[petsc-users] Could not determine how to create a shared library!
Kong, Fande fande.kong at inl.gov
Thu May 3 11:00:39 CDT 2018
I get the PETSc complied, but theta does not like the shared lib, I think.
I am switching back to a static lib.   I ever successfully built and ran
the PETSc with the static compiling.
But I encountered a problem this time on building blaslapack.
Fande
On Tue, May 1, 2018 at 2:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> This is theta..
> Try: using --LDFLAGS=-dynamic option
> [as listed in config/examples/arch-cray-xc40-knl-opt.py]
> Satish
> On Tue, 1 May 2018, Kong, Fande wrote:
> > Hi All,
> > I can build a static petsc library on a supercomputer, but could not do
> the
> > same thing with " --with-shared-libraries=1".
> > The log file is attached.
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180503/e27dd5ba/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180503/e27dd5ba/attachment-0001.zip>
