11, 2018, at 9:28 PM, Evan Um <evanum at gmail.com> wrote:
>>>> >> > Hi,
>>>> >> > I would like to ask a question about FindPETSc.cmake. I place the
>>>> cmake
>>>> >> file in the same directory where main.cpp is placed. I also placed
>>>> the file
>>>> >> in /usr/share/cmake_xx/Modules.
>>>> >> Actually, it can be put in any directory pointed by the variable
>>>> >> CMAKE_MODULE_PATH. If I were you, I would not modify /usr/share/
>>>> >> > Where should i put the file? What else should I do to use the file
>>>> in
>>>> >> cmake? Do I need any other lines in my cmakelists.txt except
>>>> >> find_package(petsc)? Thanks for your comments.
>>>> >> > Evan
>>>> >> > project(hellopetsc)
>>>> >> > find_package(PETSC COMPONENTS CXX)
>>>> >> > CMake Warning at CMakeLists.txt:9 (find_package):
>>>> >> >   By not providing "FindPETSC.cmake" in CMAKE_MODULE_PATH this
>>>> project
>>>> >> has
>>>> >> >   asked CMake to find a package configuration file provided by
>>>> "PETSC",
>>>> >> but
>>>> >> >   CMake did not find one.
>>>> >> >   Could not find a package configuration file provided by "PETSC"
>>>> with
>>>> >> any of
>>>> >> >   the following names:
>>>> >> >     PETSCConfig.cmake
>>>> >> >     petsc-config.cmake
>>>> >> >   Add the installation prefix of "PETSC" to CMAKE_PREFIX_PATH or set
>>>> >> >   "PETSC_DIR" to a directory containing one of the above files.  If
>>>> >> "PETSC"
>>>> >> >   provides a separate development package or SDK, be sure it has
>>>> been
>>>> >> >   installed.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
