[petsc-users] Solving advection equations implicitly
Zou, Ling
ling.zou at inl.gov
Mon May 7 17:24:53 CDT 2018
On Mon, May 7, 2018 at 4:15 PM, Nishant Nangia <nishantnangia329 at gmail.com>
wrote:
> We basically want something that is stable and non-oscillatory for any
> given time step size.
TVD upwind + 1st order BDF (BDF1)
As Jed already pointed out, there is no strong stability-reserving (SSP)
scheme with oder > 1.
> A little more context: Q is a fluid density variable, which we are
> currently updating using an explicit forward Euler step. This updated
> quantity is later used in a conservative discretization of the
> Navier-Stokes (NS) equations on a staggered mesh. We are using finite
> volume/finite differences.
> We observe oscillations in Q after a few time steps, which causes the
> overall mass of the domain to change and breaks the linear solvers for NS.
> We are experimenting with some strong stability preserving, TVD schemes to
> update this density, but were thinking of trying an implicit update instead.
> *Nishant Nangia*
> Northwestern University
> Ph.D. Candidate | Engineering Sciences and Applied Mathematics
> Tech L386
> On Mon, May 7, 2018 at 4:56 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Do you want it to be time accurate (implies CFL number is modest) or do
>> you want very large time steps? If very large time steps, why not
>> steady state?
>> Nishant Nangia <nishantnangia329 at gmail.com> writes:
>> > Hi all,
>> > I want to implicitly solve a linear advection equation of the form:
>> > dQ/dt + div(u*Q) = 0
>> > for a scalar quantity Q, with some known velocity field u. Note that it
>> is
>> > purely advection with no diffusion term.
>> > Is there a recommended solver/preconditioner combination to solve
>> something
>> > like this?
>> > *Nishant Nangia*
>> > Tech L386
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180507/3516b933/attachment.html>
