[petsc-users] Tweaking my code for CUDA
Wed Mar 14 13:36:21 CDT 2018
On Thu, Mar 15, 2018 at 3:25 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
wrote:
> yeah that worked,
> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcuda -dm_mat_type
> seqaijcusparse
> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
> Number of SNES iterations = 2
> How do i make sure the other program refer to this installation? using the
> same arguments there i get:
> [valera at node50 alone]$ ./linsolve -vec_type seqcuda -mat_type
> seqaijcusparse
>  laplacian.petsc !
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing package:
> http://www.mcs.anl.gov/petsc/documentation/installation.html#external
> [0]PETSC ERROR: Unknown vector type: seqcuda
This PETSc has not been configured with CUDA. It is located in
/home/valera/petsc.
The other
one you used is located in  /home/valera/testpetsc. It does not make much
sense to me that
it does not understand CUDA since it says the configure arguments had
--with-cuda=1. There
must have been a build problem. Rebuild
  cd $PETSC_DIR
  make all
If you still have a problem, reconfigure
  cd $PETSC_DIR
  ./cuda/lib/petsc/conf/reconfigure-cuda.py
  make all
If that still fails, then something very bizarre is happening on your
machine and we will have
to exchange more mail.
  Matt
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a  GIT
> Date: 2018-02-28 10:19:08 -0600
> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
> 11:25:11 2018
> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
> [0]PETSC ERROR: #1 VecSetType() line 42 in /home/valera/petsc/src/vec/
> vec/interface/vecreg.c
> [0]PETSC ERROR: #2 VecSetTypeFromOptions_Private() line 1241 in
> /home/valera/petsc/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #3 VecSetFromOptions() line 1276 in
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Vec object's type is not set: Argument # 1
> 11:25:11 2018
> [0]PETSC ERROR: #4 VecDuplicate() line 375 in /home/valera/petsc/src/vec/
> 11:25:11 2018
> [0]PETSC ERROR: #5 VecDuplicate() line 375 in /home/valera/petsc/src/vec/
> [0]PETSC ERROR: #6 User provided function() line 0 in User file
> I made sure there is a call for Vec/MatSetFromOptions() there, i am
> loading the matrix from a petsc binary in this case,
> Thanks,
> On Wed, Mar 14, 2018 at 11:22 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Mar 15, 2018 at 3:19 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>> wrote:
>>> Yes, this is the system installation that is being correctly linked (the
>>> linear solver and model are not linking the correct installation idk why
>>> yet) i configured with only CUDA this time because of the message Karl Rupp
>>> posted on my installation thread, where he says only one type of library
>>> will work at a time, anyway this is what i got:
>>> seqaijcusp
>>> package: http://www.mcs.anl.gov/petsc/documentation/installation.html
>>> #external
>>> [0]PETSC ERROR: Unknown Mat type given: seqaijcusp
>> It is telling you the problem. Use
>>   -dm_mat_type seqaijcusparse
>>    Matt
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab
>>> GIT Date: 2018-03-12 13:30:25 -0500
>>> [0]PETSC ERROR: ./ex19 on a  named node50 by valera Wed Mar 14 11:17:25
>>> 2018
>>> [0]PETSC ERROR: Configure options --prefix=/usr/local/petsc.cod/petsc-install
>>> --with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
>>> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
>>> --download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
>>> [0]PETSC ERROR: #1 MatSetType() line 61 in /home/valera/testpetsc/src/mat
>>> /interface/matreg.c
>>> [0]PETSC ERROR: #2 DMCreateMatrix_DA() line 693 in
>>> /home/valera/testpetsc/src/dm/impls/da/fdda.c
>>> [0]PETSC ERROR: #3 DMCreateMatrix() line 1199 in
>>> /home/valera/testpetsc/src/dm/interface/dm.c
>>> [0]PETSC ERROR: #4 SNESSetUpMatrices() line 646 in
>>> /home/valera/testpetsc/src/snes/interface/snes.c
>>> [0]PETSC ERROR: #5 SNESSetUp_NEWTONLS() line 296 in
>>> /home/valera/testpetsc/src/snes/impls/ls/ls.c
>>> [0]PETSC ERROR: #6 SNESSetUp() line 2795 in
>>> [0]PETSC ERROR: #7 SNESSolve() line 4187 in
>>> [0]PETSC ERROR: #8 main() line 161 in /home/valera/testpetsc/src/sne
>>> s/examples/tutorials/ex19.c
>>> [0]PETSC ERROR: PETSc Option Table entries:
>>> [0]PETSC ERROR: -dm_mat_type seqaijcusp
>>> [0]PETSC ERROR: -dm_vec_type seqcuda
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>> with errorcode 86.
>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> You may or may not see output from other processes, depending on
>>> exactly when Open MPI kills them.
>>> On Wed, Mar 14, 2018 at 11:16 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Mar 15, 2018 at 3:12 AM, Manuel Valera <mvalera-w at mail.sdsu.edu
>>>> > wrote:
>>>>> Thanks, got this error:
>>>> Did you not configure with CUSP? It looks like you have CUDA, so use
>>>>   Thanks,
>>>>     Matt
>>>>> [valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
>>>>> [valera at node50 tutorials]$ PETSC_ARCH="" make ex19
>>>>> /usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>> -fvisibility=hidden -O2   -I/home/valera/testpetsc/include
>>>>> -I/home/valera/testpetsc/arch-linux2-c-opt/include
>>>>> -I/usr/local/petsc.cod/petsc-install/include
>>>>> -I/usr/local/cuda/include -I/usr/lib64/openmpi/include    `pwd`/ex19.c
>>>>> /usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings
>>>>> -fvisibility=hidden -O2  -o ex19  ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
>>>>> -Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
>>>>> -L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64
>>>>> -L/usr/lib64 -Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64
>>>>> -L/usr/lib64/openmpi/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>> -Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack -lblas -lm
>>>>> -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>>> -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>>>>> -lpthread -lstdc++ -ldl
>>>>> /usr/bin/rm -f ex19.o
>>>>> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp -dm_mat_type
>>>>> seqaijcusp
>>>>> #external
>>>>> [0]PETSC ERROR: Unknown vector type: seqcusp
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> 11:12:11 2018
>>>>> /home/valera/testpetsc/src/vec/vec/interface/vecreg.c
>>>>> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
>>>>> /home/valera/testpetsc/src/dm/impls/da/dadist.c
>>>>> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
>>>>> [0]PETSC ERROR: #4 main() line 158 in /home/valera/testpetsc/src/sne
>>>>> [0]PETSC ERROR: -dm_vec_type seqcusp
>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>> with errorcode 86.
>>>>> On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <
>>>>>> mvalera-w at mail.sdsu.edu> wrote:
>>>>>>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>>>>>>> -linux2-c-opt/tests/src/snes/examples/tutorials there is runex19.sh
>>>>>>> and a lot of other ex19 variantes, but if i run that i get:
>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$ pushd
>>>>>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>>>>>> PETSC_ARCH=arch-master-debug make ex19
>>>>>> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> [valera at node50 tutorials]$ ./runex19.sh
>>>>>>> not ok snes_tutorials-ex19_1
>>>>>>> # mpiexec was unable to launch the specified application as it
>>>>>>> could not access
>>>>>>> # or execute an executable:
>>>>>>> # Executable: ../ex19
>>>>>>> # Node: node50
>>>>>>> # while attempting to start process rank 0.
>>>>>>> # 2 total processes failed to start
>>>>>>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>>>>>>> is this the one i should be running ?
>>>>>>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <knepley at gmail.com
>>>>>>> > wrote:
>>>>>>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <
>>>>>>>>> Ok thanks Matt, i made a smaller case with only the linear solver
>>>>>>>>> and a 25x25 matrix, the error i have in this case is:
>>>>>>>> Ah, it appears that not all parts of your problem are taking the
>>>>>>>> type options. If you want the
>>>>>>>> linear algebra objects to change type, you need to have
>>>>>>>>   VecSetFromOptions()  and MatSetFromOptions()
>>>>>>>> called after you create them, but before sizes are set and data is
>>>>>>>> entered. However, it should
>>>>>>>> not be possible to have a seq Vec with the seqcusp AXPY routine
>>>>>>>> set. Something else is wrong...
>>>>>>>> Did you try a PETSc example, such as SNES ex19, with this?
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp
>>>>>>>>> -mat_type aijcusparse
>>>>>>>>>  laplacian.petsc !
>>>>>>>>>  TrivSoln loaded, size:          125 /         125
>>>>>>>>>  RHS loaded, size:          125 /         125
>>>>>>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>>>>>>> v3.8.3-1817-g96b6f8a  GIT Date: 2018-02-28 10:19:08 -0600
>>>>>>>>> Mar 14 10:24:35 2018
>>>>>>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>>>>>>> [0]PETSC ERROR: Invalid argument
>>>>>>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>>>>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>>>>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>>>>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in
>>>>>>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>>>>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>>>>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>>>>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in
>>>>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>  soln maxval:   0.0000000000000000
>>>>>>>>>  soln minval:   0.0000000000000000
>>>>>>>>>  Norm:   11.180339887498949
>>>>>>>>>  Its:           0
>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>> Option left: name:-mat_type value: aijcusparse
>>>>>>>>> I also see the configure options are not correct, so i guess is
>>>>>>>>> still linking a different petsc installation, but maybe we can try to make
>>>>>>>>> it work as it is, i will let you know if i am able to link the correct
>>>>>>>>> petsc installation here,
>>>>>>>>> Best,
>>>>>>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <
>>>>>>>>>>> Hello all,
>>>>>>>>>>> I am working on porting a linear solver into GPUs for timing
>>>>>>>>>>> purposes, so far i've been able to compile and run the CUSP libraries and
>>>>>>>>>>> compile PETSc to be used with CUSP and ViennaCL, after the initial runs i
>>>>>>>>>>> noticed some errors, they are different for different flags and i would
>>>>>>>>>>> appreciate any help interpreting them,
>>>>>>>>>>> The only elements in this program that use PETSc are the
>>>>>>>>>>> laplacian matrix (sparse), the RHS and X vectors and a scatter petsc
>>>>>>>>>>> object, so i would say it's safe to pass the command line arguments for the
>>>>>>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>>>>>>> These systems do not properly propagate errors. My only advice is
>>>>>>>>>> to run a smaller problem and see.
>>>>>>>>>>> [0]PETSC ERROR: ------------------------------
>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>> ocumentation/faq.html#valgrind
>>>>>>>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>>>>>>> Apple Mac OS X to find memory corruption errors
>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are
>>>>>>>>>>> not available,
>>>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of
>>>>>>>>>>> the function
>>>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetType line 36
>>>>>>>>>>> /home/valera/petsc/src/vec/vec/interface/vecreg.c
>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>>>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by valera
>>>>>>>>>>> Thu Mar  8 09:50:51 2018
>>>>>>>>>>> --with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3
>>>>>>>>>>> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-shared-libraries=1
>>>>>>>>>>> --with-debugging=1 --with-cuda=1 --with-cuda-arch=sm_60 --with-cusp=1
>>>>>>>>>>> --with-cusp-dir=/home/valera/cusp --with-vienacl=1
>>>>>>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in  unknown
>>>>>>>>>>> file
>>>>>>>>>>> This seems to be a memory out of range, maybe my vector is too
>>>>>>>>>>> big for my CUDA system? how do i assess that?
>>>>>>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get
>>>>>>>>>>> something different and more interesting:
>>>>>>>>>> We need to see the entire error message, since it has the stack.
>>>>>>>>>> This seems like a logic error, but could definitely be on our
>>>>>>>>>> end. Here is how I think about these:
>>>>>>>>>>   1) We have nightly test solves, so at least some solver
>>>>>>>>>> configuration works
>>>>>>>>>>   2) Some vector which is marked read-only (happens for input to
>>>>>>>>>> solvers), but someone is trying to update it.
>>>>>>>>>>       The stack will tell me where this is happening.
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> [0]PETSC ERROR:  Vec is locked read only, argument # 3
>>>>>>>>>>> Thu Mar  8 10:02:19 2018
>>>>>>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>>>>>>>  PETSC_SOLVER_ONLY   6.8672990892082453E-005 s
>>>>>>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>>>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscatterc
>>>>>>>>>>> usp.cu
>>>>>>>>>>> And it yields a "solution" to the system and also a log at the
>>>>>>>>>>> end:
>>>>>>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by valera
>>>>>>>>>>> Thu Mar  8 10:02:24 2018
>>>>>>>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a  GIT
>>>>>>>>>>>                          Max       Max/Min        Avg      Total
>>>>>>>>>>> Time (sec):           4.573e+00      1.00000   4.573e+00
>>>>>>>>>>> Objects:              8.100e+01      1.00000   8.100e+01
>>>>>>>>>>> Flop:                 3.492e+07      1.00000   3.492e+07
>>>>>>>>>>> 3.492e+07
>>>>>>>>>>> Flop/sec:            7.637e+06      1.00000   7.637e+06
>>>>>>>>>>> 7.637e+06
>>>>>>>>>>> Memory:               2.157e+08      1.00000
>>>>>>>>>>> 2.157e+08
>>>>>>>>>>> MPI Messages:         0.000e+00      0.00000   0.000e+00
>>>>>>>>>>> 0.000e+00
>>>>>>>>>>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00
>>>>>>>>>>> 0.000e+00
>>>>>>>>>>> MPI Reductions:       0.000e+00      0.00000
>>>>>>>>>>> Flop counting convention: 1 flop = 1 real number operation of
>>>>>>>>>>> type (multiply/divide/add/subtract)
>>>>>>>>>>>                             e.g., VecAXPY() for real vectors of
>>>>>>>>>>> length N --> 2N flop
>>>>>>>>>>>                             and VecAXPY() for complex vectors of
>>>>>>>>>>> length N --> 8N flop
>>>>>>>>>>> Summary of Stages:   ----- Time ------  ----- Flop -----  ---
>>>>>>>>>>> Messages ---  -- Message Lengths --  -- Reductions --
>>>>>>>>>>>                         Avg     %Total     Avg     %Total
>>>>>>>>>>>  counts   %Total     Avg         %Total   counts   %Total
>>>>>>>>>>>  0:      Main Stage: 4.5729e+00 100.0%  3.4924e+07 100.0%
>>>>>>>>>>> 0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>>>>>>>>>>> See the 'Profiling' chapter of the users' manual for details on
>>>>>>>>>>> interpreting output.
>>>>>>>>>>> Phase summary info:
>>>>>>>>>>>    Count: number of times phase was executed
>>>>>>>>>>>    Time and Flop: Max - maximum over all processors
>>>>>>>>>>>                    Ratio - ratio of maximum to minimum over all
>>>>>>>>>>> processors
>>>>>>>>>>>    Mess: number of messages sent
>>>>>>>>>>>    Avg. len: average message length (bytes)
>>>>>>>>>>>    Reduct: number of global reductions
>>>>>>>>>>>    Global: entire computation
>>>>>>>>>>>    Stage: stages of a computation. Set stages with
>>>>>>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>>>>>>>       %T - percent time in this phase         %F - percent flop
>>>>>>>>>>> in this phase
>>>>>>>>>>>       %M - percent messages in this phase     %L - percent
>>>>>>>>>>> message lengths in this phase
>>>>>>>>>>>       %R - percent reductions in this phase
>>>>>>>>>>>    Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max
>>>>>>>>>>> time over all processors)
>>>>>>>>>>>       #                          WARNING!!!                    #
>>>>>>>>>>>       #   This code was compiled with a debugging option,      #
>>>>>>>>>>>       #   To get timing results run ./configure                #
>>>>>>>>>>>       #   using --with-debugging=no, the performance will      #
>>>>>>>>>>>       #   be generally two or three times faster.              #
>>>>>>>>>>> Event                Count      Time (sec)     Flop
>>>>>>>>>>>                --- Global ---  --- Stage ---   Total
>>>>>>>>>>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess
>>>>>>>>>>>  Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>>>>>>>>> --- Event Stage 0: Main Stage
>>>>>>>>>>> MatLUFactorNum         1 1.0 4.9502e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  1100  0  0  0   1100  0  0  0   706
>>>>>>>>>>> MatILUFactorSym        1 1.0 1.9642e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>>>>>>>> MatAssemblyBegin       2 1.0 6.9141e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> MatAssemblyEnd         2 1.0 2.6612e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
>>>>>>>>>>> MatGetRowIJ            1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> MatGetOrdering         1 1.0 1.7186e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> MatLoad                1 1.0 1.1575e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>>>>>>>>>>> MatView                1 1.0 8.0877e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>>>>>>>>> MatCUSPCopyTo          1 1.0 2.4664e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
>>>>>>>>>>> VecSet                68 1.0 5.1665e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>>>>>>>>>>> VecAssemblyBegin      17 1.0 5.2691e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> VecAssemblyEnd        17 1.0 4.3631e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> VecScatterBegin       15 1.0 1.5345e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> VecCUSPCopyFrom        1 1.0 1.1199e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> KSPSetUp               1 1.0 5.1929e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>>>>>> PCSetUp                2 1.0 8.6590e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>>>>>>>> 0.0e+00 0.0e+00  2100  0  0  0   2100  0  0  0   403
>>>>>>>>>>> Memory usage is given in bytes:
>>>>>>>>>>> Object Type          Creations   Destructions     Memory
>>>>>>>>>>> Descendants' Mem.
>>>>>>>>>>> Reports information only for process 0.
>>>>>>>>>>>               Matrix     3              1     52856972     0.
>>>>>>>>>>>    Matrix Null Space     1              1          608     0.
>>>>>>>>>>>               Vector    66              3      3414600     0.
>>>>>>>>>>>       Vector Scatter     1              1          680     0.
>>>>>>>>>>>               Viewer     3              2         1680     0.
>>>>>>>>>>>        Krylov Solver     1              0            0     0.
>>>>>>>>>>>       Preconditioner     2              1          864     0.
>>>>>>>>>>>            Index Set     4              1          800     0.
>>>>>>>>>>> Average time to get PetscTime(): 9.53674e-08
>>>>>>>>>>> #PETSc Option Table entries:
>>>>>>>>>>> -ksp_view
>>>>>>>>>>> -log_view
>>>>>>>>>>> -matload_block_size 1
>>>>>>>>>>> -vec_type cusp
>>>>>>>>>>> #End of PETSc Option Table entries
>>>>>>>>>>> Compiled without FORTRAN kernels
>>>>>>>>>>> Compiled with full precision matrices (default)
>>>>>>>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>>>>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc
>>>>>>>>>>> Libraries compiled on Mon Mar  5 16:37:18 2018 on node50
>>>>>>>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>>>>>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>>>>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>>>>>>> Using PETSc arch: cuda
>>>>>>>>>>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
>>>>>>>>>>> -fvisibility=hidden -O3
>>>>>>>>>>> Using Fortran compiler: mpifort  -fPIC -Wall
>>>>>>>>>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>>>>>>> Using C linker: mpicc
>>>>>>>>>>> Using Fortran linker: mpifort
>>>>>>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack
>>>>>>>>>>> -lfblas -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl
>>>>>>>>>>> -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
>>>>>>>>>>> -lquadmath -lpthread -lstdc++ -ldl
>>>>>>>>>>> Thanks for your help,
>>>>>>>>>>> Manuel
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/6b21907c/attachment-0001.html>
