[petsc-users] Could not determine how to create a shared library!
Satish Balay
balay at mcs.anl.gov
Thu May 3 11:02:22 CDT 2018
Perhaps you should use MKL on theta? Again check config/examples/arch-cray-xc40-knl-opt.py
Satish
On Thu, 3 May 2018, Kong, Fande wrote:
> Thanks,
> I get the PETSc complied, but theta does not like the shared lib, I think.
> I am switching back to a static lib. I ever successfully built and ran
> the PETSc with the static compiling.
> But I encountered a problem this time on building blaslapack.
> Thanks,
> Fande
> On Tue, May 1, 2018 at 2:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > This is theta..
> > Try: using --LDFLAGS=-dynamic option
> > [as listed in config/examples/arch-cray-xc40-knl-opt.py]
> > Satish
> > On Tue, 1 May 2018, Kong, Fande wrote:
> > > Hi All,
> > > I can build a static petsc library on a supercomputer, but could not do
> > the
> > > same thing with " --with-shared-libraries=1".
> > > The log file is attached.
> > > Fande,
