[petsc-users] --download-hdf5 and then compiling cgns
Satish Balay
balay at mcs.anl.gov
Thu Mar 29 11:37:46 CDT 2018
--download-hdf5 uses 'autoconf' build of hdf5 - and not cmake
build. [hdf5 provides both build tools].
This must be the reason why hdf5Config.cmake and hdf5-config.cmake
files might be missing.
You might be able to install hdf5 manually with cmake - and then build
cgns-3.3.1 with it.
Satish
On Thu, 29 Mar 2018, Klaij, Christiaan wrote:
> Satish,
> I've build petsc-3.8.3 with --download-hdf5 and this works
> fine. Now, I'm trying to compile cgns-3.3.1 and have it use the
> hdf5 library from petsc. Therefore, in the cmake configure I have
> set this option
> -D HDF5_DIR=/path/to/petsc/hdf5
> but cmake gives this message:
> CMake Warning at CMakeLists.txt:207 (find_package):
> Could not find a package configuration file provided by "HDF5" with any of
> the following names:
> hdf5Config.cmake
> hdf5-config.cmake
> and then falls back to the system's hdf5. Indeed there are no
> such files in /path/to/petsc/hdf5. Any idea on how to proceed
> from here?
> Chris
> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
> MARIN news: http://www.marin.nl/web/News/News-items/Comfort-draft-for-semisubmersible-yachts.htm
