[petsc-users] PETSc-MUMPS interface, numeric and symbolic factorisation
Y. Shidi
ys453 at cam.ac.uk
Fri May 11 08:14:01 CDT 2018
Thank you for your reply.
> How are you changing the matrix? Do you remember to assemble?
I use MatCreateMPIAIJWithArrays() to create the matrix,
and after that I call MatAssemblyBegin() and MatAssemblyEnd().
But I actually destroy the matrix at the end of each iteration
and create the matrix at the beginning of each iteration.
Cheers,
Shidi
On 2018-05-11 12:59, Matthew Knepley wrote:
> On Fri, May 11, 2018 at 7:14 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>> Dear Matt,
>> Thank you for your help last time.
>> I want to get more detail about the Petsc-MUMPS factorisation;
>> so I go to look the code "/src/mat/impls/aij/mpi/mumps/mumps.c".
>> And I found the following functions are quite important to
>> the question:
>> PetscErrorCode MatCholeskyFactorSymbolic_MUMPS(Mat F,Mat A,IS
>> r,const MatFactorInfo *info);
>> PetscErrorCode MatFactorNumeric_MUMPS(Mat F,Mat A,const
>> PetscErrorCode MatSolve_MUMPS(Mat A,Vec b,Vec x);
>> I print some sentence to trace when these functions are called.
>> Then I test my code; the values in the matrix is changing but the
>> structure stays the same. Below is the output.
>> We can see that at 0th step, all the symbolic, numeric and solve
>> are called; in the subsequent steps only the solve stage is called,
>> the numeric step is not called.
> Matt
>> Iteration 0 Step 0.0005 Time 0.0005
>> [INFO]: Direct Solver setup
>> finish MatCholeskyFactorSymbolic_MUMPS
>> finish MatFactorNumeric_MUMPS
>> MatSolve_MUMPS
>> Iteration 1 Step 0.0005 Time 0.0005
>> MatSolve_MUMPS
>> Iteration 2 Step 0.0005 Time 0.001
>> MatSolve_MUMPS
>> [INFO]: End of program!!!
>> I am wondering if there is any possibility to split the numeric
>> and solve stage (as you mentioned using KSPSolve).
>> Thank you very much indeed.
>> Kind Regards,
>> Shidi
>> On 2018-05-04 21:10, Y. Shidi wrote:
>> Thank you very much for your reply.
>> That is really clear.
>> Kind Regards,
>> Shidi
>> On 2018-05-04 21:05, Matthew Knepley wrote:
>> On Fri, May 4, 2018 at 3:54 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>> Dear Matt,
>> Thank you very much for your reply!
>> So what you mean is that I can just do the KSPSolve() every
>> iteration
>> once the MUMPS is set?
>> Yes.
>> That means inside the KSPSolve() the numerical factorization is
>> performed. If that is the case, it seems that the ksp object is
>> not changed when the values in the matrix are changed.
>> Yes.
>> Or do I need to call both KSPSetOperators() and KSPSolve()?
>> If you do SetOperators, it will redo the factorization. If you do
>> not,
>> it will look
>> at the Mat object, determine that the structure has not changed,
>> and
>> just redo
>> the numerical factorization.
>> Thanks,
>> Matt
>> On 2018-05-04 14:44, Matthew Knepley wrote:
>> On Fri, May 4, 2018 at 9:40 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>> Dear PETSc users,
>> I am currently using MUMPS to solve linear systems directly.
>> Generally, we use ICNTL(7) or ICNTL(29) to do the preprocessing
>> step and then solve the system.
>> In my code, the values in the matrix is changed in each iteration,
>> but the structure of the matrix stays the same, which means the
>> performance can be improved if symbolic factorisation is only
>> performed once. Hence, it is necessary to split the symbolic
>> and numeric factorisation. However, I cannot find a specific step
>> (control parameter) to perform the numeric factorisation.
>> I have used ICNTL(3) and ICNTL(4) to print the MUMPS information,
>> it seems that the symbolic and numeric factorisation always perform
>> together.
>> If you use KSPSolve instead, it will automatically preserve the
>> symbolic
>> factorization.
>> Thanks,
>> Matt
>> So I am wondering if anyone has an idea about it.
>> Below is how I set up MUMPS solver:
>> PC pc;
>> PetscBool flg_mumps, flg_mumps_ch;
>> flg_mumps = PETSC_FALSE;
>> flg_mumps_ch = PETSC_FALSE;
>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_lu", &flg_mumps,
>> NULL);
>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_ch", &flg_mumps_ch,
>> NULL);
>> if(flg_mumps ||flg_mumps_ch)
>> KSPSetType(_ksp, KSPPREONLY);
>> PetscInt ival,icntl;
>> PetscReal val;
>> KSPGetPC(_ksp, &pc);
>> /// Set preconditioner type
>> if(flg_mumps)
>> PCSetType(pc, PCLU);
>> else if(flg_mumps_ch)
>> MatSetOption(A, MAT_SPD, PETSC_TRUE);
>> PCSetType(pc, PCCHOLESKY);
>> PCFactorSetMatSolverPackage(pc, MATSOLVERMUMPS);
>> PCFactorSetUpMatSolverPackage(pc);
>> PCFactorGetMatrix(pc, &_F);
>> icntl = 7; ival = 0;
>> MatMumpsSetIcntl( _F, icntl, ival );
>> MatMumpsSetIcntl(_F, 3, 6);
>> MatMumpsSetIcntl(_F, 4, 2);
>> KSPSetUp(_ksp);
>> Kind Regards,
>> Shidi
>> experiments is infinitely more interesting than any results to
>> which
>> their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ [1] [1] [1]
>> Links:
>> [1] http://www.caam.rice.edu/~mk51/ [2] [2]
>> which
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ [1] [2]
>> Links:
>> [1] https://www.cse.buffalo.edu/~knepley/ [1]
>> [2] http://www.caam.rice.edu/~mk51/ [2]
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ [2]
> Links:
