[petsc-users] PETSc-MUMPS interface, numeric and symbolic factorisation
Matthew Knepley
knepley at gmail.com
Fri May 11 06:59:52 CDT 2018
On Fri, May 11, 2018 at 7:14 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
> Dear Matt,
> Thank you for your help last time.
> I want to get more detail about the Petsc-MUMPS factorisation;
> so I go to look the code "/src/mat/impls/aij/mpi/mumps/mumps.c".
> And I found the following functions are quite important to
> the question:
> PetscErrorCode MatCholeskyFactorSymbolic_MUMPS(Mat F,Mat A,IS r,const
> MatFactorInfo *info);
> PetscErrorCode MatFactorNumeric_MUMPS(Mat F,Mat A,const MatFactorInfo
> *info);
> PetscErrorCode MatSolve_MUMPS(Mat A,Vec b,Vec x);
> I print some sentence to trace when these functions are called.
> Then I test my code; the values in the matrix is changing but the
> structure stays the same. Below is the output.
> We can see that at 0th step, all the symbolic, numeric and solve
> are called; in the subsequent steps only the solve stage is called,
> the numeric step is not called.
How are you changing the matrix? Do you remember to assemble?
Matt
> Iteration 0 Step 0.0005 Time 0.0005
> [INFO]: Direct Solver setup
> finish MatCholeskyFactorSymbolic_MUMPS
> finish MatFactorNumeric_MUMPS
> MatSolve_MUMPS
> Iteration 1 Step 0.0005 Time 0.0005
> MatSolve_MUMPS
> Iteration 2 Step 0.0005 Time 0.001
> MatSolve_MUMPS
> [INFO]: End of program!!!
> I am wondering if there is any possibility to split the numeric
> and solve stage (as you mentioned using KSPSolve).
> Thank you very much indeed.
> Kind Regards,
> Shidi
> On 2018-05-04 21:10, Y. Shidi wrote:
>> Thank you very much for your reply.
>> That is really clear.
>> Kind Regards,
>> Shidi
>> On 2018-05-04 21:05, Matthew Knepley wrote:
>>> On Fri, May 4, 2018 at 3:54 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>> Dear Matt,
>>>> Thank you very much for your reply!
>>>> So what you mean is that I can just do the KSPSolve() every
>>>> iteration
>>>> once the MUMPS is set?
>>> Yes.
>>> That means inside the KSPSolve() the numerical factorization is
>>>> performed. If that is the case, it seems that the ksp object is
>>>> not changed when the values in the matrix are changed.
>>> Yes.
>>> Or do I need to call both KSPSetOperators() and KSPSolve()?
>>> If you do SetOperators, it will redo the factorization. If you do not,
>>> it will look
>>> at the Mat object, determine that the structure has not changed, and
>>> just redo
>>> the numerical factorization.
>>> Thanks,
>>> Matt
>>> On 2018-05-04 14:44, Matthew Knepley wrote:
>>>> On Fri, May 4, 2018 at 9:40 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>> Dear PETSc users,
>>>> I am currently using MUMPS to solve linear systems directly.
>>>> Generally, we use ICNTL(7) or ICNTL(29) to do the preprocessing
>>>> step and then solve the system.
>>>> In my code, the values in the matrix is changed in each iteration,
>>>> but the structure of the matrix stays the same, which means the
>>>> performance can be improved if symbolic factorisation is only
>>>> performed once. Hence, it is necessary to split the symbolic
>>>> and numeric factorisation. However, I cannot find a specific step
>>>> (control parameter) to perform the numeric factorisation.
>>>> I have used ICNTL(3) and ICNTL(4) to print the MUMPS information,
>>>> it seems that the symbolic and numeric factorisation always perform
>>>> together.
>>>> If you use KSPSolve instead, it will automatically preserve the
>>>> symbolic
>>>> factorization.
>>>> Thanks,
>>>> Matt
>>>> So I am wondering if anyone has an idea about it.
>>>> Below is how I set up MUMPS solver:
>>>> PC pc;
>>>> PetscBool flg_mumps, flg_mumps_ch;
>>>> flg_mumps = PETSC_FALSE;
>>>> flg_mumps_ch = PETSC_FALSE;
>>>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_lu", &flg_mumps,
>>>> NULL);
>>>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_ch", &flg_mumps_ch,
>>>> NULL);
>>>> if(flg_mumps ||flg_mumps_ch)
>>>> KSPSetType(_ksp, KSPPREONLY);
>>>> PetscInt ival,icntl;
>>>> PetscReal val;
>>>> KSPGetPC(_ksp, &pc);
>>>> /// Set preconditioner type
>>>> if(flg_mumps)
>>>> PCSetType(pc, PCLU);
>>>> else if(flg_mumps_ch)
>>>> MatSetOption(A, MAT_SPD, PETSC_TRUE);
>>>> PCSetType(pc, PCCHOLESKY);
>>>> PCFactorSetMatSolverPackage(pc, MATSOLVERMUMPS);
>>>> PCFactorSetUpMatSolverPackage(pc);
>>>> PCFactorGetMatrix(pc, &_F);
>>>> icntl = 7; ival = 0;
>>>> MatMumpsSetIcntl( _F, icntl, ival );
>>>> MatMumpsSetIcntl(_F, 3, 6);
>>>> MatMumpsSetIcntl(_F, 4, 2);
>>>> KSPSetUp(_ksp);
>>>> Kind Regards,
>>>> Shidi
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to
>>>> which
>>>> their experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ [1] [1]
>>>> Links:
>>>> [1] http://www.caam.rice.edu/~mk51/ [2]
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ [2]
>>> Links:
>>> [1] https://www.cse.buffalo.edu/~knepley/
>>> [2] http://www.caam.rice.edu/~mk51/
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180511/1f77aaf9/attachment.html>
