[petsc-users] --download-hdf5 and then compiling cgns
Gaetan Kenway gaetank at gmail.com
Thu Mar 29 11:43:12 CDT 2018
I have compiled CGNS3.3 with hdf from PETSc but not using cmake from CGNS.
Here is what I used:
git clone  https://github.com/CGNS/CGNS.git
cd CGNS/src
export CC=mpicc
export FC=mpif90
export FCFLAGS='-fPIC -O3'
export CFLAGS='-fPIC -O3'
export LIBS='-lz -ldl'
./configure --with-hdf5=$PETSC_DIR/$PETSC_ARCH --enable-64bit
--prefix=/u/wk/gkenway/.local  --enable-parallel --enable-cgnstools=yes
--enable-shared
make -j 10
Hope that helps
Gaetan
On Thu, Mar 29, 2018 at 9:37 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> --download-hdf5 uses 'autoconf' build of hdf5 - and not cmake
> build. [hdf5 provides both build tools].
> This must be the reason why hdf5Config.cmake and hdf5-config.cmake
> files might be missing.
> You might be able to install hdf5 manually with cmake - and then build
> cgns-3.3.1 with it.
> Satish
> On Thu, 29 Mar 2018, Klaij, Christiaan wrote:
> > Satish,
> > I've build petsc-3.8.3 with --download-hdf5 and this works
> > fine. Now, I'm trying to compile cgns-3.3.1 and have it use the
> > hdf5 library from petsc. Therefore, in the cmake configure I have
> > set this option
> > -D HDF5_DIR=/path/to/petsc/hdf5
> > but cmake gives this message:
> > CMake Warning at CMakeLists.txt:207 (find_package):
> >   Could not find a package configuration file provided by "HDF5" with
> any of
> >   the following names:
> >     hdf5Config.cmake
> >     hdf5-config.cmake
> > and then falls back to the system's hdf5. Indeed there are no
> > such files in /path/to/petsc/hdf5. Any idea on how to proceed
> > from here?
> > Chris
> > dr. ir. Christiaan Klaij  | Senior Researcher | Research & Development
> > MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl |
> http://www.marin.nl
> > MARIN news: http://www.marin.nl/web/News/News-items/Comfort-draft-for-
> semisubmersible-yachts.htm
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180329/21aa531e/attachment.html>
