[petsc-users] Tweaking my code for CUDA
Manuel Valera
mvalera-w at mail.sdsu.edu
Thu Mar 15 16:06:28 CDT 2018
Ok Matthew and everyone, i finally made my small example work, im sending
the ksp_view and log_view for feedback / check up if it seems correct.
What i would like to do next is explore how fast this setup solves my
linear systems, for it i could fire up the whole big model or i could
extract the binaries and solve with this standalone, i know how do extract
a matrix binary, is there an analog for a vector? i would like to test my
system for scaling and then look at multi-node scaling as well as
multi-gpu, any ideas would be welcome,
.-.-.-.-.-.- ksp_view and log_view .-.-.-.-.-.-
[valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type seqcuda -mat_type
seqaijcusparse -ksp_view -log_view
laplacian.petsc !
TrivSoln loaded, size: 125 / 125
KSP Object: 1 MPI processes
type: gcr
restart = 30
restarts performed = 1
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-11, absolute=1e-50, divergence=10000.
right preconditioning
using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: ilu
out-of-place factorization
0 levels of fill
tolerance for zero pivot 2.22045e-14
matrix ordering: natural
factor fill ratio given 1., needed 1.
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=125, cols=125
package used to perform factorization: petsc
total: nonzeros=1685, allocated nonzeros=1685
total number of mallocs used during MatSetValues calls =0
not using I-node routines
linear system matrix = precond matrix:
type: seqaijcusparse
rows=125, cols=125
soln maxval: 1.0000000000007194
soln minval: 0.99999999999484046
Norm: 1.3586823299239453E-011
Its: 4
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r
-fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary:
./linsolve on a named node50 with 1 processor, by valera Thu Mar 15
14:04:47 2018
Using Petsc Development GIT revision: v3.8.3-2027-g045eeab GIT Date:
2018-03-12 13:30:25 -0500
Max Max/Min Avg Total
Time (sec): 7.459e-01 1.00000 7.459e-01
Objects: 7.500e+01 1.00000 7.500e+01
Flop: 6.024e+04 1.00000 6.024e+04 6.024e+04
Flop/sec: 8.076e+04 1.00000 8.076e+04 8.076e+04
MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Reductions: 0.000e+00 0.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N
--> 2N flop
and VecAXPY() for complex vectors of length N
--> 8N flop
Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages ---
-- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts
%Total Avg %Total counts %Total
0: Main Stage: 7.4589e-01 100.0% 6.0240e+04 100.0% 0.000e+00
0.0% 0.000e+00 0.0% 0.000e+00 0.0%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flop: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and
PetscLogStagePop().
%T - percent time in this phase %F - percent flop in this
phase
%M - percent messages in this phase %L - percent message lengths
in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over
all processors)
Event Count Time (sec) Flop
--- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len
Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDotNorm2 4 1.0 2.0170e-04 1.0 3.99e+03 1.0 0.0e+00 0.0e+00
0.0e+00 0 7 0 0 0 0 7 0 0 0 20
VecMDot 3 1.0 1.4329e-04 1.0 1.49e+03 1.0 0.0e+00 0.0e+00
0.0e+00 0 2 0 0 0 0 2 0 0 0 10
VecNorm 6 1.0 3.7265e-04 1.0 1.49e+03 1.0 0.0e+00 0.0e+00
0.0e+00 0 2 0 0 0 0 2 0 0 0 4
VecScale 8 1.0 6.8903e-05 1.0 1.00e+03 1.0 0.0e+00 0.0e+00
0.0e+00 0 2 0 0 0 0 2 0 0 0 15
VecSet 74 1.0 6.0844e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 9 1.0 9.3699e-05 1.0 2.25e+03 1.0 0.0e+00 0.0e+00
0.0e+00 0 4 0 0 0 0 4 0 0 0 24
VecAYPX 1 1.0 2.8685e-01 1.0 2.50e+02 1.0 0.0e+00 0.0e+00
0.0e+00 38 0 0 0 0 38 0 0 0 0 0
VecMAXPY 6 1.0 1.2016e-04 1.0 6.00e+03 1.0 0.0e+00 0.0e+00
0.0e+00 0 10 0 0 0 0 10 0 0 0 50
VecAssemblyBegin 3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecAssemblyEnd 3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecCUDACopyTo 5 1.0 2.8849e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecCUDACopyFrom 9 1.0 9.7275e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatMult 6 1.0 3.6573e-04 1.0 1.95e+04 1.0 0.0e+00 0.0e+00
0.0e+00 0 32 0 0 0 0 32 0 0 0 53
MatSolve 4 1.0 1.1349e-04 1.0 1.30e+04 1.0 0.0e+00 0.0e+00
0.0e+00 0 22 0 0 0 0 22 0 0 0 114
MatLUFactorNum 1 1.0 2.9087e-05 1.0 1.13e+04 1.0 0.0e+00 0.0e+00
0.0e+00 0 19 0 0 0 0 19 0 0 0 389
MatILUFactorSym 1 1.0 2.7180e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatAssemblyBegin 1 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatAssemblyEnd 1 1.0 4.5514e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetRowIJ 1 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering 1 1.0 8.5831e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatLoad 1 1.0 2.4009e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatView 2 1.0 1.6499e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatCUSPARSECopyTo 2 1.0 4.4584e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
PCSetUp 1 1.0 1.8096e-04 1.0 1.13e+04 1.0 0.0e+00 0.0e+00
0.0e+00 0 19 0 0 0 0 19 0 0 0 63
PCApply 4 1.0 1.1659e-04 1.0 1.30e+04 1.0 0.0e+00 0.0e+00
0.0e+00 0 22 0 0 0 0 22 0 0 0 111
KSPSetUp 1 1.0 2.2879e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve 1 1.0 2.8820e-01 1.0 4.52e+04 1.0 0.0e+00 0.0e+00
0.0e+00 39 75 0 0 0 39 75 0 0 0 0
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Vector 64 63 104280 0.
Matrix 2 2 51368 0.
Viewer 3 1 848 0.
Preconditioner 2 1 1016 0.
Krylov Solver 1 1 1248 0.
Index Set 3 3 3900 0.
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-ksp_view
-log_view
-mat_type seqaijcusparse
-matload_block_size 1
-vec_type seqcuda
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --prefix=/usr/local/petsc.cod/petsc-install
--with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=1
--with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
Libraries compiled on Wed Mar 14 14:53:02 2018 on node50
Machine characteristics:
Linux-3.10.0-693.17.1.el7.x86_64-x86_64-with-centos-7.2.1511-Core
Using PETSc directory: /usr/local/petsc.cod/petsc-install
Using PETSc arch:
Using C compiler: /usr/lib64/openmpi/bin/mpicc -fPIC -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
-fvisibility=hidden -O2
Using Fortran compiler: /usr/lib64/openmpi/bin/mpif90 -fPIC -Wall
-ffree-line-length-0 -Wno-unused-dummy-argument -O2
Using include paths: -I/usr/local/petsc.cod/petsc-install/include
-I/usr/local/petsc.cod/petsc-install//include -I/usr/local/cuda/include
-I/usr/lib64/openmpi/include
Using C linker: /usr/lib64/openmpi/bin/mpicc
Using Fortran linker: /usr/lib64/openmpi/bin/mpif90
Using libraries: -Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
-L/usr/local/petsc.cod/petsc-install/lib -lpetsc -Wl,-rpath,/usr/lib64
-L/usr/lib64 -Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64
-Wl,-rpath,/usr/lib64/openmpi/lib -L/usr/lib64/openmpi/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
-L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -llapack -lblas -lm -lcufft
-lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi -lmpi_mpifh
-lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lstdc++
-ldl
On Wed, Mar 14, 2018 at 4:23 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 15, 2018 at 8:18 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
> wrote:
>> Ok so, i went back and erased the old libpetsc.so.3 i think it was the
>> one causing problems, i had --with-shared-libraries=0 and the installation
>> complained of not having that file, then reinstalled with
>> --with-shared-libraries=1 and it is finally recognizing my system
>> installation with only CUDA, but now it gives a 11 SEGV violation error:
> But ex19 runs?
> And this crash is without CUDA? Just run valgrind on it
> Matt
>> [valera at node50 alone]$ ./linsolve
>> laplacian.petsc !
>> [0]PETSC ERROR: ------------------------------
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>> ocumentation/faq.html#valgrind
>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
>> X to find memory corruption errors
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>> and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Signal received
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab GIT
>> Date: 2018-03-12 13:30:25 -0500
>> [0]PETSC ERROR: ./linsolve on a named node50 by valera Wed Mar 14
>> 16:17:34 2018
>> [0]PETSC ERROR: Configure options --prefix=/usr/local/petsc.cod/petsc-install
>> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 59.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Thanks,
>> On Wed, Mar 14, 2018 at 1:52 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, Mar 15, 2018 at 4:01 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>>> wrote:
>>>> Ok well, it turns out the $PETSC_DIR points to the testpetsc directory,
>>>> and it makes, install and tests without problems (only a problem on ex5f)
>>>> but trying to reconfigure on valera/petsc directory asks me to change the
>>>> $PETSC_DIR variable,
>>> Yes, you must set PETSC_DIR to point to the installation you want to use.
>>> Matt
>>>> Meanwhile the system installation still points to the valera/petsc/cuda
>>>> build,
>>>> should i just delete the petsc installation folder and start over?
>>>> Thanks,
>>>> On Wed, Mar 14, 2018 at 11:36 AM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Thu, Mar 15, 2018 at 3:25 AM, Manuel Valera <
>>>>> mvalera-w at mail.sdsu.edu> wrote:
>>>>>> yeah that worked,
>>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcuda -dm_mat_type
>>>>>> seqaijcusparse
>>>>>> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
>>>>>> Number of SNES iterations = 2
>>>>>> How do i make sure the other program refer to this installation?
>>>>>> using the same arguments there i get:
>>>>>> [valera at node50 alone]$ ./linsolve -vec_type seqcuda -mat_type
>>>>>> seqaijcusparse
>>>>>> laplacian.petsc !
>>>>>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>>>>>> package: http://www.mcs.anl.gov/petsc/documentation/installation.html
>>>>>> #external
>>>>>> [0]PETSC ERROR: Unknown vector type: seqcuda
>>>>> This PETSc has not been configured with CUDA. It is located in /home/valera/petsc.
>>>>> The other
>>>>> one you used is located in /home/valera/testpetsc. It does not make
>>>>> much sense to me that
>>>>> it does not understand CUDA since it says the configure arguments had
>>>>> --with-cuda=1. There
>>>>> must have been a build problem. Rebuild
>>>>> cd $PETSC_DIR
>>>>> make all
>>>>> If you still have a problem, reconfigure
>>>>> cd $PETSC_DIR
>>>>> ./cuda/lib/petsc/conf/reconfigure-cuda.py
>>>>> make all
>>>>> If that still fails, then something very bizarre is happening on your
>>>>> machine and we will have
>>>>> to exchange more mail.
>>>>> Matt
>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>>>>> GIT Date: 2018-02-28 10:19:08 -0600
>>>>>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar
>>>>>> 14 11:25:11 2018
>>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>>>>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>>>>>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>>>>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>>>>>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>>>>>> [0]PETSC ERROR: #1 VecSetType() line 42 in
>>>>>> /home/valera/petsc/src/vec/vec/interface/vecreg.c
>>>>>> [0]PETSC ERROR: #2 VecSetTypeFromOptions_Private() line 1241 in
>>>>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>>>>> [0]PETSC ERROR: #3 VecSetFromOptions() line 1276 in
>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>> [0]PETSC ERROR: Vec object's type is not set: Argument # 1
>>>>>> 14 11:25:11 2018
>>>>>> [0]PETSC ERROR: #4 VecDuplicate() line 375 in
>>>>>> 14 11:25:11 2018
>>>>>> [0]PETSC ERROR: #5 VecDuplicate() line 375 in
>>>>>> [0]PETSC ERROR: #6 User provided function() line 0 in User file
>>>>>> I made sure there is a call for Vec/MatSetFromOptions() there, i am
>>>>>> loading the matrix from a petsc binary in this case,
>>>>>> Thanks,
>>>>>> On Wed, Mar 14, 2018 at 11:22 AM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Thu, Mar 15, 2018 at 3:19 AM, Manuel Valera <
>>>>>>>> Yes, this is the system installation that is being correctly linked
>>>>>>>> (the linear solver and model are not linking the correct installation idk
>>>>>>>> why yet) i configured with only CUDA this time because of the message Karl
>>>>>>>> Rupp posted on my installation thread, where he says only one type of
>>>>>>>> library will work at a time, anyway this is what i got:
>>>>>>>> -dm_mat_type seqaijcusp
>>>>>>>> ocumentation/installation.html#external
>>>>>>>> [0]PETSC ERROR: Unknown Mat type given: seqaijcusp
>>>>>>> It is telling you the problem. Use
>>>>>>> -dm_mat_type seqaijcusparse
>>>>>>> Matt
>>>>>>>> v3.8.3-2027-g045eeab GIT Date: 2018-03-12 13:30:25 -0500
>>>>>>>> [0]PETSC ERROR: ./ex19 on a named node50 by valera Wed Mar 14
>>>>>>>> 11:17:25 2018
>>>>>>>> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
>>>>>>>> --download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
>>>>>>>> [0]PETSC ERROR: #1 MatSetType() line 61 in
>>>>>>>> /home/valera/testpetsc/src/mat/interface/matreg.c
>>>>>>>> [0]PETSC ERROR: #2 DMCreateMatrix_DA() line 693 in
>>>>>>>> /home/valera/testpetsc/src/dm/impls/da/fdda.c
>>>>>>>> [0]PETSC ERROR: #3 DMCreateMatrix() line 1199 in
>>>>>>>> /home/valera/testpetsc/src/dm/interface/dm.c
>>>>>>>> [0]PETSC ERROR: #4 SNESSetUpMatrices() line 646 in
>>>>>>>> /home/valera/testpetsc/src/snes/interface/snes.c
>>>>>>>> [0]PETSC ERROR: #5 SNESSetUp_NEWTONLS() line 296 in
>>>>>>>> /home/valera/testpetsc/src/snes/impls/ls/ls.c
>>>>>>>> [0]PETSC ERROR: #6 SNESSetUp() line 2795 in
>>>>>>>> [0]PETSC ERROR: #7 SNESSolve() line 4187 in
>>>>>>>> [0]PETSC ERROR: #8 main() line 161 in /home/valera/testpetsc/src/sne
>>>>>>>> s/examples/tutorials/ex19.c
>>>>>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>>>>>> [0]PETSC ERROR: -dm_mat_type seqaijcusp
>>>>>>>> [0]PETSC ERROR: -dm_vec_type seqcuda
>>>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>>>> with errorcode 86.
>>>>>>>> On Wed, Mar 14, 2018 at 11:16 AM, Matthew Knepley <
>>>>>>>>> On Thu, Mar 15, 2018 at 3:12 AM, Manuel Valera <
>>>>>>>>>> Thanks, got this error:
>>>>>>>>> Did you not configure with CUSP? It looks like you have CUDA, so
>>>>>>>>> use
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>>> [valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
>>>>>>>>>> [valera at node50 tutorials]$ PETSC_ARCH="" make ex19
>>>>>>>>>> /usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
>>>>>>>>>> -fvisibility=hidden -O2 -I/home/valera/testpetsc/include
>>>>>>>>>> -I/home/valera/testpetsc/arch-linux2-c-opt/include
>>>>>>>>>> -I/usr/local/cuda/include -I/usr/lib64/openmpi/include `pwd`/ex19.c
>>>>>>>>>> /usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings
>>>>>>>>>> -fvisibility=hidden -O2 -o ex19 ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
>>>>>>>>>> -L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64
>>>>>>>>>> -L/usr/local/cuda/lib64 -L/usr/lib64/openmpi/lib
>>>>>>>>>> -Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack
>>>>>>>>>> -lblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl
>>>>>>>>>> -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
>>>>>>>>>> -lquadmath -lpthread -lstdc++ -ldl
>>>>>>>>>> /usr/bin/rm -f ex19.o
>>>>>>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp
>>>>>>>>>> [0]PETSC ERROR: Unknown vector type: seqcusp
>>>>>>>>>> 11:12:11 2018
>>>>>>>>>> /home/valera/testpetsc/src/vec/vec/interface/vecreg.c
>>>>>>>>>> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
>>>>>>>>>> /home/valera/testpetsc/src/dm/impls/da/dadist.c
>>>>>>>>>> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
>>>>>>>>>> [0]PETSC ERROR: #4 main() line 158 in
>>>>>>>>>> /home/valera/testpetsc/src/snes/examples/tutorials/ex19.c
>>>>>>>>>> [0]PETSC ERROR: -dm_vec_type seqcusp
>>>>>>>>>> with errorcode 86.
>>>>>>>>>> processes.
>>>>>>>>>> On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <
>>>>>>>>>>> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <
>>>>>>>>>>>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>>>>>>>>>>>> -linux2-c-opt/tests/src/snes/examples/tutorials there is
>>>>>>>>>>>> runex19.sh and a lot of other ex19 variantes, but if i run that i get:
>>>>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$
>>>>>>>>>>> pushd src/snes/examples/tutorials/
>>>>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>>>>>>>>>>> PETSC_ARCH=arch-master-debug make ex19
>>>>>>>>>>> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Matt
>>>>>>>>>>>> [valera at node50 tutorials]$ ./runex19.sh
>>>>>>>>>>>> not ok snes_tutorials-ex19_1
>>>>>>>>>>>> # mpiexec was unable to launch the specified application as it
>>>>>>>>>>>> could not access
>>>>>>>>>>>> # or execute an executable:
>>>>>>>>>>>> # Executable: ../ex19
>>>>>>>>>>>> # Node: node50
>>>>>>>>>>>> # while attempting to start process rank 0.
>>>>>>>>>>>> # 2 total processes failed to start
>>>>>>>>>>>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>>>>>>>>>>>> is this the one i should be running ?
>>>>>>>>>>>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <
>>>>>>>>>>>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <
>>>>>>>>>>>>>> Ok thanks Matt, i made a smaller case with only the linear
>>>>>>>>>>>>>> solver and a 25x25 matrix, the error i have in this case is:
>>>>>>>>>>>>> Ah, it appears that not all parts of your problem are taking
>>>>>>>>>>>>> the type options. If you want the
>>>>>>>>>>>>> linear algebra objects to change type, you need to have
>>>>>>>>>>>>> VecSetFromOptions() and MatSetFromOptions()
>>>>>>>>>>>>> called after you create them, but before sizes are set and
>>>>>>>>>>>>> data is entered. However, it should
>>>>>>>>>>>>> not be possible to have a seq Vec with the seqcusp AXPY
>>>>>>>>>>>>> routine set. Something else is wrong...
>>>>>>>>>>>>> Did you try a PETSc example, such as SNES ex19, with this?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp
>>>>>>>>>>>>>> -mat_type aijcusparse
>>>>>>>>>>>>>> laplacian.petsc !
>>>>>>>>>>>>>> RHS loaded, size: 125 / 125
>>>>>>>>>>>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>>>>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>>>>>>>>>>>> v3.8.3-1817-g96b6f8a GIT Date: 2018-02-28 10:19:08 -0600
>>>>>>>>>>>>>> Wed Mar 14 10:24:35 2018
>>>>>>>>>>>>>> --with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3
>>>>>>>>>>>>>> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-shared-libraries=1
>>>>>>>>>>>>>> --with-debugging=1 --with-cuda=1 --with-cuda-arch=sm_60 --with-cusp=1
>>>>>>>>>>>>>> --with-cusp-dir=/home/valera/cusp --with-vienacl=1
>>>>>>>>>>>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>>>>>>>>>>>> [0]PETSC ERROR: Invalid argument
>>>>>>>>>>>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>>>>>>>>>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>>>>>>>>>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>>>>>>>>>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in
>>>>>>>>>>>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>>>>>>>>>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>>>>>>>>>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in
>>>>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>> soln maxval: 0.0000000000000000
>>>>>>>>>>>>>> soln minval: 0.0000000000000000
>>>>>>>>>>>>>> Norm: 11.180339887498949
>>>>>>>>>>>>>> Its: 0
>>>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>>>> Option left: name:-mat_type value: aijcusparse
>>>>>>>>>>>>>> I also see the configure options are not correct, so i guess
>>>>>>>>>>>>>> is still linking a different petsc installation, but maybe we can try to
>>>>>>>>>>>>>> make it work as it is, i will let you know if i am able to link the correct
>>>>>>>>>>>>>> petsc installation here,
>>>>>>>>>>>>>> Best,
>>>>>>>>>>>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <
>>>>>>>>>>>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <
>>>>>>>>>>>>>>>> Hello all,
>>>>>>>>>>>>>>>> I am working on porting a linear solver into GPUs for
>>>>>>>>>>>>>>>> timing purposes, so far i've been able to compile and run the CUSP
>>>>>>>>>>>>>>>> libraries and compile PETSc to be used with CUSP and ViennaCL, after the
>>>>>>>>>>>>>>>> initial runs i noticed some errors, they are different for different flags
>>>>>>>>>>>>>>>> and i would appreciate any help interpreting them,
>>>>>>>>>>>>>>>> The only elements in this program that use PETSc are the
>>>>>>>>>>>>>>>> laplacian matrix (sparse), the RHS and X vectors and a scatter petsc
>>>>>>>>>>>>>>>> object, so i would say it's safe to pass the command line arguments for the
>>>>>>>>>>>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>>>>>>>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>>>>>>>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>>>>>>>>>>>> These systems do not properly propagate errors. My only
>>>>>>>>>>>>>>> advice is to run a smaller problem and see.
>>>>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>>>>> and Apple Mac OS X to find memory corruption errors
>>>>>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack
>>>>>>>>>>>>>>>> below
>>>>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Stack Frames
>>>>>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack
>>>>>>>>>>>>>>>> are not available,
>>>>>>>>>>>>>>>> [0]PETSC ERROR: INSTEAD the line number of the start
>>>>>>>>>>>>>>>> of the function
>>>>>>>>>>>>>>>> [0]PETSC ERROR: is given.
>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetType line 36
>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>>>>>>>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by
>>>>>>>>>>>>>>>> valera Thu Mar 8 09:50:51 2018
>>>>>>>>>>>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in
>>>>>>>>>>>>>>>> unknown file
>>>>>>>>>>>>>>>> This seems to be a memory out of range, maybe my vector is
>>>>>>>>>>>>>>>> too big for my CUDA system? how do i assess that?
>>>>>>>>>>>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i
>>>>>>>>>>>>>>>> get something different and more interesting:
>>>>>>>>>>>>>>> We need to see the entire error message, since it has the
>>>>>>>>>>>>>>> stack.
>>>>>>>>>>>>>>> This seems like a logic error, but could definitely be on
>>>>>>>>>>>>>>> our end. Here is how I think about these:
>>>>>>>>>>>>>>> 1) We have nightly test solves, so at least some solver
>>>>>>>>>>>>>>> configuration works
>>>>>>>>>>>>>>> 2) Some vector which is marked read-only (happens for
>>>>>>>>>>>>>>> input to solvers), but someone is trying to update it.
>>>>>>>>>>>>>>> The stack will tell me where this is happening.
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>> [0]PETSC ERROR: Vec is locked read only, argument # 3
>>>>>>>>>>>>>>>> valera Thu Mar 8 10:02:19 2018
>>>>>>>>>>>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>>>>>>>>>>>> PETSC_SOLVER_ONLY 6.8672990892082453E-005 s
>>>>>>>>>>>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>>>>>>>>>>>>> veccusp2.cu
>>>>>>>>>>>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>>>>>>>>>>>> vecscattercusp.cu
>>>>>>>>>>>>>>>> And it yields a "solution" to the system and also a log at
>>>>>>>>>>>>>>>> the end:
>>>>>>>>>>>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by
>>>>>>>>>>>>>>>> valera Thu Mar 8 10:02:24 2018
>>>>>>>>>>>>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>>>>>>>>>>>>>>> Max Max/Min Avg
>>>>>>>>>>>>>>>> Total
>>>>>>>>>>>>>>>> Time (sec): 4.573e+00 1.00000 4.573e+00
>>>>>>>>>>>>>>>> Objects: 8.100e+01 1.00000 8.100e+01
>>>>>>>>>>>>>>>> Flop: 3.492e+07 1.00000 3.492e+07
>>>>>>>>>>>>>>>> 3.492e+07
>>>>>>>>>>>>>>>> Flop/sec: 7.637e+06 1.00000 7.637e+06
>>>>>>>>>>>>>>>> 7.637e+06
>>>>>>>>>>>>>>>> Memory: 2.157e+08 1.00000
>>>>>>>>>>>>>>>> 2.157e+08
>>>>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>>>>> of type (multiply/divide/add/subtract)
>>>>>>>>>>>>>>>> vectors of length N --> 2N flop
>>>>>>>>>>>>>>>> vectors of length N --> 8N flop
>>>>>>>>>>>>>>>> --- Messages --- -- Message Lengths -- -- Reductions --
>>>>>>>>>>>>>>>> counts %Total Avg %Total counts %Total
>>>>>>>>>>>>>>>> 0: Main Stage: 4.5729e+00 100.0% 3.4924e+07 100.0%
>>>>>>>>>>>>>>>> 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
>>>>>>>>>>>>>>>> details on interpreting output.
>>>>>>>>>>>>>>>> Phase summary info:
>>>>>>>>>>>>>>>> all processors
>>>>>>>>>>>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>>>>>>>>>>>> flop in this phase
>>>>>>>>>>>>>>>> message lengths in this phase
>>>>>>>>>>>>>>>> processors)/(max time over all processors)
>>>>>>>>>>>>>>>> # WARNING!!!
>>>>>>>>>>>>>>>> # This code was compiled with a debugging option,
>>>>>>>>>>>>>>>> # To get timing results run ./configure
>>>>>>>>>>>>>>>> # using --with-debugging=no, the performance will
>>>>>>>>>>>>>>>> # be generally two or three times faster.
>>>>>>>>>>>>>>>> Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>>>>>>>>>>>>>>>> MatLUFactorNum 1 1.0 4.9502e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 1100 0 0 0 1100 0 0 0 706
>>>>>>>>>>>>>>>> MatILUFactorSym 1 1.0 1.9642e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>>>>>>>>>>>>> MatAssemblyBegin 2 1.0 6.9141e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> MatAssemblyEnd 2 1.0 2.6612e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 6 0 0 0 0 6 0 0 0 0 0
>>>>>>>>>>>>>>>> MatGetRowIJ 1 1.0 5.0068e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> MatGetOrdering 1 1.0 1.7186e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> MatLoad 1 1.0 1.1575e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
>>>>>>>>>>>>>>>> MatView 1 1.0 8.0877e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
>>>>>>>>>>>>>>>> MatCUSPCopyTo 1 1.0 2.4664e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 5 0 0 0 0 5 0 0 0 0 0
>>>>>>>>>>>>>>>> VecSet 68 1.0 5.1665e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>>>>>>>>>>>>> VecAssemblyBegin 17 1.0 5.2691e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> VecAssemblyEnd 17 1.0 4.3631e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> VecScatterBegin 15 1.0 1.5345e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> VecCUSPCopyFrom 1 1.0 1.1199e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> KSPSetUp 1 1.0 5.1929e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>> PCSetUp 2 1.0 8.6590e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 2100 0 0 0 2100 0 0 0 403
>>>>>>>>>>>>>>>> Descendants' Mem.
>>>>>>>>>>>>>>>> Matrix 3 1 52856972
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> Matrix Null Space 1 1 608
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> Vector 66 3 3414600
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> Vector Scatter 1 1 680
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> Viewer 3 2 1680
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> Krylov Solver 1 0 0
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> Preconditioner 2 1 864
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> Index Set 4 1 800
>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>>>>>> -log_view
>>>>>>>>>>>>>>>> -vec_type cusp
>>>>>>>>>>>>>>>> 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>>>>>>>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc
>>>>>>>>>>>>>>>> Libraries compiled on Mon Mar 5 16:37:18 2018 on node50
>>>>>>>>>>>>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>>>>>>>>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>>>>>>>>>>>> Using PETSc arch: cuda
>>>>>>>>>>>>>>>> Using C compiler: mpicc -fPIC -Wall -Wwrite-strings
>>>>>>>>>>>>>>>> -fvisibility=hidden -O3
>>>>>>>>>>>>>>>> Using Fortran compiler: mpifort -fPIC -Wall
>>>>>>>>>>>>>>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>>>>>>>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>>>>>>>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>>>>>>>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>>>>>>>>>>>> Using C linker: mpicc
>>>>>>>>>>>>>>>> Using Fortran linker: mpifort
>>>>>>>>>>>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>>>>>>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>>>>>>>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>>>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack
>>>>>>>>>>>>>>>> -lfblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl
>>>>>>>>>>>>>>>> Thanks for your help,
>>>>>>>>>>>>>>>> Manuel
>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/ff3dcbf3/attachment-0001.html>
