[petsc-users] Tweaking my code for CUDA
    Manuel Valera
    mvalera-w at mail.sdsu.edu
    Wed Mar 14 14:01:06 CDT 2018
Ok well, it turns out the $PETSC_DIR points to the testpetsc directory, and
it makes, install and tests without problems (only a problem on ex5f) but
trying to reconfigure on valera/petsc directory asks me to change the
$PETSC_DIR variable,
Meanwhile the system installation still points to the valera/petsc/cuda
build,
should i just delete the petsc installation folder and start over?
On Wed, Mar 14, 2018 at 11:36 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 15, 2018 at 3:25 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
> wrote:
>> yeah that worked,
>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcuda -dm_mat_type
>> seqaijcusparse
>> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
>> Number of SNES iterations = 2
>> How do i make sure the other program refer to this installation? using
>> the same arguments there i get:
>> [valera at node50 alone]$ ./linsolve -vec_type seqcuda -mat_type
>> seqaijcusparse
>>  laplacian.petsc !
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing package:
>> http://www.mcs.anl.gov/petsc/documentation/installation.html#external
>> [0]PETSC ERROR: Unknown vector type: seqcuda
> This PETSc has not been configured with CUDA. It is located in /home/valera/petsc.
> The other
> one you used is located in  /home/valera/testpetsc. It does not make much
> sense to me that
> it does not understand CUDA since it says the configure arguments had
> --with-cuda=1. There
> must have been a build problem. Rebuild
>   cd $PETSC_DIR
>   make all
> If you still have a problem, reconfigure
>   cd $PETSC_DIR
>   ./cuda/lib/petsc/conf/reconfigure-cuda.py
>   make all
> If that still fails, then something very bizarre is happening on your
> machine and we will have
> to exchange more mail.
>   Matt
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a  GIT
>> Date: 2018-02-28 10:19:08 -0600
>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
>> 11:25:11 2018
>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>> [0]PETSC ERROR: #1 VecSetType() line 42 in /home/valera/petsc/src/vec/vec
>> /interface/vecreg.c
>> [0]PETSC ERROR: #2 VecSetTypeFromOptions_Private() line 1241 in
>> /home/valera/petsc/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: #3 VecSetFromOptions() line 1276 in
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: Vec object's type is not set: Argument # 1
>> 11:25:11 2018
>> [0]PETSC ERROR: #4 VecDuplicate() line 375 in
>> 11:25:11 2018
>> [0]PETSC ERROR: #5 VecDuplicate() line 375 in
>> [0]PETSC ERROR: #6 User provided function() line 0 in User file
>> I made sure there is a call for Vec/MatSetFromOptions() there, i am
>> loading the matrix from a petsc binary in this case,
>> Thanks,
>> On Wed, Mar 14, 2018 at 11:22 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, Mar 15, 2018 at 3:19 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>>> wrote:
>>>> Yes, this is the system installation that is being correctly linked
>>>> (the linear solver and model are not linking the correct installation idk
>>>> why yet) i configured with only CUDA this time because of the message Karl
>>>> Rupp posted on my installation thread, where he says only one type of
>>>> library will work at a time, anyway this is what i got:
>>>> seqaijcusp
>>>> package: http://www.mcs.anl.gov/petsc/documentation/installation.html
>>>> #external
>>>> [0]PETSC ERROR: Unknown Mat type given: seqaijcusp
>>> It is telling you the problem. Use
>>>   -dm_mat_type seqaijcusparse
>>>    Matt
>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab
>>>> GIT Date: 2018-03-12 13:30:25 -0500
>>>> [0]PETSC ERROR: ./ex19 on a  named node50 by valera Wed Mar 14 11:17:25
>>>> 2018
>>>> [0]PETSC ERROR: Configure options --prefix=/usr/local/petsc.cod/petsc-install
>>>> --with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
>>>> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
>>>> --download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
>>>> [0]PETSC ERROR: #1 MatSetType() line 61 in
>>>> /home/valera/testpetsc/src/mat/interface/matreg.c
>>>> [0]PETSC ERROR: #2 DMCreateMatrix_DA() line 693 in
>>>> /home/valera/testpetsc/src/dm/impls/da/fdda.c
>>>> [0]PETSC ERROR: #3 DMCreateMatrix() line 1199 in
>>>> /home/valera/testpetsc/src/dm/interface/dm.c
>>>> [0]PETSC ERROR: #4 SNESSetUpMatrices() line 646 in
>>>> /home/valera/testpetsc/src/snes/interface/snes.c
>>>> [0]PETSC ERROR: #5 SNESSetUp_NEWTONLS() line 296 in
>>>> /home/valera/testpetsc/src/snes/impls/ls/ls.c
>>>> [0]PETSC ERROR: #6 SNESSetUp() line 2795 in
>>>> [0]PETSC ERROR: #7 SNESSolve() line 4187 in
>>>> [0]PETSC ERROR: #8 main() line 161 in /home/valera/testpetsc/src/sne
>>>> s/examples/tutorials/ex19.c
>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>> [0]PETSC ERROR: -dm_mat_type seqaijcusp
>>>> [0]PETSC ERROR: -dm_vec_type seqcuda
>>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>>> error message to petsc-maint at mcs.anl.gov----------
>>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>> with errorcode 86.
>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>> You may or may not see output from other processes, depending on
>>>> exactly when Open MPI kills them.
>>>> On Wed, Mar 14, 2018 at 11:16 AM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Thu, Mar 15, 2018 at 3:12 AM, Manuel Valera <
>>>>> mvalera-w at mail.sdsu.edu> wrote:
>>>>>> Thanks, got this error:
>>>>> Did you not configure with CUSP? It looks like you have CUDA, so use
>>>>>   Thanks,
>>>>>     Matt
>>>>>> [valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
>>>>>> [valera at node50 tutorials]$ PETSC_ARCH="" make ex19
>>>>>> /usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>>> -fvisibility=hidden -O2   -I/home/valera/testpetsc/include
>>>>>> -I/home/valera/testpetsc/arch-linux2-c-opt/include
>>>>>> -I/usr/local/petsc.cod/petsc-install/include
>>>>>> -I/usr/local/cuda/include -I/usr/lib64/openmpi/include    `pwd`/ex19.c
>>>>>> /usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings
>>>>>> -fvisibility=hidden -O2  -o ex19  ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
>>>>>> -Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
>>>>>> -L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64
>>>>>> -L/usr/lib64 -Wl,-rpath,/usr/local/cuda/lib64
>>>>>> -L/usr/local/cuda/lib64 -L/usr/lib64/openmpi/lib
>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>> -Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack -lblas
>>>>>> -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>>>> -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>>>>>> -lpthread -lstdc++ -ldl
>>>>>> /usr/bin/rm -f ex19.o
>>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp -dm_mat_type
>>>>>> seqaijcusp
>>>>>> #external
>>>>>> [0]PETSC ERROR: Unknown vector type: seqcusp
>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>> 11:12:11 2018
>>>>>> /home/valera/testpetsc/src/vec/vec/interface/vecreg.c
>>>>>> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
>>>>>> /home/valera/testpetsc/src/dm/impls/da/dadist.c
>>>>>> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
>>>>>> [0]PETSC ERROR: #4 main() line 158 in /home/valera/testpetsc/src/sne
>>>>>> [0]PETSC ERROR: -dm_vec_type seqcusp
>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>> with errorcode 86.
>>>>>> On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <
>>>>>>>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>>>>>>>> -linux2-c-opt/tests/src/snes/examples/tutorials there is
>>>>>>>> runex19.sh and a lot of other ex19 variantes, but if i run that i get:
>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$ pushd
>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>>>>>>> PETSC_ARCH=arch-master-debug make ex19
>>>>>>> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> [valera at node50 tutorials]$ ./runex19.sh
>>>>>>>> not ok snes_tutorials-ex19_1
>>>>>>>> # mpiexec was unable to launch the specified application as it
>>>>>>>> could not access
>>>>>>>> # or execute an executable:
>>>>>>>> # Executable: ../ex19
>>>>>>>> # Node: node50
>>>>>>>> # while attempting to start process rank 0.
>>>>>>>> # 2 total processes failed to start
>>>>>>>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>>>>>>>> is this the one i should be running ?
>>>>>>>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <
>>>>>>>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <
>>>>>>>>>> Ok thanks Matt, i made a smaller case with only the linear solver
>>>>>>>>>> and a 25x25 matrix, the error i have in this case is:
>>>>>>>>> Ah, it appears that not all parts of your problem are taking the
>>>>>>>>> type options. If you want the
>>>>>>>>> linear algebra objects to change type, you need to have
>>>>>>>>>   VecSetFromOptions()  and MatSetFromOptions()
>>>>>>>>> called after you create them, but before sizes are set and data is
>>>>>>>>> entered. However, it should
>>>>>>>>> not be possible to have a seq Vec with the seqcusp AXPY routine
>>>>>>>>> set. Something else is wrong...
>>>>>>>>> Did you try a PETSc example, such as SNES ex19, with this?
>>>>>>>>>   Thanks,
>>>>>>>>>     Matt
>>>>>>>>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp
>>>>>>>>>> -mat_type aijcusparse
>>>>>>>>>>  laplacian.petsc !
>>>>>>>>>>  TrivSoln loaded, size:          125 /         125
>>>>>>>>>>  RHS loaded, size:          125 /         125
>>>>>>>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>>>>>>>> v3.8.3-1817-g96b6f8a  GIT Date: 2018-02-28 10:19:08 -0600
>>>>>>>>>> Mar 14 10:24:35 2018
>>>>>>>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>>>>>>>> [0]PETSC ERROR: Invalid argument
>>>>>>>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>>>>>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>>>>>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>>>>>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in
>>>>>>>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>>>>>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>>>>>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in
>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>  soln maxval:   0.0000000000000000
>>>>>>>>>>  soln minval:   0.0000000000000000
>>>>>>>>>>  Norm:   11.180339887498949
>>>>>>>>>>  Its:           0
>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>> Option left: name:-mat_type value: aijcusparse
>>>>>>>>>> I also see the configure options are not correct, so i guess is
>>>>>>>>>> still linking a different petsc installation, but maybe we can try to make
>>>>>>>>>> it work as it is, i will let you know if i am able to link the correct
>>>>>>>>>> petsc installation here,
>>>>>>>>>> Best,
>>>>>>>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <
>>>>>>>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <
>>>>>>>>>>>> Hello all,
>>>>>>>>>>>> I am working on porting a linear solver into GPUs for timing
>>>>>>>>>>>> purposes, so far i've been able to compile and run the CUSP libraries and
>>>>>>>>>>>> compile PETSc to be used with CUSP and ViennaCL, after the initial runs i
>>>>>>>>>>>> noticed some errors, they are different for different flags and i would
>>>>>>>>>>>> appreciate any help interpreting them,
>>>>>>>>>>>> The only elements in this program that use PETSc are the
>>>>>>>>>>>> laplacian matrix (sparse), the RHS and X vectors and a scatter petsc
>>>>>>>>>>>> object, so i would say it's safe to pass the command line arguments for the
>>>>>>>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>>>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>>>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>>>>>>>> These systems do not properly propagate errors. My only advice
>>>>>>>>>>> is to run a smaller problem and see.
>>>>>>>>>>>> [0]PETSC ERROR: ------------------------------
>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>> ocumentation/faq.html#valgrind
>>>>>>>>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>>>>>>>> Apple Mac OS X to find memory corruption errors
>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are
>>>>>>>>>>>> not available,
>>>>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of
>>>>>>>>>>>> the function
>>>>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetType line 36
>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/vecreg.c
>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by valera
>>>>>>>>>>>> Thu Mar  8 09:50:51 2018
>>>>>>>>>>>> --with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3
>>>>>>>>>>>> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-shared-libraries=1
>>>>>>>>>>>> --with-debugging=1 --with-cuda=1 --with-cuda-arch=sm_60 --with-cusp=1
>>>>>>>>>>>> --with-cusp-dir=/home/valera/cusp --with-vienacl=1
>>>>>>>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in  unknown
>>>>>>>>>>>> file
>>>>>>>>>>>> This seems to be a memory out of range, maybe my vector is too
>>>>>>>>>>>> big for my CUDA system? how do i assess that?
>>>>>>>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get
>>>>>>>>>>>> something different and more interesting:
>>>>>>>>>>> We need to see the entire error message, since it has the stack.
>>>>>>>>>>> This seems like a logic error, but could definitely be on our
>>>>>>>>>>> end. Here is how I think about these:
>>>>>>>>>>>   1) We have nightly test solves, so at least some solver
>>>>>>>>>>> configuration works
>>>>>>>>>>>   2) Some vector which is marked read-only (happens for input to
>>>>>>>>>>> solvers), but someone is trying to update it.
>>>>>>>>>>>       The stack will tell me where this is happening.
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> [0]PETSC ERROR:  Vec is locked read only, argument # 3
>>>>>>>>>>>> Thu Mar  8 10:02:19 2018
>>>>>>>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>>>>>>>>  PETSC_SOLVER_ONLY   6.8672990892082453E-005 s
>>>>>>>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>>>>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscatterc
>>>>>>>>>>>> usp.cu
>>>>>>>>>>>> And it yields a "solution" to the system and also a log at the
>>>>>>>>>>>> end:
>>>>>>>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by
>>>>>>>>>>>> valera Thu Mar  8 10:02:24 2018
>>>>>>>>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a  GIT
>>>>>>>>>>>>                          Max       Max/Min        Avg
>>>>>>>>>>>> Total
>>>>>>>>>>>> Time (sec):           4.573e+00      1.00000   4.573e+00
>>>>>>>>>>>> Objects:              8.100e+01      1.00000   8.100e+01
>>>>>>>>>>>> Flop:                 3.492e+07      1.00000   3.492e+07
>>>>>>>>>>>> 3.492e+07
>>>>>>>>>>>> Flop/sec:            7.637e+06      1.00000   7.637e+06
>>>>>>>>>>>> 7.637e+06
>>>>>>>>>>>> Memory:               2.157e+08      1.00000
>>>>>>>>>>>> 2.157e+08
>>>>>>>>>>>> MPI Messages:         0.000e+00      0.00000   0.000e+00
>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00
>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>> MPI Reductions:       0.000e+00      0.00000
>>>>>>>>>>>> Flop counting convention: 1 flop = 1 real number operation of
>>>>>>>>>>>> type (multiply/divide/add/subtract)
>>>>>>>>>>>>                             e.g., VecAXPY() for real vectors of
>>>>>>>>>>>> length N --> 2N flop
>>>>>>>>>>>>                             and VecAXPY() for complex vectors
>>>>>>>>>>>> of length N --> 8N flop
>>>>>>>>>>>> Summary of Stages:   ----- Time ------  ----- Flop -----  ---
>>>>>>>>>>>> Messages ---  -- Message Lengths --  -- Reductions --
>>>>>>>>>>>>                         Avg     %Total     Avg     %Total
>>>>>>>>>>>>  counts   %Total     Avg         %Total   counts   %Total
>>>>>>>>>>>>  0:      Main Stage: 4.5729e+00 100.0%  3.4924e+07 100.0%
>>>>>>>>>>>> 0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>>>>>>>>>>>> See the 'Profiling' chapter of the users' manual for details on
>>>>>>>>>>>> interpreting output.
>>>>>>>>>>>> Phase summary info:
>>>>>>>>>>>>    Count: number of times phase was executed
>>>>>>>>>>>>    Time and Flop: Max - maximum over all processors
>>>>>>>>>>>>                    Ratio - ratio of maximum to minimum over all
>>>>>>>>>>>> processors
>>>>>>>>>>>>    Mess: number of messages sent
>>>>>>>>>>>>    Avg. len: average message length (bytes)
>>>>>>>>>>>>    Reduct: number of global reductions
>>>>>>>>>>>>    Global: entire computation
>>>>>>>>>>>>    Stage: stages of a computation. Set stages with
>>>>>>>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>>>>>>>>       %T - percent time in this phase         %F - percent flop
>>>>>>>>>>>> in this phase
>>>>>>>>>>>>       %M - percent messages in this phase     %L - percent
>>>>>>>>>>>> message lengths in this phase
>>>>>>>>>>>>       %R - percent reductions in this phase
>>>>>>>>>>>>    Total Mflop/s: 10e-6 * (sum of flop over all
>>>>>>>>>>>> processors)/(max time over all processors)
>>>>>>>>>>>>       #                          WARNING!!!                    #
>>>>>>>>>>>>       #   This code was compiled with a debugging option,      #
>>>>>>>>>>>>       #   To get timing results run ./configure                #
>>>>>>>>>>>>       #   using --with-debugging=no, the performance will      #
>>>>>>>>>>>>       #   be generally two or three times faster.              #
>>>>>>>>>>>> Event                Count      Time (sec)     Flop
>>>>>>>>>>>>                  --- Global ---  --- Stage ---   Total
>>>>>>>>>>>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess
>>>>>>>>>>>>  Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>>>>>>>>>> --- Event Stage 0: Main Stage
>>>>>>>>>>>> MatLUFactorNum         1 1.0 4.9502e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  1100  0  0  0   1100  0  0  0   706
>>>>>>>>>>>> MatILUFactorSym        1 1.0 1.9642e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>>>>>>>>> MatAssemblyBegin       2 1.0 6.9141e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>> MatAssemblyEnd         2 1.0 2.6612e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
>>>>>>>>>>>> MatGetRowIJ            1 1.0 5.0068e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>> MatGetOrdering         1 1.0 1.7186e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>> MatLoad                1 1.0 1.1575e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>>>>>>>>>>>> MatView                1 1.0 8.0877e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>>>>>>>>>> MatCUSPCopyTo          1 1.0 2.4664e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
>>>>>>>>>>>> VecSet                68 1.0 5.1665e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>>>>>>>>>>>> VecAssemblyBegin      17 1.0 5.2691e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>> VecAssemblyEnd        17 1.0 4.3631e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>> VecScatterBegin       15 1.0 1.5345e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>> VecCUSPCopyFrom        1 1.0 1.1199e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>> KSPSetUp               1 1.0 5.1929e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>> PCSetUp                2 1.0 8.6590e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  2100  0  0  0   2100  0  0  0   403
>>>>>>>>>>>> Memory usage is given in bytes:
>>>>>>>>>>>> Object Type          Creations   Destructions     Memory
>>>>>>>>>>>> Descendants' Mem.
>>>>>>>>>>>> Reports information only for process 0.
>>>>>>>>>>>>               Matrix     3              1     52856972     0.
>>>>>>>>>>>>    Matrix Null Space     1              1          608     0.
>>>>>>>>>>>>               Vector    66              3      3414600     0.
>>>>>>>>>>>>       Vector Scatter     1              1          680     0.
>>>>>>>>>>>>               Viewer     3              2         1680     0.
>>>>>>>>>>>>        Krylov Solver     1              0            0     0.
>>>>>>>>>>>>       Preconditioner     2              1          864     0.
>>>>>>>>>>>>            Index Set     4              1          800     0.
>>>>>>>>>>>> Average time to get PetscTime(): 9.53674e-08
>>>>>>>>>>>> #PETSc Option Table entries:
>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>> -log_view
>>>>>>>>>>>> -matload_block_size 1
>>>>>>>>>>>> -vec_type cusp
>>>>>>>>>>>> #End of PETSc Option Table entries
>>>>>>>>>>>> Compiled without FORTRAN kernels
>>>>>>>>>>>> Compiled with full precision matrices (default)
>>>>>>>>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>>>>>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>>>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc
>>>>>>>>>>>> Libraries compiled on Mon Mar  5 16:37:18 2018 on node50
>>>>>>>>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>>>>>>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>>>>>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>>>>>>>> Using PETSc arch: cuda
>>>>>>>>>>>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
>>>>>>>>>>>> -fvisibility=hidden -O3
>>>>>>>>>>>> Using Fortran compiler: mpifort  -fPIC -Wall
>>>>>>>>>>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>>>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>>>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>>>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>>>>>>>> Using C linker: mpicc
>>>>>>>>>>>> Using Fortran linker: mpifort
>>>>>>>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>>>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack
>>>>>>>>>>>> -lfblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl
>>>>>>>>>>>> -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
>>>>>>>>>>>> -lquadmath -lpthread -lstdc++ -ldl
>>>>>>>>>>>> Thanks for your help,
>>>>>>>>>>>> Manuel
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180314/f5ec01b4/attachment-0001.html>
