[petsc-users] Placing FindPETSc.cmake
Evan Um evanum at gmail.com
Fri May 11 17:04:47 CDT 2018
Matt and Jed,
Thanks for your comments.
I still have a trouble in using FindPETSc.cmake. I removed the directory:
(i.e. canceling cp - r /home/evan/petsc//lib/petsc/
conf/rules /home/evan/petsc//lib/petsc/conf/petscrules) and explicitly set
SET (PETSC_ARCH "arch-linux2-c-debug all").
Now, FindPETSc.cmake does not recognize PETSC_DIR and PETSC_ARCH. When I
read the comments inside FindPETSc.cmake, the twos should be refined by
FindPETSc.cmake. BTW, I have my petsc at /home/evan/petsc. So all are
defaults.
Thanks for your kind help.
Evan
cmake_minimum_required(VERSION 3.10)
project(hellopetsc)
list (APPEND CMAKE_MODULE_PATH /home/evan/CLionProjects/hellopetsc)
SET(CMAKE_CXX_STANDARD 11)
SET(CMAKE_C_COMPILER mpicc)
SET(CMAKE_CXX_COMPILER mpicxx)
find_package(PETSc COMPONENTS CXX)
add_executable(hellopetsc main.cpp)
/home/evan/opt/clion-2018.1.2/bin/cmake/bin/cmake -DCMAKE_BUILD_TYPE=Debug
-G "CodeBlocks - Unix Makefiles" /home/evan/CLionProjects/hellopetsc
CMake Error at FindPETSc.cmake:140 (message):
  The pair PETSC_DIR=/home/evan/petsc PETSC_ARCH=arch-linux2-c-debug all do
  not specify a valid PETSc installation
Call Stack (most recent call first):
  CMakeLists.txt:12 (find_package)
-- PETSc could not be found.  Be sure to set PETSC_DIR and PETSC_ARCH.
(missing: PETSC_INCLUDES PETSC_LIBRARIES PETSC_EXECUTABLE_RUNS) (found
version "3.9.1")
-- Configuring incomplete, errors occurred!
See also
"/home/evan/CLionProjects/hellopetsc/cmake-build-debug/CMakeFiles/CMakeOutput.log".
See also
"/home/evan/CLionProjects/hellopetsc/cmake-build-debug/CMakeFiles/CMakeError.log".
[Finished]
On Fri, May 11, 2018 at 2:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, May 11, 2018 at 5:06 PM, Evan Um <evanum at gmail.com> wrote:
>> Hi Jed,
>> Thanks for the comment. I added the module but still saw errors (before I
>> arrived here, I had to do cp - r /home/evan/petsc//lib/petsc/
>> conf/rules /home/evan/petsc//lib/petsc/conf/petscrules).
> That is wrong. It means PETSC_ARCH is (null) instead of the correct string.
>    Matt
>> They are supposed to be defined by FindPETSc.cmake. How could I solve
>> these errors?
>> Could you also explain a little bit about how to use pkg-config to find
>> PETSc? Thanks!
>> Evan
>> project(hellopetsc)
>> -DCMAKE_BUILD_TYPE=Debug -G "CodeBlocks - Unix Makefiles"
>> version "3.9.1")
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to: /home/evan/CLionProjects/hello
>> [Finished]
>> On Fri, May 11, 2018 at 12:08 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Yes, it depends on this module from the same repository.
>>> Note that you can use pkg-config to find PETSc these days.
>>> Evan Um <evanum at gmail.com> writes:
>>> > Hi Stefano,
>>> > Thanks for your comment. Now, cmake was able to locate FindPETSc.cmake
>>> file
>>> > in my project directory, but I see a new error.
>>> > Evan
>>> > Messages
>>> > CMake Error at FindPETSc.cmake:123 (include):
>>> >   include could not find load file:
>>> >     FindPackageMultipass
>>> >   CMakeLists.txt:10 (find_package)
>>> > CMake Error at FindPETSc.cmake:124 (find_package_multipass):
>>> >   Unknown CMake command "find_package_multipass".
>>> > See also
>>> > See also
>>> > CMakeLists.txt
>>> > See also
>>> > See also
>>> > [Finished]
>>> > On Fri, May 11, 2018 at 11:34 AM, Stefano Zampini <
>>> stefano.zampini at gmail.com
>>> >> wrote:
>>> >> CMAKE is case sensitive on this. You should use find_package(PETSc ….)
>>> >> > On May 11, 2018, at 9:28 PM, Evan Um <evanum at gmail.com> wrote:
>>> >> > Hi,
>>> >> > I would like to ask a question about FindPETSc.cmake. I place the
>>> cmake
>>> >> file in the same directory where main.cpp is placed. I also placed
>>> the file
>>> >> in /usr/share/cmake_xx/Modules.
>>> >> Actually, it can be put in any directory pointed by the variable
>>> >> CMAKE_MODULE_PATH. If I were you, I would not modify /usr/share/
>>> >> > Where should i put the file? What else should I do to use the file
>>> in
>>> >> cmake? Do I need any other lines in my cmakelists.txt except
>>> >> find_package(petsc)? Thanks for your comments.
>>> >> > Evan
>>> >> > project(hellopetsc)
>>> >> > find_package(PETSC COMPONENTS CXX)
>>> >> > CMake Warning at CMakeLists.txt:9 (find_package):
>>> >> >   By not providing "FindPETSC.cmake" in CMAKE_MODULE_PATH this
>>> project
>>> >> has
>>> >> >   asked CMake to find a package configuration file provided by
>>> "PETSC",
>>> >> but
>>> >> >   CMake did not find one.
>>> >> >   Could not find a package configuration file provided by "PETSC"
>>> with
>>> >> any of
>>> >> >   the following names:
>>> >> >     PETSCConfig.cmake
>>> >> >     petsc-config.cmake
>>> >> >   Add the installation prefix of "PETSC" to CMAKE_PREFIX_PATH or set
>>> >> >   "PETSC_DIR" to a directory containing one of the above files.  If
>>> >> "PETSC"
>>> >> >   provides a separate development package or SDK, be sure it has
>>> been
>>> >> >   installed.
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180511/f406ebe7/attachment.html>
