[petsc-users] Tweaking my code for CUDA
Matthew Knepley
knepley at gmail.com
Thu Mar 15 18:26:03 CDT 2018
On Thu, Mar 15, 2018 at 5:06 PM, Manuel Valera <mvalera-w at mail.sdsu.edu>
wrote:
> Ok Matthew and everyone, i finally made my small example work, im sending
> the ksp_view and log_view for feedback / check up if it seems correct.
It looks fine. Of course the time is dominated by kernel launch latency
since its small.
> What i would like to do next is explore how fast this setup solves my
> linear systems, for it i could fire up the whole big model or i could
> extract the binaries and solve with this standalone, i know how do extract
> a matrix binary, is there an analog for a vector?
I do not see the advantage in involving disk.
Matt
> i would like to test my system for scaling and then look at multi-node
> scaling as well as multi-gpu, any ideas would be welcome,
> Thanks,
> .-.-.-.-.-.- ksp_view and log_view .-.-.-.-.-.-
> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type seqcuda
> -mat_type seqaijcusparse -ksp_view -log_view
> laplacian.petsc !
> TrivSoln loaded, size: 125 / 125
> KSP Object: 1 MPI processes
> type: gcr
> restart = 30
> restarts performed = 1
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-11, absolute=1e-50, divergence=10000.
> right preconditioning
> using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
> type: ilu
> out-of-place factorization
> 0 levels of fill
> tolerance for zero pivot 2.22045e-14
> matrix ordering: natural
> factor fill ratio given 1., needed 1.
> Factored matrix follows:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=125, cols=125
> package used to perform factorization: petsc
> total: nonzeros=1685, allocated nonzeros=1685
> total number of mallocs used during MatSetValues calls =0
> not using I-node routines
> linear system matrix = precond matrix:
> type: seqaijcusparse
> rows=125, cols=125
> soln maxval: 1.0000000000007194
> soln minval: 0.99999999999484046
> Norm: 1.3586823299239453E-011
> Its: 4
> *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r
> -fCourier9' to print this document ***
> ---------------------------------------------- PETSc Performance Summary:
> ./linsolve on a named node50 with 1 processor, by valera Thu Mar 15
> 14:04:47 2018
> Using Petsc Development GIT revision: v3.8.3-2027-g045eeab GIT Date:
> 2018-03-12 13:30:25 -0500
> Max Max/Min Avg Total
> Time (sec): 7.459e-01 1.00000 7.459e-01
> Objects: 7.500e+01 1.00000 7.500e+01
> Flop: 6.024e+04 1.00000 6.024e+04 6.024e+04
> Flop/sec: 8.076e+04 1.00000 8.076e+04 8.076e+04
> MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
> MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
> MPI Reductions: 0.000e+00 0.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> e.g., VecAXPY() for real vectors of length N
> --> 2N flop
> and VecAXPY() for complex vectors of length N
> --> 8N flop
> Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages
> --- -- Message Lengths -- -- Reductions --
> Avg %Total Avg %Total counts
> %Total Avg %Total counts %Total
> 0: Main Stage: 7.4589e-01 100.0% 6.0240e+04 100.0% 0.000e+00
> 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
> Count: number of times phase was executed
> Time and Flop: Max - maximum over all processors
> Ratio - ratio of maximum to minimum over all processors
> Mess: number of messages sent
> Avg. len: average message length (bytes)
> Reduct: number of global reductions
> Global: entire computation
> Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
> %T - percent time in this phase %F - percent flop in this
> phase
> %M - percent messages in this phase %L - percent message lengths
> in this phase
> %R - percent reductions in this phase
> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over
> all processors)
> Event Count Time (sec) Flop
> --- Global --- --- Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> VecDotNorm2 4 1.0 2.0170e-04 1.0 3.99e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 7 0 0 0 0 7 0 0 0 20
> VecMDot 3 1.0 1.4329e-04 1.0 1.49e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 2 0 0 0 0 2 0 0 0 10
> VecNorm 6 1.0 3.7265e-04 1.0 1.49e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 2 0 0 0 0 2 0 0 0 4
> VecScale 8 1.0 6.8903e-05 1.0 1.00e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 2 0 0 0 0 2 0 0 0 15
> VecSet 74 1.0 6.0844e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecAXPY 9 1.0 9.3699e-05 1.0 2.25e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 4 0 0 0 0 4 0 0 0 24
> VecAYPX 1 1.0 2.8685e-01 1.0 2.50e+02 1.0 0.0e+00 0.0e+00
> 0.0e+00 38 0 0 0 0 38 0 0 0 0 0
> VecMAXPY 6 1.0 1.2016e-04 1.0 6.00e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 10 0 0 0 0 10 0 0 0 50
> VecAssemblyBegin 3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd 3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecCUDACopyTo 5 1.0 2.8849e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecCUDACopyFrom 9 1.0 9.7275e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMult 6 1.0 3.6573e-04 1.0 1.95e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 32 0 0 0 0 32 0 0 0 53
> MatSolve 4 1.0 1.1349e-04 1.0 1.30e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 22 0 0 0 0 22 0 0 0 114
> MatLUFactorNum 1 1.0 2.9087e-05 1.0 1.13e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 19 0 0 0 0 19 0 0 0 389
> MatILUFactorSym 1 1.0 2.7180e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyBegin 1 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd 1 1.0 4.5514e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetRowIJ 1 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering 1 1.0 8.5831e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatLoad 1 1.0 2.4009e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatView 2 1.0 1.6499e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatCUSPARSECopyTo 2 1.0 4.4584e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCSetUp 1 1.0 1.8096e-04 1.0 1.13e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 19 0 0 0 0 19 0 0 0 63
> PCApply 4 1.0 1.1659e-04 1.0 1.30e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 22 0 0 0 0 22 0 0 0 111
> KSPSetUp 1 1.0 2.2879e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve 1 1.0 2.8820e-01 1.0 4.52e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00 39 75 0 0 0 39 75 0 0 0 0
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants' Mem.
> Reports information only for process 0.
> Vector 64 63 104280 0.
> Matrix 2 2 51368 0.
> Viewer 3 1 848 0.
> Preconditioner 2 1 1016 0.
> Krylov Solver 1 1 1248 0.
> Index Set 3 3 3900 0.
> Average time to get PetscTime(): 9.53674e-08
> #PETSc Option Table entries:
> -ksp_view
> -log_view
> -matload_block_size 1
> -vec_type seqcuda
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: --prefix=/usr/local/petsc.cod/petsc-install
> --with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=1
> --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
> Libraries compiled on Wed Mar 14 14:53:02 2018 on node50
> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
> 64-x86_64-with-centos-7.2.1511-Core
> Using PETSc directory: /usr/local/petsc.cod/petsc-install
> Using PETSc arch:
> Using C compiler: /usr/lib64/openmpi/bin/mpicc -fPIC -Wall
> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
> -fvisibility=hidden -O2
> Using Fortran compiler: /usr/lib64/openmpi/bin/mpif90 -fPIC -Wall
> -ffree-line-length-0 -Wno-unused-dummy-argument -O2
> Using include paths: -I/usr/local/petsc.cod/petsc-install/include
> -I/usr/local/petsc.cod/petsc-install//include -I/usr/local/cuda/include
> -I/usr/lib64/openmpi/include
> Using C linker: /usr/lib64/openmpi/bin/mpicc
> Using Fortran linker: /usr/lib64/openmpi/bin/mpif90
> Using libraries: -Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
> -L/usr/local/petsc.cod/petsc-install/lib -lpetsc -Wl,-rpath,/usr/lib64
> -L/usr/lib64 -Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64
> -Wl,-rpath,/usr/lib64/openmpi/lib -L/usr/lib64/openmpi/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -llapack -lblas -lm -lcufft
> -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi -lmpi_mpifh
> -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lstdc++
> -ldl
> On Wed, Mar 14, 2018 at 4:23 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Mar 15, 2018 at 8:18 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>> wrote:
>>> Ok so, i went back and erased the old libpetsc.so.3 i think it was the
>>> one causing problems, i had --with-shared-libraries=0 and the installation
>>> complained of not having that file, then reinstalled with
>>> --with-shared-libraries=1 and it is finally recognizing my system
>>> installation with only CUDA, but now it gives a 11 SEGV violation error:
>> But ex19 runs?
>> And this crash is without CUDA? Just run valgrind on it
>> Matt
>>> [valera at node50 alone]$ ./linsolve
>>> laplacian.petsc !
>>> [0]PETSC ERROR: ------------------------------
>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>> probably memory access out of range
>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>> -on_error_attach_debugger
>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>> ocumentation/faq.html#valgrind
>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>> OS X to find memory corruption errors
>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>>> and run
>>> [0]PETSC ERROR: to get more information on the crash.
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Signal received
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab
>>> GIT Date: 2018-03-12 13:30:25 -0500
>>> [0]PETSC ERROR: ./linsolve on a named node50 by valera Wed Mar 14
>>> 16:17:34 2018
>>> [0]PETSC ERROR: Configure options --prefix=/usr/local/petsc.cod/petsc-install
>>> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>> with errorcode 59.
>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> You may or may not see output from other processes, depending on
>>> exactly when Open MPI kills them.
>>> Thanks,
>>> On Wed, Mar 14, 2018 at 1:52 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Mar 15, 2018 at 4:01 AM, Manuel Valera <mvalera-w at mail.sdsu.edu
>>>> > wrote:
>>>>> Ok well, it turns out the $PETSC_DIR points to the testpetsc
>>>>> directory, and it makes, install and tests without problems (only a problem
>>>>> on ex5f) but trying to reconfigure on valera/petsc directory asks me to
>>>>> change the $PETSC_DIR variable,
>>>> Yes, you must set PETSC_DIR to point to the installation you want to
>>>> use.
>>>> Matt
>>>>> Meanwhile the system installation still points to the
>>>>> valera/petsc/cuda build,
>>>>> should i just delete the petsc installation folder and start over?
>>>>> Thanks,
>>>>> On Wed, Mar 14, 2018 at 11:36 AM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Mar 15, 2018 at 3:25 AM, Manuel Valera <
>>>>>> mvalera-w at mail.sdsu.edu> wrote:
>>>>>>> yeah that worked,
>>>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcuda -dm_mat_type
>>>>>>> seqaijcusparse
>>>>>>> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
>>>>>>> Number of SNES iterations = 2
>>>>>>> How do i make sure the other program refer to this installation?
>>>>>>> using the same arguments there i get:
>>>>>>> [valera at node50 alone]$ ./linsolve -vec_type seqcuda -mat_type
>>>>>>> seqaijcusparse
>>>>>>> laplacian.petsc !
>>>>>>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>>>>>>> package: http://www.mcs.anl.gov/petsc/d
>>>>>>> ocumentation/installation.html#external
>>>>>>> [0]PETSC ERROR: Unknown vector type: seqcuda
>>>>>> This PETSc has not been configured with CUDA. It is located in /home/valera/petsc.
>>>>>> The other
>>>>>> one you used is located in /home/valera/testpetsc. It does not make
>>>>>> much sense to me that
>>>>>> it does not understand CUDA since it says the configure arguments had
>>>>>> --with-cuda=1. There
>>>>>> must have been a build problem. Rebuild
>>>>>> cd $PETSC_DIR
>>>>>> make all
>>>>>> If you still have a problem, reconfigure
>>>>>> cd $PETSC_DIR
>>>>>> ./cuda/lib/petsc/conf/reconfigure-cuda.py
>>>>>> make all
>>>>>> If that still fails, then something very bizarre is happening on your
>>>>>> machine and we will have
>>>>>> to exchange more mail.
>>>>>> Matt
>>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>>> v3.8.3-1817-g96b6f8a GIT Date: 2018-02-28 10:19:08 -0600
>>>>>>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar
>>>>>>> 14 11:25:11 2018
>>>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>>>>>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>>>>>>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>>>>>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>>>>>>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>>>>>>> [0]PETSC ERROR: #1 VecSetType() line 42 in
>>>>>>> /home/valera/petsc/src/vec/vec/interface/vecreg.c
>>>>>>> [0]PETSC ERROR: #2 VecSetTypeFromOptions_Private() line 1241 in
>>>>>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>>>>>> [0]PETSC ERROR: #3 VecSetFromOptions() line 1276 in
>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>> [0]PETSC ERROR: Vec object's type is not set: Argument # 1
>>>>>>> 14 11:25:11 2018
>>>>>>> [0]PETSC ERROR: #4 VecDuplicate() line 375 in
>>>>>>> 14 11:25:11 2018
>>>>>>> [0]PETSC ERROR: #5 VecDuplicate() line 375 in
>>>>>>> [0]PETSC ERROR: #6 User provided function() line 0 in User file
>>>>>>> I made sure there is a call for Vec/MatSetFromOptions() there, i am
>>>>>>> loading the matrix from a petsc binary in this case,
>>>>>>> Thanks,
>>>>>>> On Wed, Mar 14, 2018 at 11:22 AM, Matthew Knepley <knepley at gmail.com
>>>>>>> > wrote:
>>>>>>>> On Thu, Mar 15, 2018 at 3:19 AM, Manuel Valera <
>>>>>>>>> Yes, this is the system installation that is being correctly
>>>>>>>>> linked (the linear solver and model are not linking the correct
>>>>>>>>> installation idk why yet) i configured with only CUDA this time because of
>>>>>>>>> the message Karl Rupp posted on my installation thread, where he says only
>>>>>>>>> one type of library will work at a time, anyway this is what i got:
>>>>>>>>> -dm_mat_type seqaijcusp
>>>>>>>>> [0]PETSC ERROR: Unknown Mat type given: seqaijcusp
>>>>>>>> It is telling you the problem. Use
>>>>>>>> -dm_mat_type seqaijcusparse
>>>>>>>> Matt
>>>>>>>>> v3.8.3-2027-g045eeab GIT Date: 2018-03-12 13:30:25 -0500
>>>>>>>>> [0]PETSC ERROR: ./ex19 on a named node50 by valera Wed Mar 14
>>>>>>>>> 11:17:25 2018
>>>>>>>>> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
>>>>>>>>> --download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
>>>>>>>>> [0]PETSC ERROR: #1 MatSetType() line 61 in
>>>>>>>>> /home/valera/testpetsc/src/mat/interface/matreg.c
>>>>>>>>> [0]PETSC ERROR: #2 DMCreateMatrix_DA() line 693 in
>>>>>>>>> /home/valera/testpetsc/src/dm/impls/da/fdda.c
>>>>>>>>> [0]PETSC ERROR: #3 DMCreateMatrix() line 1199 in
>>>>>>>>> /home/valera/testpetsc/src/dm/interface/dm.c
>>>>>>>>> [0]PETSC ERROR: #4 SNESSetUpMatrices() line 646 in
>>>>>>>>> /home/valera/testpetsc/src/snes/interface/snes.c
>>>>>>>>> [0]PETSC ERROR: #5 SNESSetUp_NEWTONLS() line 296 in
>>>>>>>>> /home/valera/testpetsc/src/snes/impls/ls/ls.c
>>>>>>>>> [0]PETSC ERROR: #6 SNESSetUp() line 2795 in
>>>>>>>>> [0]PETSC ERROR: #7 SNESSolve() line 4187 in
>>>>>>>>> [0]PETSC ERROR: #8 main() line 161 in
>>>>>>>>> /home/valera/testpetsc/src/snes/examples/tutorials/ex19.c
>>>>>>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>>>>>>> [0]PETSC ERROR: -dm_mat_type seqaijcusp
>>>>>>>>> [0]PETSC ERROR: -dm_vec_type seqcuda
>>>>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>>>>> with errorcode 86.
>>>>>>>>> On Wed, Mar 14, 2018 at 11:16 AM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Thu, Mar 15, 2018 at 3:12 AM, Manuel Valera <
>>>>>>>>>>> Thanks, got this error:
>>>>>>>>>> Did you not configure with CUSP? It looks like you have CUDA, so
>>>>>>>>>> use
>>>>>>>>>> Thanks,
>>>>>>>>>> Matt
>>>>>>>>>>> [valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
>>>>>>>>>>> [valera at node50 tutorials]$ PETSC_ARCH="" make ex19
>>>>>>>>>>> /usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
>>>>>>>>>>> -fvisibility=hidden -O2 -I/home/valera/testpetsc/include
>>>>>>>>>>> -I/home/valera/testpetsc/arch-linux2-c-opt/include
>>>>>>>>>>> -I/usr/local/cuda/include -I/usr/lib64/openmpi/include `pwd`/ex19.c
>>>>>>>>>>> /usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings
>>>>>>>>>>> -fvisibility=hidden -O2 -o ex19 ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
>>>>>>>>>>> -L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64
>>>>>>>>>>> -L/usr/local/cuda/lib64 -L/usr/lib64/openmpi/lib
>>>>>>>>>>> -Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack
>>>>>>>>>>> -lblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl
>>>>>>>>>>> -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
>>>>>>>>>>> -lquadmath -lpthread -lstdc++ -ldl
>>>>>>>>>>> /usr/bin/rm -f ex19.o
>>>>>>>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp
>>>>>>>>>>> [0]PETSC ERROR: Unknown vector type: seqcusp
>>>>>>>>>>> 11:12:11 2018
>>>>>>>>>>> /home/valera/testpetsc/src/vec/vec/interface/vecreg.c
>>>>>>>>>>> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
>>>>>>>>>>> /home/valera/testpetsc/src/dm/impls/da/dadist.c
>>>>>>>>>>> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
>>>>>>>>>>> [0]PETSC ERROR: #4 main() line 158 in
>>>>>>>>>>> [0]PETSC ERROR: -dm_vec_type seqcusp
>>>>>>>>>>> with errorcode 86.
>>>>>>>>>>> processes.
>>>>>>>>>>> On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <
>>>>>>>>>>>> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <
>>>>>>>>>>>>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>>>>>>>>>>>>> -linux2-c-opt/tests/src/snes/examples/tutorials there is
>>>>>>>>>>>>> runex19.sh and a lot of other ex19 variantes, but if i run that i get:
>>>>>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$
>>>>>>>>>>>> pushd src/snes/examples/tutorials/
>>>>>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>>>>>>>>>>>> PETSC_ARCH=arch-master-debug make ex19
>>>>>>>>>>>> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Matt
>>>>>>>>>>>>> [valera at node50 tutorials]$ ./runex19.sh
>>>>>>>>>>>>> not ok snes_tutorials-ex19_1
>>>>>>>>>>>>> # mpiexec was unable to launch the specified application as
>>>>>>>>>>>>> it could not access
>>>>>>>>>>>>> # or execute an executable:
>>>>>>>>>>>>> # Executable: ../ex19
>>>>>>>>>>>>> # Node: node50
>>>>>>>>>>>>> # while attempting to start process rank 0.
>>>>>>>>>>>>> # 2 total processes failed to start
>>>>>>>>>>>>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>>>>>>>>>>>>> is this the one i should be running ?
>>>>>>>>>>>>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <
>>>>>>>>>>>>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <
>>>>>>>>>>>>>>> Ok thanks Matt, i made a smaller case with only the linear
>>>>>>>>>>>>>>> solver and a 25x25 matrix, the error i have in this case is:
>>>>>>>>>>>>>> Ah, it appears that not all parts of your problem are taking
>>>>>>>>>>>>>> the type options. If you want the
>>>>>>>>>>>>>> linear algebra objects to change type, you need to have
>>>>>>>>>>>>>> VecSetFromOptions() and MatSetFromOptions()
>>>>>>>>>>>>>> called after you create them, but before sizes are set and
>>>>>>>>>>>>>> data is entered. However, it should
>>>>>>>>>>>>>> not be possible to have a seq Vec with the seqcusp AXPY
>>>>>>>>>>>>>> routine set. Something else is wrong...
>>>>>>>>>>>>>> Did you try a PETSc example, such as SNES ex19, with this?
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>> cusp -mat_type aijcusparse
>>>>>>>>>>>>>>> laplacian.petsc !
>>>>>>>>>>>>>>> RHS loaded, size: 125 / 125
>>>>>>>>>>>>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>>>>>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>>>>>>>>>>>>> Wed Mar 14 10:24:35 2018
>>>>>>>>>>>>>>> --with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3
>>>>>>>>>>>>>>> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-shared-libraries=1
>>>>>>>>>>>>>>> --with-debugging=1 --with-cuda=1 --with-cuda-arch=sm_60 --with-cusp=1
>>>>>>>>>>>>>>> --with-cusp-dir=/home/valera/cusp --with-vienacl=1
>>>>>>>>>>>>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: Invalid argument
>>>>>>>>>>>>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>>>>>>>>>>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>>>>>>>>>>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>>>>>>>>>>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in
>>>>>>>>>>>>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>>>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>>>>>>>>>>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in
>>>>>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>>> soln maxval: 0.0000000000000000
>>>>>>>>>>>>>>> soln minval: 0.0000000000000000
>>>>>>>>>>>>>>> Norm: 11.180339887498949
>>>>>>>>>>>>>>> Its: 0
>>>>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>>>>> Option left: name:-mat_type value: aijcusparse
>>>>>>>>>>>>>>> I also see the configure options are not correct, so i guess
>>>>>>>>>>>>>>> is still linking a different petsc installation, but maybe we can try to
>>>>>>>>>>>>>>> make it work as it is, i will let you know if i am able to link the correct
>>>>>>>>>>>>>>> petsc installation here,
>>>>>>>>>>>>>>> Best,
>>>>>>>>>>>>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <
>>>>>>>>>>>>>>>>> Hello all,
>>>>>>>>>>>>>>>>> I am working on porting a linear solver into GPUs for
>>>>>>>>>>>>>>>>> timing purposes, so far i've been able to compile and run the CUSP
>>>>>>>>>>>>>>>>> libraries and compile PETSc to be used with CUSP and ViennaCL, after the
>>>>>>>>>>>>>>>>> initial runs i noticed some errors, they are different for different flags
>>>>>>>>>>>>>>>>> and i would appreciate any help interpreting them,
>>>>>>>>>>>>>>>>> The only elements in this program that use PETSc are the
>>>>>>>>>>>>>>>>> laplacian matrix (sparse), the RHS and X vectors and a scatter petsc
>>>>>>>>>>>>>>>>> object, so i would say it's safe to pass the command line arguments for the
>>>>>>>>>>>>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>>>>>>>>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>>>>>>>>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>>>>>>>>>>>>> These systems do not properly propagate errors. My only
>>>>>>>>>>>>>>>> advice is to run a smaller problem and see.
>>>>>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>>>>>> and Apple Mac OS X to find memory corruption errors
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack
>>>>>>>>>>>>>>>>> below
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Stack Frames
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack
>>>>>>>>>>>>>>>>> are not available,
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: INSTEAD the line number of the start
>>>>>>>>>>>>>>>>> of the function
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: is given.
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetType line 36
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line
>>>>>>>>>>>>>>>>> 1230 /home/valera/petsc/src/vec/vec/interface/vector.c
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by
>>>>>>>>>>>>>>>>> valera Thu Mar 8 09:50:51 2018
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in
>>>>>>>>>>>>>>>>> unknown file
>>>>>>>>>>>>>>>>> This seems to be a memory out of range, maybe my vector is
>>>>>>>>>>>>>>>>> too big for my CUDA system? how do i assess that?
>>>>>>>>>>>>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i
>>>>>>>>>>>>>>>>> get something different and more interesting:
>>>>>>>>>>>>>>>> We need to see the entire error message, since it has the
>>>>>>>>>>>>>>>> stack.
>>>>>>>>>>>>>>>> This seems like a logic error, but could definitely be on
>>>>>>>>>>>>>>>> our end. Here is how I think about these:
>>>>>>>>>>>>>>>> 1) We have nightly test solves, so at least some solver
>>>>>>>>>>>>>>>> configuration works
>>>>>>>>>>>>>>>> 2) Some vector which is marked read-only (happens for
>>>>>>>>>>>>>>>> input to solvers), but someone is trying to update it.
>>>>>>>>>>>>>>>> The stack will tell me where this is happening.
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Vec is locked read only, argument # 3
>>>>>>>>>>>>>>>>> valera Thu Mar 8 10:02:19 2018
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>>>>>>>>>>>>> PETSC_SOLVER_ONLY 6.8672990892082453E-005 s
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718
>>>>>>>>>>>>>>>>> in /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/
>>>>>>>>>>>>>>>>> veccusp2.cu
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>>>>>>>>>>>>> vecscattercusp.cu
>>>>>>>>>>>>>>>>> And it yields a "solution" to the system and also a log at
>>>>>>>>>>>>>>>>> the end:
>>>>>>>>>>>>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by
>>>>>>>>>>>>>>>>> valera Thu Mar 8 10:02:24 2018
>>>>>>>>>>>>>>>>> Max Max/Min Avg
>>>>>>>>>>>>>>>>> Total
>>>>>>>>>>>>>>>>> Time (sec): 4.573e+00 1.00000 4.573e+00
>>>>>>>>>>>>>>>>> Objects: 8.100e+01 1.00000 8.100e+01
>>>>>>>>>>>>>>>>> Flop: 3.492e+07 1.00000 3.492e+07
>>>>>>>>>>>>>>>>> 3.492e+07
>>>>>>>>>>>>>>>>> Flop/sec: 7.637e+06 1.00000 7.637e+06
>>>>>>>>>>>>>>>>> 7.637e+06
>>>>>>>>>>>>>>>>> Memory: 2.157e+08 1.00000
>>>>>>>>>>>>>>>>> 2.157e+08
>>>>>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>>>>>> of type (multiply/divide/add/subtract)
>>>>>>>>>>>>>>>>> vectors of length N --> 2N flop
>>>>>>>>>>>>>>>>> vectors of length N --> 8N flop
>>>>>>>>>>>>>>>>> --- Messages --- -- Message Lengths -- -- Reductions --
>>>>>>>>>>>>>>>>> counts %Total Avg %Total counts %Total
>>>>>>>>>>>>>>>>> 0: Main Stage: 4.5729e+00 100.0% 3.4924e+07 100.0%
>>>>>>>>>>>>>>>>> 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
>>>>>>>>>>>>>>>>> details on interpreting output.
>>>>>>>>>>>>>>>>> Phase summary info:
>>>>>>>>>>>>>>>>> over all processors
>>>>>>>>>>>>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>>>>>>>>>>>>> flop in this phase
>>>>>>>>>>>>>>>>> message lengths in this phase
>>>>>>>>>>>>>>>>> processors)/(max time over all processors)
>>>>>>>>>>>>>>>>> # WARNING!!!
>>>>>>>>>>>>>>>>> # This code was compiled with a debugging option,
>>>>>>>>>>>>>>>>> # To get timing results run ./configure
>>>>>>>>>>>>>>>>> # using --with-debugging=no, the performance will
>>>>>>>>>>>>>>>>> # be generally two or three times faster.
>>>>>>>>>>>>>>>>> Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>>>>>>>>>>>>>>>>> MatLUFactorNum 1 1.0 4.9502e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 1100 0 0 0 1100 0 0 0 706
>>>>>>>>>>>>>>>>> MatILUFactorSym 1 1.0 1.9642e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>>>>>>>>>>>>>> MatAssemblyBegin 2 1.0 6.9141e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> MatAssemblyEnd 2 1.0 2.6612e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 6 0 0 0 0 6 0 0 0 0 0
>>>>>>>>>>>>>>>>> MatGetRowIJ 1 1.0 5.0068e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> MatGetOrdering 1 1.0 1.7186e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> MatLoad 1 1.0 1.1575e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
>>>>>>>>>>>>>>>>> MatView 1 1.0 8.0877e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
>>>>>>>>>>>>>>>>> MatCUSPCopyTo 1 1.0 2.4664e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 5 0 0 0 0 5 0 0 0 0 0
>>>>>>>>>>>>>>>>> VecSet 68 1.0 5.1665e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>>>>>>>>>>>>>> VecAssemblyBegin 17 1.0 5.2691e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> VecAssemblyEnd 17 1.0 4.3631e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> VecScatterBegin 15 1.0 1.5345e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> VecCUSPCopyFrom 1 1.0 1.1199e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> KSPSetUp 1 1.0 5.1929e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>>>>> PCSetUp 2 1.0 8.6590e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 2100 0 0 0 2100 0 0 0 403
>>>>>>>>>>>>>>>>> Descendants' Mem.
>>>>>>>>>>>>>>>>> Matrix 3 1 52856972
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> Matrix Null Space 1 1 608
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> Vector 66 3 3414600
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> Vector Scatter 1 1 680
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> Viewer 3 2 1680
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> Krylov Solver 1 0 0
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> Preconditioner 2 1 864
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> Index Set 4 1 800
>>>>>>>>>>>>>>>>> 0.
>>>>>>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>>>>>>> -log_view
>>>>>>>>>>>>>>>>> -vec_type cusp
>>>>>>>>>>>>>>>>> 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>>>>>>>>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc
>>>>>>>>>>>>>>>>> Libraries compiled on Mon Mar 5 16:37:18 2018 on node50
>>>>>>>>>>>>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>>>>>>>>>>>>> Using PETSc arch: cuda
>>>>>>>>>>>>>>>>> Using C compiler: mpicc -fPIC -Wall -Wwrite-strings
>>>>>>>>>>>>>>>>> -fvisibility=hidden -O3
>>>>>>>>>>>>>>>>> Using Fortran compiler: mpifort -fPIC -Wall
>>>>>>>>>>>>>>>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>>>>>>>>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>>>>>>>>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>>>>>>>>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>>>>>>>>>>>>> Using C linker: mpicc
>>>>>>>>>>>>>>>>> Using Fortran linker: mpifort
>>>>>>>>>>>>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>>>>>>>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>>>>>>>>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>>>>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE
>>>>>>>>>>>>>>>>> -lflapack -lfblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++
>>>>>>>>>>>>>>>>> -ldl -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
>>>>>>>>>>>>>>>>> Thanks for your help,
>>>>>>>>>>>>>>>>> Manuel
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/30ec096d/attachment-0001.html>
