[petsc-users] Tweaking my code for CUDA
Wed Mar 14 15:52:53 CDT 2018
On Thu, Mar 15, 2018 at 4:01 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
wrote:
> Ok well, it turns out the $PETSC_DIR points to the testpetsc directory,
> and it makes, install and tests without problems (only a problem on ex5f)
> but trying to reconfigure on valera/petsc directory asks me to change the
> $PETSC_DIR variable,
Yes, you must set PETSC_DIR to point to the installation you want to use.
  Matt
> Meanwhile the system installation still points to the valera/petsc/cuda
> build,
> should i just delete the petsc installation folder and start over?
> Thanks,
> On Wed, Mar 14, 2018 at 11:36 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Mar 15, 2018 at 3:25 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>> wrote:
>>> yeah that worked,
>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcuda -dm_mat_type
>>> seqaijcusparse
>>> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
>>> Number of SNES iterations = 2
>>> How do i make sure the other program refer to this installation? using
>>> the same arguments there i get:
>>> [valera at node50 alone]$ ./linsolve -vec_type seqcuda -mat_type
>>> seqaijcusparse
>>>  laplacian.petsc !
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>>> package: http://www.mcs.anl.gov/petsc/documentation/installation.html
>>> #external
>>> [0]PETSC ERROR: Unknown vector type: seqcuda
>> This PETSc has not been configured with CUDA. It is located in /home/valera/petsc.
>> The other
>> one you used is located in  /home/valera/testpetsc. It does not make
>> much sense to me that
>> it does not understand CUDA since it says the configure arguments had
>> --with-cuda=1. There
>> must have been a build problem. Rebuild
>>   cd $PETSC_DIR
>>   make all
>> If you still have a problem, reconfigure
>>   cd $PETSC_DIR
>>   ./cuda/lib/petsc/conf/reconfigure-cuda.py
>>   make all
>> If that still fails, then something very bizarre is happening on your
>> machine and we will have
>> to exchange more mail.
>>   Matt
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>> GIT Date: 2018-02-28 10:19:08 -0600
>>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
>>> 11:25:11 2018
>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>>> [0]PETSC ERROR: #1 VecSetType() line 42 in /home/valera/petsc/src/vec/vec
>>> /interface/vecreg.c
>>> [0]PETSC ERROR: #2 VecSetTypeFromOptions_Private() line 1241 in
>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>> [0]PETSC ERROR: #3 VecSetFromOptions() line 1276 in
>>> [0]PETSC ERROR: Object is in wrong state
>>> [0]PETSC ERROR: Vec object's type is not set: Argument # 1
>>> 11:25:11 2018
>>> [0]PETSC ERROR: #4 VecDuplicate() line 375 in
>>> 11:25:11 2018
>>> [0]PETSC ERROR: #5 VecDuplicate() line 375 in
>>> [0]PETSC ERROR: #6 User provided function() line 0 in User file
>>> I made sure there is a call for Vec/MatSetFromOptions() there, i am
>>> loading the matrix from a petsc binary in this case,
>>> Thanks,
>>> On Wed, Mar 14, 2018 at 11:22 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Mar 15, 2018 at 3:19 AM, Manuel Valera <mvalera-w at mail.sdsu.edu
>>>> > wrote:
>>>>> Yes, this is the system installation that is being correctly linked
>>>>> (the linear solver and model are not linking the correct installation idk
>>>>> why yet) i configured with only CUDA this time because of the message Karl
>>>>> Rupp posted on my installation thread, where he says only one type of
>>>>> library will work at a time, anyway this is what i got:
>>>>> seqaijcusp
>>>>> #external
>>>>> [0]PETSC ERROR: Unknown Mat type given: seqaijcusp
>>>> It is telling you the problem. Use
>>>>   -dm_mat_type seqaijcusparse
>>>>    Matt
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab
>>>>> GIT Date: 2018-03-12 13:30:25 -0500
>>>>> [0]PETSC ERROR: ./ex19 on a  named node50 by valera Wed Mar 14
>>>>> 11:17:25 2018
>>>>> [0]PETSC ERROR: Configure options --prefix=/usr/local/petsc.cod/petsc-install
>>>>> --with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
>>>>> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
>>>>> --download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
>>>>> [0]PETSC ERROR: #1 MatSetType() line 61 in
>>>>> /home/valera/testpetsc/src/mat/interface/matreg.c
>>>>> [0]PETSC ERROR: #2 DMCreateMatrix_DA() line 693 in
>>>>> /home/valera/testpetsc/src/dm/impls/da/fdda.c
>>>>> [0]PETSC ERROR: #3 DMCreateMatrix() line 1199 in
>>>>> /home/valera/testpetsc/src/dm/interface/dm.c
>>>>> [0]PETSC ERROR: #4 SNESSetUpMatrices() line 646 in
>>>>> /home/valera/testpetsc/src/snes/interface/snes.c
>>>>> [0]PETSC ERROR: #5 SNESSetUp_NEWTONLS() line 296 in
>>>>> /home/valera/testpetsc/src/snes/impls/ls/ls.c
>>>>> [0]PETSC ERROR: #6 SNESSetUp() line 2795 in
>>>>> [0]PETSC ERROR: #7 SNESSolve() line 4187 in
>>>>> [0]PETSC ERROR: #8 main() line 161 in /home/valera/testpetsc/src/sne
>>>>> s/examples/tutorials/ex19.c
>>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>>> [0]PETSC ERROR: -dm_mat_type seqaijcusp
>>>>> [0]PETSC ERROR: -dm_vec_type seqcuda
>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>>> with errorcode 86.
>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>>> You may or may not see output from other processes, depending on
>>>>> exactly when Open MPI kills them.
>>>>> On Wed, Mar 14, 2018 at 11:16 AM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Mar 15, 2018 at 3:12 AM, Manuel Valera <
>>>>>> mvalera-w at mail.sdsu.edu> wrote:
>>>>>>> Thanks, got this error:
>>>>>> Did you not configure with CUSP? It looks like you have CUDA, so use
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>> [valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
>>>>>>> [valera at node50 tutorials]$ PETSC_ARCH="" make ex19
>>>>>>> /usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
>>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>>>> -fvisibility=hidden -O2   -I/home/valera/testpetsc/include
>>>>>>> -I/home/valera/testpetsc/arch-linux2-c-opt/include
>>>>>>> -I/usr/local/petsc.cod/petsc-install/include
>>>>>>> -I/usr/local/cuda/include -I/usr/lib64/openmpi/include    `pwd`/ex19.c
>>>>>>> /usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings
>>>>>>> -fvisibility=hidden -O2  -o ex19  ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
>>>>>>> -Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
>>>>>>> -L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64
>>>>>>> -L/usr/lib64 -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>> -L/usr/local/cuda/lib64 -L/usr/lib64/openmpi/lib
>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>> -Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack -lblas
>>>>>>> -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>>>>> -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>>>>>>> -lpthread -lstdc++ -ldl
>>>>>>> /usr/bin/rm -f ex19.o
>>>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp -dm_mat_type
>>>>>>> seqaijcusp
>>>>>>> ocumentation/installation.html#external
>>>>>>> [0]PETSC ERROR: Unknown vector type: seqcusp
>>>>>>> v3.8.3-2027-g045eeab  GIT Date: 2018-03-12 13:30:25 -0500
>>>>>>> 11:12:11 2018
>>>>>>> /home/valera/testpetsc/src/vec/vec/interface/vecreg.c
>>>>>>> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
>>>>>>> /home/valera/testpetsc/src/dm/impls/da/dadist.c
>>>>>>> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
>>>>>>> [0]PETSC ERROR: #4 main() line 158 in /home/valera/testpetsc/src/sne
>>>>>>> [0]PETSC ERROR: -dm_vec_type seqcusp
>>>>>>> with errorcode 86.
>>>>>>> On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <knepley at gmail.com
>>>>>>> > wrote:
>>>>>>>> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <
>>>>>>>>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>>>>>>>>> -linux2-c-opt/tests/src/snes/examples/tutorials there is
>>>>>>>>> runex19.sh and a lot of other ex19 variantes, but if i run that i get:
>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$ pushd
>>>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>>>>>>>> PETSC_ARCH=arch-master-debug make ex19
>>>>>>>> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> [valera at node50 tutorials]$ ./runex19.sh
>>>>>>>>> not ok snes_tutorials-ex19_1
>>>>>>>>> # mpiexec was unable to launch the specified application as it
>>>>>>>>> could not access
>>>>>>>>> # or execute an executable:
>>>>>>>>> # Executable: ../ex19
>>>>>>>>> # Node: node50
>>>>>>>>> # while attempting to start process rank 0.
>>>>>>>>> # 2 total processes failed to start
>>>>>>>>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>>>>>>>>> is this the one i should be running ?
>>>>>>>>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <
>>>>>>>>>>> Ok thanks Matt, i made a smaller case with only the linear
>>>>>>>>>>> solver and a 25x25 matrix, the error i have in this case is:
>>>>>>>>>> Ah, it appears that not all parts of your problem are taking the
>>>>>>>>>> type options. If you want the
>>>>>>>>>> linear algebra objects to change type, you need to have
>>>>>>>>>>   VecSetFromOptions()  and MatSetFromOptions()
>>>>>>>>>> called after you create them, but before sizes are set and data
>>>>>>>>>> is entered. However, it should
>>>>>>>>>> not be possible to have a seq Vec with the seqcusp AXPY routine
>>>>>>>>>> set. Something else is wrong...
>>>>>>>>>> Did you try a PETSc example, such as SNES ex19, with this?
>>>>>>>>>>   Thanks,
>>>>>>>>>>     Matt
>>>>>>>>>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp
>>>>>>>>>>> -mat_type aijcusparse
>>>>>>>>>>>  laplacian.petsc !
>>>>>>>>>>>  TrivSoln loaded, size:          125 /         125
>>>>>>>>>>>  RHS loaded, size:          125 /         125
>>>>>>>>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>>>>>>>>> v3.8.3-1817-g96b6f8a  GIT Date: 2018-02-28 10:19:08 -0600
>>>>>>>>>>> Mar 14 10:24:35 2018
>>>>>>>>>>> --with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3
>>>>>>>>>>> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-shared-libraries=1
>>>>>>>>>>> --with-debugging=1 --with-cuda=1 --with-cuda-arch=sm_60 --with-cusp=1
>>>>>>>>>>> --with-cusp-dir=/home/valera/cusp --with-vienacl=1
>>>>>>>>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>>>>>>>>> [0]PETSC ERROR: Invalid argument
>>>>>>>>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>>>>>>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>>>>>>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>>>>>>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in
>>>>>>>>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>>>>>>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>>>>>>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in
>>>>>>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>  soln maxval:   0.0000000000000000
>>>>>>>>>>>  soln minval:   0.0000000000000000
>>>>>>>>>>>  Norm:   11.180339887498949
>>>>>>>>>>>  Its:           0
>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>> Option left: name:-mat_type value: aijcusparse
>>>>>>>>>>> I also see the configure options are not correct, so i guess is
>>>>>>>>>>> still linking a different petsc installation, but maybe we can try to make
>>>>>>>>>>> it work as it is, i will let you know if i am able to link the correct
>>>>>>>>>>> petsc installation here,
>>>>>>>>>>> Best,
>>>>>>>>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <
>>>>>>>>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <
>>>>>>>>>>>>> Hello all,
>>>>>>>>>>>>> I am working on porting a linear solver into GPUs for timing
>>>>>>>>>>>>> purposes, so far i've been able to compile and run the CUSP libraries and
>>>>>>>>>>>>> compile PETSc to be used with CUSP and ViennaCL, after the initial runs i
>>>>>>>>>>>>> noticed some errors, they are different for different flags and i would
>>>>>>>>>>>>> appreciate any help interpreting them,
>>>>>>>>>>>>> The only elements in this program that use PETSc are the
>>>>>>>>>>>>> laplacian matrix (sparse), the RHS and X vectors and a scatter petsc
>>>>>>>>>>>>> object, so i would say it's safe to pass the command line arguments for the
>>>>>>>>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>>>>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>>>>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>>>>>>>>> These systems do not properly propagate errors. My only advice
>>>>>>>>>>>> is to run a smaller problem and see.
>>>>>>>>>>>>> [0]PETSC ERROR: ------------------------------
>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>> ocumentation/faq.html#valgrind
>>>>>>>>>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>>>>>>>>> Apple Mac OS X to find memory corruption errors
>>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are
>>>>>>>>>>>>> not available,
>>>>>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of
>>>>>>>>>>>>> the function
>>>>>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetType line 36
>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/vecreg.c
>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by valera
>>>>>>>>>>>>> Thu Mar  8 09:50:51 2018
>>>>>>>>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in  unknown
>>>>>>>>>>>>> file
>>>>>>>>>>>>> This seems to be a memory out of range, maybe my vector is too
>>>>>>>>>>>>> big for my CUDA system? how do i assess that?
>>>>>>>>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get
>>>>>>>>>>>>> something different and more interesting:
>>>>>>>>>>>> We need to see the entire error message, since it has the stack.
>>>>>>>>>>>> This seems like a logic error, but could definitely be on our
>>>>>>>>>>>> end. Here is how I think about these:
>>>>>>>>>>>>   1) We have nightly test solves, so at least some solver
>>>>>>>>>>>> configuration works
>>>>>>>>>>>>   2) Some vector which is marked read-only (happens for input
>>>>>>>>>>>> to solvers), but someone is trying to update it.
>>>>>>>>>>>>       The stack will tell me where this is happening.
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> [0]PETSC ERROR:  Vec is locked read only, argument # 3
>>>>>>>>>>>>> Thu Mar  8 10:02:19 2018
>>>>>>>>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>>>>>>>>>  PETSC_SOLVER_ONLY   6.8672990892082453E-005 s
>>>>>>>>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>>>>>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscatterc
>>>>>>>>>>>>> usp.cu
>>>>>>>>>>>>> And it yields a "solution" to the system and also a log at the
>>>>>>>>>>>>> end:
>>>>>>>>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by
>>>>>>>>>>>>> valera Thu Mar  8 10:02:24 2018
>>>>>>>>>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>>>>>>>>>>>>                          Max       Max/Min        Avg
>>>>>>>>>>>>> Total
>>>>>>>>>>>>> Time (sec):           4.573e+00      1.00000   4.573e+00
>>>>>>>>>>>>> Objects:              8.100e+01      1.00000   8.100e+01
>>>>>>>>>>>>> Flop:                 3.492e+07      1.00000   3.492e+07
>>>>>>>>>>>>> 3.492e+07
>>>>>>>>>>>>> Flop/sec:            7.637e+06      1.00000   7.637e+06
>>>>>>>>>>>>> 7.637e+06
>>>>>>>>>>>>> Memory:               2.157e+08      1.00000
>>>>>>>>>>>>> 2.157e+08
>>>>>>>>>>>>> MPI Messages:         0.000e+00      0.00000   0.000e+00
>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00
>>>>>>>>>>>>> 0.000e+00
>>>>>>>>>>>>> MPI Reductions:       0.000e+00      0.00000
>>>>>>>>>>>>> Flop counting convention: 1 flop = 1 real number operation of
>>>>>>>>>>>>> type (multiply/divide/add/subtract)
>>>>>>>>>>>>>                             e.g., VecAXPY() for real vectors
>>>>>>>>>>>>> of length N --> 2N flop
>>>>>>>>>>>>>                             and VecAXPY() for complex vectors
>>>>>>>>>>>>> of length N --> 8N flop
>>>>>>>>>>>>> Summary of Stages:   ----- Time ------  ----- Flop -----  ---
>>>>>>>>>>>>> Messages ---  -- Message Lengths --  -- Reductions --
>>>>>>>>>>>>>                         Avg     %Total     Avg     %Total
>>>>>>>>>>>>>  counts   %Total     Avg         %Total   counts   %Total
>>>>>>>>>>>>>  0:      Main Stage: 4.5729e+00 100.0%  3.4924e+07 100.0%
>>>>>>>>>>>>> 0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>>>>>>>>>>>>> See the 'Profiling' chapter of the users' manual for details
>>>>>>>>>>>>> on interpreting output.
>>>>>>>>>>>>> Phase summary info:
>>>>>>>>>>>>>    Count: number of times phase was executed
>>>>>>>>>>>>>    Time and Flop: Max - maximum over all processors
>>>>>>>>>>>>>                    Ratio - ratio of maximum to minimum over
>>>>>>>>>>>>> all processors
>>>>>>>>>>>>>    Mess: number of messages sent
>>>>>>>>>>>>>    Avg. len: average message length (bytes)
>>>>>>>>>>>>>    Reduct: number of global reductions
>>>>>>>>>>>>>    Global: entire computation
>>>>>>>>>>>>>    Stage: stages of a computation. Set stages with
>>>>>>>>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>>>>>>>>>       %T - percent time in this phase         %F - percent
>>>>>>>>>>>>> flop in this phase
>>>>>>>>>>>>>       %M - percent messages in this phase     %L - percent
>>>>>>>>>>>>> message lengths in this phase
>>>>>>>>>>>>>       %R - percent reductions in this phase
>>>>>>>>>>>>>    Total Mflop/s: 10e-6 * (sum of flop over all
>>>>>>>>>>>>> processors)/(max time over all processors)
>>>>>>>>>>>>>       #                          WARNING!!!
>>>>>>>>>>>>>       #   This code was compiled with a debugging option,
>>>>>>>>>>>>>       #   To get timing results run ./configure
>>>>>>>>>>>>>       #   using --with-debugging=no, the performance will
>>>>>>>>>>>>>       #   be generally two or three times faster.
>>>>>>>>>>>>> Event                Count      Time (sec)     Flop
>>>>>>>>>>>>>                  --- Global ---  --- Stage ---   Total
>>>>>>>>>>>>>                    Max Ratio  Max     Ratio   Max  Ratio
>>>>>>>>>>>>> Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>>>>>>>>>>> --- Event Stage 0: Main Stage
>>>>>>>>>>>>> MatLUFactorNum         1 1.0 4.9502e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  1100  0  0  0   1100  0  0  0   706
>>>>>>>>>>>>> MatILUFactorSym        1 1.0 1.9642e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>>>>>>>>>> MatAssemblyBegin       2 1.0 6.9141e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>> MatAssemblyEnd         2 1.0 2.6612e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
>>>>>>>>>>>>> MatGetRowIJ            1 1.0 5.0068e-06 1.0 0.00e+00 0.0
>>>>>>>>>>>>> MatGetOrdering         1 1.0 1.7186e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>> MatLoad                1 1.0 1.1575e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>>>>>>>>>>>>> MatView                1 1.0 8.0877e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>>>>>>>>>>> MatCUSPCopyTo          1 1.0 2.4664e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
>>>>>>>>>>>>> VecSet                68 1.0 5.1665e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>>>>>>>>>>>>> VecAssemblyBegin      17 1.0 5.2691e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>> VecAssemblyEnd        17 1.0 4.3631e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>> VecScatterBegin       15 1.0 1.5345e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>> VecCUSPCopyFrom        1 1.0 1.1199e-03 1.0 0.00e+00 0.0
>>>>>>>>>>>>> KSPSetUp               1 1.0 5.1929e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>> PCSetUp                2 1.0 8.6590e-02 1.0 3.49e+07 1.0
>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00  2100  0  0  0   2100  0  0  0   403
>>>>>>>>>>>>> Memory usage is given in bytes:
>>>>>>>>>>>>> Object Type          Creations   Destructions     Memory
>>>>>>>>>>>>> Descendants' Mem.
>>>>>>>>>>>>> Reports information only for process 0.
>>>>>>>>>>>>>               Matrix     3              1     52856972     0.
>>>>>>>>>>>>>    Matrix Null Space     1              1          608     0.
>>>>>>>>>>>>>               Vector    66              3      3414600     0.
>>>>>>>>>>>>>       Vector Scatter     1              1          680     0.
>>>>>>>>>>>>>               Viewer     3              2         1680     0.
>>>>>>>>>>>>>        Krylov Solver     1              0            0     0.
>>>>>>>>>>>>>       Preconditioner     2              1          864     0.
>>>>>>>>>>>>>            Index Set     4              1          800     0.
>>>>>>>>>>>>> Average time to get PetscTime(): 9.53674e-08
>>>>>>>>>>>>> #PETSc Option Table entries:
>>>>>>>>>>>>> -ksp_view
>>>>>>>>>>>>> -log_view
>>>>>>>>>>>>> -matload_block_size 1
>>>>>>>>>>>>> -vec_type cusp
>>>>>>>>>>>>> #End of PETSc Option Table entries
>>>>>>>>>>>>> Compiled without FORTRAN kernels
>>>>>>>>>>>>> Compiled with full precision matrices (default)
>>>>>>>>>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>>>>>>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>>>>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc
>>>>>>>>>>>>> Libraries compiled on Mon Mar  5 16:37:18 2018 on node50
>>>>>>>>>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>>>>>>>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>>>>>>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>>>>>>>>> Using PETSc arch: cuda
>>>>>>>>>>>>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
>>>>>>>>>>>>> -fvisibility=hidden -O3
>>>>>>>>>>>>> Using Fortran compiler: mpifort  -fPIC -Wall
>>>>>>>>>>>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>>>>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>>>>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>>>>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>>>>>>>>> Using C linker: mpicc
>>>>>>>>>>>>> Using Fortran linker: mpifort
>>>>>>>>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>>>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>>>>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack
>>>>>>>>>>>>> -lfblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl
>>>>>>>>>>>>> -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
>>>>>>>>>>>>> -lquadmath -lpthread -lstdc++ -ldl
>>>>>>>>>>>>> Thanks for your help,
>>>>>>>>>>>>> Manuel
>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/97429697/attachment-0001.html>
