[petsc-users] Tweaking my code for CUDA
Wed Mar 14 18:23:35 CDT 2018
On Thu, Mar 15, 2018 at 8:18 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
wrote:
> Ok so, i went back and erased the old libpetsc.so.3 i think it was the one
> causing problems, i had --with-shared-libraries=0 and the installation
> complained of not having that file, then reinstalled with
> --with-shared-libraries=1 and it is finally recognizing my system
> installation with only CUDA, but now it gives a 11 SEGV violation error:
But ex19 runs?
And this crash is without CUDA? Just run valgrind on it
   Matt
> [valera at node50 alone]$ ./linsolve
>  laplacian.petsc !
>  TrivSoln loaded, size:          125 /         125
> [0]PETSC ERROR: ------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab  GIT
> Date: 2018-03-12 13:30:25 -0500
> [0]PETSC ERROR: ./linsolve on a  named node50 by valera Wed Mar 14
> 16:17:34 2018
> [0]PETSC ERROR: Configure options --prefix=/usr/local/petsc.cod/petsc-install
> --with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=1
> --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> Thanks,
> On Wed, Mar 14, 2018 at 1:52 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Mar 15, 2018 at 4:01 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>> wrote:
>>> Ok well, it turns out the $PETSC_DIR points to the testpetsc directory,
>>> and it makes, install and tests without problems (only a problem on ex5f)
>>> but trying to reconfigure on valera/petsc directory asks me to change the
>>> $PETSC_DIR variable,
>> Yes, you must set PETSC_DIR to point to the installation you want to use.
>>   Matt
>>> Meanwhile the system installation still points to the valera/petsc/cuda
>>> build,
>>> should i just delete the petsc installation folder and start over?
>>> Thanks,
>>> On Wed, Mar 14, 2018 at 11:36 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Mar 15, 2018 at 3:25 AM, Manuel Valera <mvalera-w at mail.sdsu.edu
>>>> > wrote:
>>>>> yeah that worked,
>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcuda -dm_mat_type
>>>>> seqaijcusparse
>>>>> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
>>>>> Number of SNES iterations = 2
>>>>> How do i make sure the other program refer to this installation? using
>>>>> the same arguments there i get:
>>>>> [valera at node50 alone]$ ./linsolve -vec_type seqcuda -mat_type
>>>>> seqaijcusparse
>>>>>  laplacian.petsc !
>>>>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>>>>> package: http://www.mcs.anl.gov/petsc/documentation/installation.html
>>>>> #external
>>>>> [0]PETSC ERROR: Unknown vector type: seqcuda
>>>> This PETSc has not been configured with CUDA. It is located in /home/valera/petsc.
>>>> The other
>>>> one you used is located in  /home/valera/testpetsc. It does not make
>>>> much sense to me that
>>>> it does not understand CUDA since it says the configure arguments had
>>>> --with-cuda=1. There
>>>> must have been a build problem. Rebuild
>>>>   cd $PETSC_DIR
>>>>   make all
>>>> If you still have a problem, reconfigure
>>>>   cd $PETSC_DIR
>>>>   ./cuda/lib/petsc/conf/reconfigure-cuda.py
>>>>   make all
>>>> If that still fails, then something very bizarre is happening on your
>>>> machine and we will have
>>>> to exchange more mail.
>>>>   Matt
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>>>> GIT Date: 2018-02-28 10:19:08 -0600
>>>>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
>>>>> 11:25:11 2018
>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>>>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>>>>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>>>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>>>>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>>>>> [0]PETSC ERROR: #1 VecSetType() line 42 in
>>>>> /home/valera/petsc/src/vec/vec/interface/vecreg.c
>>>>> [0]PETSC ERROR: #2 VecSetTypeFromOptions_Private() line 1241 in
>>>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>>>> [0]PETSC ERROR: #3 VecSetFromOptions() line 1276 in
>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>> [0]PETSC ERROR: Vec object's type is not set: Argument # 1
>>>>> 11:25:11 2018
>>>>> [0]PETSC ERROR: #4 VecDuplicate() line 375 in
>>>>> 11:25:11 2018
>>>>> [0]PETSC ERROR: #5 VecDuplicate() line 375 in
>>>>> [0]PETSC ERROR: #6 User provided function() line 0 in User file
>>>>> I made sure there is a call for Vec/MatSetFromOptions() there, i am
>>>>> loading the matrix from a petsc binary in this case,
>>>>> Thanks,
>>>>> On Wed, Mar 14, 2018 at 11:22 AM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Mar 15, 2018 at 3:19 AM, Manuel Valera <
>>>>>> mvalera-w at mail.sdsu.edu> wrote:
>>>>>>> Yes, this is the system installation that is being correctly linked
>>>>>>> (the linear solver and model are not linking the correct installation idk
>>>>>>> why yet) i configured with only CUDA this time because of the message Karl
>>>>>>> Rupp posted on my installation thread, where he says only one type of
>>>>>>> library will work at a time, anyway this is what i got:
>>>>>>> seqaijcusp
>>>>>>> ocumentation/installation.html#external
>>>>>>> [0]PETSC ERROR: Unknown Mat type given: seqaijcusp
>>>>>> It is telling you the problem. Use
>>>>>>   -dm_mat_type seqaijcusparse
>>>>>>    Matt
>>>>>>> v3.8.3-2027-g045eeab  GIT Date: 2018-03-12 13:30:25 -0500
>>>>>>> [0]PETSC ERROR: ./ex19 on a  named node50 by valera Wed Mar 14
>>>>>>> 11:17:25 2018
>>>>>>> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
>>>>>>> --download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
>>>>>>> [0]PETSC ERROR: #1 MatSetType() line 61 in
>>>>>>> /home/valera/testpetsc/src/mat/interface/matreg.c
>>>>>>> [0]PETSC ERROR: #2 DMCreateMatrix_DA() line 693 in
>>>>>>> /home/valera/testpetsc/src/dm/impls/da/fdda.c
>>>>>>> [0]PETSC ERROR: #3 DMCreateMatrix() line 1199 in
>>>>>>> /home/valera/testpetsc/src/dm/interface/dm.c
>>>>>>> [0]PETSC ERROR: #4 SNESSetUpMatrices() line 646 in
>>>>>>> /home/valera/testpetsc/src/snes/interface/snes.c
>>>>>>> [0]PETSC ERROR: #5 SNESSetUp_NEWTONLS() line 296 in
>>>>>>> /home/valera/testpetsc/src/snes/impls/ls/ls.c
>>>>>>> [0]PETSC ERROR: #6 SNESSetUp() line 2795 in
>>>>>>> [0]PETSC ERROR: #7 SNESSolve() line 4187 in
>>>>>>> [0]PETSC ERROR: #8 main() line 161 in /home/valera/testpetsc/src/sne
>>>>>>> s/examples/tutorials/ex19.c
>>>>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>>>>> [0]PETSC ERROR: -dm_mat_type seqaijcusp
>>>>>>> [0]PETSC ERROR: -dm_vec_type seqcuda
>>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>>> with errorcode 86.
>>>>>>> On Wed, Mar 14, 2018 at 11:16 AM, Matthew Knepley <knepley at gmail.com
>>>>>>> > wrote:
>>>>>>>> On Thu, Mar 15, 2018 at 3:12 AM, Manuel Valera <
>>>>>>>>> Thanks, got this error:
>>>>>>>> Did you not configure with CUSP? It looks like you have CUDA, so use
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>>> [valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
>>>>>>>>> [valera at node50 tutorials]$ PETSC_ARCH="" make ex19
>>>>>>>>> /usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
>>>>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>>>>>> -fvisibility=hidden -O2   -I/home/valera/testpetsc/include
>>>>>>>>> -I/home/valera/testpetsc/arch-linux2-c-opt/include
>>>>>>>>> -I/usr/local/petsc.cod/petsc-install/include
>>>>>>>>> -I/usr/local/cuda/include -I/usr/lib64/openmpi/include    `pwd`/ex19.c
>>>>>>>>> /usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings
>>>>>>>>> -fvisibility=hidden -O2  -o ex19  ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
>>>>>>>>> -Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
>>>>>>>>> -L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64
>>>>>>>>> -L/usr/lib64 -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>>>> -L/usr/local/cuda/lib64 -L/usr/lib64/openmpi/lib
>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>>>> -Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack -lblas
>>>>>>>>> -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>>>>>>> -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>>>>>>>>> -lpthread -lstdc++ -ldl
>>>>>>>>> /usr/bin/rm -f ex19.o
>>>>>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp
>>>>>>>>> [0]PETSC ERROR: Unknown vector type: seqcusp
>>>>>>>>> 11:12:11 2018
>>>>>>>>> /home/valera/testpetsc/src/vec/vec/interface/vecreg.c
>>>>>>>>> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
>>>>>>>>> /home/valera/testpetsc/src/dm/impls/da/dadist.c
>>>>>>>>> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
>>>>>>>>> [0]PETSC ERROR: #4 main() line 158 in
>>>>>>>>> /home/valera/testpetsc/src/snes/examples/tutorials/ex19.c
>>>>>>>>> [0]PETSC ERROR: -dm_vec_type seqcusp
>>>>>>>>> with errorcode 86.
>>>>>>>>> On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <
>>>>>>>>>>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>>>>>>>>>>> -linux2-c-opt/tests/src/snes/examples/tutorials there is
>>>>>>>>>>> runex19.sh and a lot of other ex19 variantes, but if i run that i get:
>>>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$
>>>>>>>>>> pushd src/snes/examples/tutorials/
>>>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>>>>>>>>>> PETSC_ARCH=arch-master-debug make ex19
>>>>>>>>>> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> [valera at node50 tutorials]$ ./runex19.sh
>>>>>>>>>>> not ok snes_tutorials-ex19_1
>>>>>>>>>>> # mpiexec was unable to launch the specified application as it
>>>>>>>>>>> could not access
>>>>>>>>>>> # or execute an executable:
>>>>>>>>>>> # Executable: ../ex19
>>>>>>>>>>> # Node: node50
>>>>>>>>>>> # while attempting to start process rank 0.
>>>>>>>>>>> # 2 total processes failed to start
>>>>>>>>>>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>>>>>>>>>>> is this the one i should be running ?
>>>>>>>>>>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <
>>>>>>>>>>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <
>>>>>>>>>>>>> Ok thanks Matt, i made a smaller case with only the linear
>>>>>>>>>>>>> solver and a 25x25 matrix, the error i have in this case is:
>>>>>>>>>>>> Ah, it appears that not all parts of your problem are taking
>>>>>>>>>>>> the type options. If you want the
>>>>>>>>>>>> linear algebra objects to change type, you need to have
>>>>>>>>>>>>   VecSetFromOptions()  and MatSetFromOptions()
>>>>>>>>>>>> called after you create them, but before sizes are set and data
>>>>>>>>>>>> is entered. However, it should
>>>>>>>>>>>> not be possible to have a seq Vec with the seqcusp AXPY routine
>>>>>>>>>>>> set. Something else is wrong...
>>>>>>>>>>>> Did you try a PETSc example, such as SNES ex19, with this?
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>     Matt
>>>>>>>>>>>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp
>>>>>>>>>>>>> -mat_type aijcusparse
>>>>>>>>>>>>>  laplacian.petsc !
>>>>>>>>>>>>>  RHS loaded, size:          125 /         125
>>>>>>>>>>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>>>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>>>>>>>>>>> v3.8.3-1817-g96b6f8a  GIT Date: 2018-02-28 10:19:08 -0600
>>>>>>>>>>>>> Wed Mar 14 10:24:35 2018
>>>>>>>>>>>>> --with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3
>>>>>>>>>>>>> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-shared-libraries=1
>>>>>>>>>>>>> --with-debugging=1 --with-cuda=1 --with-cuda-arch=sm_60 --with-cusp=1
>>>>>>>>>>>>> --with-cusp-dir=/home/valera/cusp --with-vienacl=1
>>>>>>>>>>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>>>>>>>>>>> [0]PETSC ERROR: Invalid argument
>>>>>>>>>>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>>>>>>>>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>>>>>>>>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>>>>>>>>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in
>>>>>>>>>>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>>>>>>>>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>>>>>>>>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in
>>>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>  soln maxval:   0.0000000000000000
>>>>>>>>>>>>>  soln minval:   0.0000000000000000
>>>>>>>>>>>>>  Norm:   11.180339887498949
>>>>>>>>>>>>>  Its:           0
>>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>>> Option left: name:-mat_type value: aijcusparse
>>>>>>>>>>>>> I also see the configure options are not correct, so i guess
>>>>>>>>>>>>> is still linking a different petsc installation, but maybe we can try to
>>>>>>>>>>>>> make it work as it is, i will let you know if i am able to link the correct
>>>>>>>>>>>>> petsc installation here,
>>>>>>>>>>>>> Best,
>>>>>>>>>>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <
>>>>>>>>>>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <
>>>>>>>>>>>>>>> Hello all,
>>>>>>>>>>>>>>> I am working on porting a linear solver into GPUs for timing
>>>>>>>>>>>>>>> purposes, so far i've been able to compile and run the CUSP libraries and
>>>>>>>>>>>>>>> compile PETSc to be used with CUSP and ViennaCL, after the initial runs i
>>>>>>>>>>>>>>> noticed some errors, they are different for different flags and i would
>>>>>>>>>>>>>>> appreciate any help interpreting them,
>>>>>>>>>>>>>>> The only elements in this program that use PETSc are the
>>>>>>>>>>>>>>> laplacian matrix (sparse), the RHS and X vectors and a scatter petsc
>>>>>>>>>>>>>>> object, so i would say it's safe to pass the command line arguments for the
>>>>>>>>>>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>>>>>>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>>>>>>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>>>>>>>>>>> These systems do not properly propagate errors. My only
>>>>>>>>>>>>>> advice is to run a smaller problem and see.
>>>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>>>> Apple Mac OS X to find memory corruption errors
>>>>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack
>>>>>>>>>>>>>>> below
>>>>>>>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack
>>>>>>>>>>>>>>> are not available,
>>>>>>>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start
>>>>>>>>>>>>>>> of the function
>>>>>>>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetType line 36
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>>>>>>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by
>>>>>>>>>>>>>>> valera Thu Mar  8 09:50:51 2018
>>>>>>>>>>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in
>>>>>>>>>>>>>>> unknown file
>>>>>>>>>>>>>>> This seems to be a memory out of range, maybe my vector is
>>>>>>>>>>>>>>> too big for my CUDA system? how do i assess that?
>>>>>>>>>>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get
>>>>>>>>>>>>>>> something different and more interesting:
>>>>>>>>>>>>>> We need to see the entire error message, since it has the
>>>>>>>>>>>>>> stack.
>>>>>>>>>>>>>> This seems like a logic error, but could definitely be on our
>>>>>>>>>>>>>> end. Here is how I think about these:
>>>>>>>>>>>>>>   1) We have nightly test solves, so at least some solver
>>>>>>>>>>>>>> configuration works
>>>>>>>>>>>>>>   2) Some vector which is marked read-only (happens for input
>>>>>>>>>>>>>> to solvers), but someone is trying to update it.
>>>>>>>>>>>>>>       The stack will tell me where this is happening.
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>> [0]PETSC ERROR:  Vec is locked read only, argument # 3
>>>>>>>>>>>>>>> valera Thu Mar  8 10:02:19 2018
>>>>>>>>>>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>>>>>>>>>>>  PETSC_SOLVER_ONLY   6.8672990892082453E-005 s
>>>>>>>>>>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>>>>>>>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscatterc
>>>>>>>>>>>>>>> usp.cu
>>>>>>>>>>>>>>> And it yields a "solution" to the system and also a log at
>>>>>>>>>>>>>>> the end:
>>>>>>>>>>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by
>>>>>>>>>>>>>>> valera Thu Mar  8 10:02:24 2018
>>>>>>>>>>>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>>>>>>>>>>>>>>                          Max       Max/Min        Avg
>>>>>>>>>>>>>>> Total
>>>>>>>>>>>>>>> Time (sec):           4.573e+00      1.00000   4.573e+00
>>>>>>>>>>>>>>> Objects:              8.100e+01      1.00000   8.100e+01
>>>>>>>>>>>>>>> Flop:                 3.492e+07      1.00000   3.492e+07
>>>>>>>>>>>>>>> 3.492e+07
>>>>>>>>>>>>>>> Flop/sec:            7.637e+06      1.00000   7.637e+06
>>>>>>>>>>>>>>> 7.637e+06
>>>>>>>>>>>>>>> Memory:               2.157e+08      1.00000
>>>>>>>>>>>>>>> 2.157e+08
>>>>>>>>>>>>>>> MPI Messages:         0.000e+00      0.00000   0.000e+00
>>>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>>>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00
>>>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>>>> MPI Reductions:       0.000e+00      0.00000
>>>>>>>>>>>>>>> Flop counting convention: 1 flop = 1 real number operation
>>>>>>>>>>>>>>> of type (multiply/divide/add/subtract)
>>>>>>>>>>>>>>>                             e.g., VecAXPY() for real vectors
>>>>>>>>>>>>>>> of length N --> 2N flop
>>>>>>>>>>>>>>>                             and VecAXPY() for complex
>>>>>>>>>>>>>>> vectors of length N --> 8N flop
>>>>>>>>>>>>>>> Summary of Stages:   ----- Time ------  ----- Flop -----
>>>>>>>>>>>>>>> --- Messages ---  -- Message Lengths --  -- Reductions --
>>>>>>>>>>>>>>>                         Avg     %Total     Avg     %Total
>>>>>>>>>>>>>>>  counts   %Total     Avg         %Total   counts   %Total
>>>>>>>>>>>>>>>  0:      Main Stage: 4.5729e+00 100.0%  3.4924e+07 100.0%
>>>>>>>>>>>>>>> 0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>>>>>>>>>>>>>>> See the 'Profiling' chapter of the users' manual for details
>>>>>>>>>>>>>>> on interpreting output.
>>>>>>>>>>>>>>> Phase summary info:
>>>>>>>>>>>>>>>    Count: number of times phase was executed
>>>>>>>>>>>>>>>    Time and Flop: Max - maximum over all processors
>>>>>>>>>>>>>>>                    Ratio - ratio of maximum to minimum over
>>>>>>>>>>>>>>> all processors
>>>>>>>>>>>>>>>    Mess: number of messages sent
>>>>>>>>>>>>>>>    Avg. len: average message length (bytes)
>>>>>>>>>>>>>>>    Reduct: number of global reductions
>>>>>>>>>>>>>>>    Global: entire computation
>>>>>>>>>>>>>>>    Stage: stages of a computation. Set stages with
>>>>>>>>>>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>>>>>>>>>>>       %T - percent time in this phase         %F - percent
>>>>>>>>>>>>>>> flop in this phase
>>>>>>>>>>>>>>>       %M - percent messages in this phase     %L - percent
>>>>>>>>>>>>>>> message lengths in this phase
>>>>>>>>>>>>>>>       %R - percent reductions in this phase
>>>>>>>>>>>>>>>    Total Mflop/s: 10e-6 * (sum of flop over all
>>>>>>>>>>>>>>> processors)/(max time over all processors)
>>>>>>>>>>>>>>>       #                          WARNING!!!
>>>>>>>>>>>>>>>       #   This code was compiled with a debugging option,
>>>>>>>>>>>>>>>       #   To get timing results run ./configure
>>>>>>>>>>>>>>>       #   using --with-debugging=no, the performance will
>>>>>>>>>>>>>>>       #   be generally two or three times faster.
>>>>>>>>>>>>>>> Event                Count      Time (sec)     Flop
>>>>>>>>>>>>>>>                    --- Global ---  --- Stage ---   Total
>>>>>>>>>>>>>>>                    Max Ratio  Max     Ratio   Max  Ratio
>>>>>>>>>>>>>>> Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>>>>>>>>>>>>> --- Event Stage 0: Main Stage
>>>>>>>>>>>>>>> MatLUFactorNum         1 1.0 4.9502e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  1100  0  0  0   1100  0  0  0   706
>>>>>>>>>>>>>>> MatILUFactorSym        1 1.0 1.9642e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>>>>>>>>>>>> MatAssemblyBegin       2 1.0 6.9141e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> MatAssemblyEnd         2 1.0 2.6612e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
>>>>>>>>>>>>>>> MatGetRowIJ            1 1.0 5.0068e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> MatGetOrdering         1 1.0 1.7186e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> MatLoad                1 1.0 1.1575e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>>>>>>>>>>>>>>> MatView                1 1.0 8.0877e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>>>>>>>>>>>>> MatCUSPCopyTo          1 1.0 2.4664e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
>>>>>>>>>>>>>>> VecSet                68 1.0 5.1665e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>>>>>>>>>>>>>>> VecAssemblyBegin      17 1.0 5.2691e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> VecAssemblyEnd        17 1.0 4.3631e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> VecScatterBegin       15 1.0 1.5345e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> VecCUSPCopyFrom        1 1.0 1.1199e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> KSPSetUp               1 1.0 5.1929e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>> PCSetUp                2 1.0 8.6590e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  2100  0  0  0   2100  0  0  0   403
>>>>>>>>>>>>>>> Memory usage is given in bytes:
>>>>>>>>>>>>>>> Object Type          Creations   Destructions     Memory
>>>>>>>>>>>>>>> Descendants' Mem.
>>>>>>>>>>>>>>> Reports information only for process 0.
>>>>>>>>>>>>>>>               Matrix     3              1     52856972     0.
>>>>>>>>>>>>>>>    Matrix Null Space     1              1          608     0.
>>>>>>>>>>>>>>>               Vector    66              3      3414600     0.
>>>>>>>>>>>>>>>       Vector Scatter     1              1          680     0.
>>>>>>>>>>>>>>>               Viewer     3              2         1680     0.
>>>>>>>>>>>>>>>        Krylov Solver     1              0            0     0.
>>>>>>>>>>>>>>>       Preconditioner     2              1          864     0.
>>>>>>>>>>>>>>>            Index Set     4              1          800     0.
>>>>>>>>>>>>>>> Average time to get PetscTime(): 9.53674e-08
>>>>>>>>>>>>>>> #PETSc Option Table entries:
>>>>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>>>>> -log_view
>>>>>>>>>>>>>>> -matload_block_size 1
>>>>>>>>>>>>>>> -vec_type cusp
>>>>>>>>>>>>>>> #End of PETSc Option Table entries
>>>>>>>>>>>>>>> Compiled without FORTRAN kernels
>>>>>>>>>>>>>>> Compiled with full precision matrices (default)
>>>>>>>>>>>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>>>>>>>>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>>>>>>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc
>>>>>>>>>>>>>>> Libraries compiled on Mon Mar  5 16:37:18 2018 on node50
>>>>>>>>>>>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>>>>>>>>>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>>>>>>>>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>>>>>>>>>>> Using PETSc arch: cuda
>>>>>>>>>>>>>>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
>>>>>>>>>>>>>>> -fvisibility=hidden -O3
>>>>>>>>>>>>>>> Using Fortran compiler: mpifort  -fPIC -Wall
>>>>>>>>>>>>>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>>>>>>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>>>>>>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>>>>>>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>>>>>>>>>>> Using C linker: mpicc
>>>>>>>>>>>>>>> Using Fortran linker: mpifort
>>>>>>>>>>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>>>>>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>>>>>>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack
>>>>>>>>>>>>>>> -lfblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl
>>>>>>>>>>>>>>> -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
>>>>>>>>>>>>>>> -lquadmath -lpthread -lstdc++ -ldl
>>>>>>>>>>>>>>> Thanks for your help,
>>>>>>>>>>>>>>> Manuel
>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/7d4aed39/attachment-0001.html>
