[petsc-users] Solving advection equations implicitly
Zou, Ling ling.zou at inl.gov
Mon May 7 17:00:58 CDT 2018
I played with implicitly (BDF1 and BDF2) solving a linear advection
equation before.
For spatial discretization, I used upwind donor cell method.
I did not give any specifications to the solver, so I suppose default works
just fine. I did supply a Jacobian matrix for preconditioning purpose.
Here a screen shot of -snes_view and -ksp_view is attached.
Maybe PETSc team member could provide more useful info from this screenshot.
Hope this helps.
-Ling
SNES Object: 1 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=6
  total number of function evaluations=11
  norm schedule ALWAYS
  SNESLineSearch Object: 1 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  KSP Object: 1 MPI processes
    type: gmres
      restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      happy breakdown tolerance 1e-30
    maximum iterations=30, initial guess is zero
    tolerances:  relative=0.001, absolute=1e-50, divergence=10000.
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object: 1 MPI processes
    type: ilu
      out-of-place factorization
      0 levels of fill
      tolerance for zero pivot 2.22045e-14
      matrix ordering: natural
      factor fill ratio given 1., needed 1.
        Factored matrix follows:
          Mat Object: 1 MPI processes
            type: seqaij
            rows=600, cols=600
            package used to perform factorization: petsc
            total: nonzeros=2994, allocated nonzeros=2994
            total number of mallocs used during MatSetValues calls =0
              not using I-node routines
    linear system matrix followed by preconditioner matrix:
      type: mffd
      rows=600, cols=600
        Matrix-free approximation:
          err=1.49012e-08 (relative error in function evaluation)
          Using wp compute h routine
              Does not compute normU
      type: seqaij
      rows=600, cols=600
On Mon, May 7, 2018 at 3:24 PM, Nishant Nangia <nishantnangia329 at gmail.com>
wrote:
> Hi all,
> I want to implicitly solve a linear advection equation of the form:
> dQ/dt + div(u*Q) = 0
> for a scalar quantity Q, with some known velocity field u. Note that it is
> purely advection with no diffusion term.
> Is there a recommended solver/preconditioner combination to solve
> something like this?
> *Nishant Nangia*
> Northwestern University
> Ph.D. Candidate | Engineering Sciences and Applied Mathematics
> Tech L386
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180507/0c793485/attachment-0001.html>
