[petsc-users] Could not determine how to create a shared library!
Satish Balay
balay at mcs.anl.gov
Thu May 3 11:09:32 CDT 2018
Ok you are not 'building blaslapack' - but using mkl [as per configure.log].
I'll have to check the issue. It might be something to do with using
mkl as a static library..
Hong might have some suggestions wrt theta builds.
Satish
On Thu, 3 May 2018, Satish Balay wrote:
> Perhaps you should use MKL on theta? Again check config/examples/arch-cray-xc40-knl-opt.py
> Satish
> On Thu, 3 May 2018, Kong, Fande wrote:
> > Thanks,
> > I get the PETSc complied, but theta does not like the shared lib, I think.
> > I am switching back to a static lib. I ever successfully built and ran
> > the PETSc with the static compiling.
> > But I encountered a problem this time on building blaslapack.
> > Thanks,
> > Fande
> > On Tue, May 1, 2018 at 2:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > This is theta..
> > > Try: using --LDFLAGS=-dynamic option
> > > [as listed in config/examples/arch-cray-xc40-knl-opt.py]
> > > Satish
> > > On Tue, 1 May 2018, Kong, Fande wrote:
> > > > Hi All,
> > > > I can build a static petsc library on a supercomputer, but could not do
> > > the
> > > > same thing with " --with-shared-libraries=1".
> > > > The log file is attached.
> > > > Fande,
