[petsc-users] Placing FindPETSc.cmake
Evan Um
evanum at gmail.com
Fri May 11 17:41:16 CDT 2018
Jed,
After all was removed, I see a new error from FindPETSc.cmake.
I added to cmake
SET(CMAKE_CXX_COMPILER mpicxx)
FIND_PACKAGE(MPI REQUIRED)
INCLUDE_DIRECTORIES(${MPI_INCLUDE_PATH})
and tested but no luck.
It seems that I need to let FindPETSc.cmake know a compiler location.
Thanks for your help.
Evan
cmake_minimum_required(VERSION 3.10)
project(hellopetsc)
list (APPEND CMAKE_MODULE_PATH /home/evan/CLionProjects/hellopetsc)
SET(CMAKE_CXX_STANDARD 11)
SET(CMAKE_C_COMPILER mpicc)
SET (PETSC_ARCH "arch-linux2-c-debug")
find_package(PETSc COMPONENTS CXX)
add_executable(hellopetsc main.cpp)
/home/evan/opt/clion-2018.1.2/bin/cmake/bin/cmake -DCMAKE_BUILD_TYPE=Debug
-G "CodeBlocks - Unix Makefiles" /home/evan/CLionProjects/hellopetsc
CMake Error at FindPETSc.cmake:179 (include):
include could not find load file:
ResolveCompilerPaths
Call Stack (most recent call first):
CMakeLists.txt:12 (find_package)
CMake Error at FindPETSc.cmake:181 (resolve_includes):
Unknown CMake command "resolve_includes".
-- Configuring incomplete, errors occurred!
See also
"/home/evan/CLionProjects/hellopetsc/cmake-build-debug/CMakeFiles/CMakeOutput.log".
See also
"/home/evan/CLionProjects/hellopetsc/cmake-build-debug/CMakeFiles/CMakeError.log".
[Finished]
On Fri, May 11, 2018 at 3:10 PM, Jed Brown <jed at jedbrown.org> wrote:
> Evan Um <evanum at gmail.com> writes:
> > Matt and Jed,
> > Thanks for your comments.
> > I still have a trouble in using FindPETSc.cmake. I removed the directory:
> > (i.e. canceling cp - r /home/evan/petsc//lib/petsc/
> > conf/rules /home/evan/petsc//lib/petsc/conf/petscrules) and explicitly
> set
> > SET (PETSC_ARCH "arch-linux2-c-debug all").
> No " all".
> > Now, FindPETSc.cmake does not recognize PETSC_DIR and PETSC_ARCH. When I
> > read the comments inside FindPETSc.cmake, the twos should be refined by
> > FindPETSc.cmake. BTW, I have my petsc at /home/evan/petsc. So all are
> > defaults.
> > Thanks for your kind help.
> > Evan
> > project(hellopetsc)
> > CMake Error at FindPETSc.cmake:140 (message):
> > The pair PETSC_DIR=/home/evan/petsc PETSC_ARCH=arch-linux2-c-debug all
> do
> > not specify a valid PETSc installation
> > -- PETSc could not be found. Be sure to set PETSC_DIR and PETSC_ARCH.
> > (missing: PETSC_INCLUDES PETSC_LIBRARIES PETSC_EXECUTABLE_RUNS) (found
> > version "3.9.1")
> > See also
> > See also
> > [Finished]
> > On Fri, May 11, 2018 at 2:13 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >> On Fri, May 11, 2018 at 5:06 PM, Evan Um <evanum at gmail.com> wrote:
> >>> Hi Jed,
> >>> Thanks for the comment. I added the module but still saw errors
> (before I
> >>> arrived here, I had to do cp - r /home/evan/petsc//lib/petsc/
> >>> conf/rules /home/evan/petsc//lib/petsc/conf/petscrules).
> >> That is wrong. It means PETSC_ARCH is (null) instead of the correct
> string.
> >> Matt
> >>> They are supposed to be defined by FindPETSc.cmake. How could I solve
> >>> these errors?
> >>> Could you also explain a little bit about how to use pkg-config to find
> >>> PETSc? Thanks!
> >>> Evan
> >>> project(hellopetsc)
> >>> -DCMAKE_BUILD_TYPE=Debug -G "CodeBlocks - Unix Makefiles"
> >>> version "3.9.1")
> >>> -- Configuring done
> >>> -- Generating done
> >>> -- Build files have been written to: /home/evan/CLionProjects/hello
> >>> [Finished]
> >>> On Fri, May 11, 2018 at 12:08 PM, Jed Brown <jed at jedbrown.org> wrote:
> >>>> Yes, it depends on this module from the same repository.
> >>>> Note that you can use pkg-config to find PETSc these days.
> >>>> > Hi Stefano,
> >>>> > Thanks for your comment. Now, cmake was able to locate
> FindPETSc.cmake
> >>>> file
> >>>> > in my project directory, but I see a new error.
> >>>> > Evan
> >>>> > Messages
> hellopetsc
> >>>> > CMake Error at FindPETSc.cmake:123 (include):
> >>>> > FindPackageMultipass
> >>>> > CMakeLists.txt:10 (find_package)
> >>>> > CMake Error at FindPETSc.cmake:124 (find_package_multipass):
> >>>> > Unknown CMake command "find_package_multipass".
> >>>> > See also
> >>>> > See also
> >>>> > CMakeLists.txt
> hellopetsc
> >>>> > See also
> >>>> > See also
> >>>> > [Finished]
> >>>> > On Fri, May 11, 2018 at 11:34 AM, Stefano Zampini <
> >>>> stefano.zampini at gmail.com
> >>>> >> wrote:
> >>>> >> CMAKE is case sensitive on this. You should use find_package(PETSc
> >>>> >> > On May 11, 2018, at 9:28 PM, Evan Um <evanum at gmail.com> wrote:
> >>>> >> > Hi,
> >>>> >> > I would like to ask a question about FindPETSc.cmake. I place the
> >>>> cmake
> >>>> >> file in the same directory where main.cpp is placed. I also placed
> >>>> the file
> >>>> >> in /usr/share/cmake_xx/Modules.
> >>>> >> Actually, it can be put in any directory pointed by the variable
> >>>> >> CMAKE_MODULE_PATH. If I were you, I would not modify /usr/share/
> >>>> >> > Where should i put the file? What else should I do to use the
> file
> >>>> in
> >>>> >> cmake? Do I need any other lines in my cmakelists.txt except
> >>>> >> find_package(petsc)? Thanks for your comments.
> >>>> >> > Evan
> >>>> >> > project(hellopetsc)
> >>>> >> > find_package(PETSC COMPONENTS CXX)
> >>>> >> > CMake Warning at CMakeLists.txt:9 (find_package):
> >>>> >> > By not providing "FindPETSC.cmake" in CMAKE_MODULE_PATH this
> >>>> project
> >>>> >> has
> >>>> >> > asked CMake to find a package configuration file provided by
> >>>> "PETSC",
> >>>> >> but
> >>>> >> > CMake did not find one.
> >>>> >> > Could not find a package configuration file provided by "PETSC"
> >>>> with
> >>>> >> any of
> >>>> >> > the following names:
> >>>> >> > PETSCConfig.cmake
> >>>> >> > petsc-config.cmake
> >>>> >> > Add the installation prefix of "PETSC" to CMAKE_PREFIX_PATH or
> set
> >>>> >> > "PETSC_DIR" to a directory containing one of the above files.
> If
> >>>> >> "PETSC"
> >>>> >> > provides a separate development package or SDK, be sure it has
> >>>> been
> >>>> >> > installed.
> >> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to which
> their
> >> experiments lead.
> >> -- Norbert Wiener
> >> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180511/403390c9/attachment.html>
