[petsc-users] Tweaking my code for CUDA
Manuel Valera
mvalera-w at mail.sdsu.edu
Wed Mar 14 13:12:39 CDT 2018
Thanks, got this error:
[valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
[valera at node50 tutorials]$ PETSC_ARCH="" make ex19
/usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
-fvisibility=hidden -O2 -I/home/valera/testpetsc/include
-I/home/valera/testpetsc/arch-linux2-c-opt/include
-I/usr/local/petsc.cod/petsc-install/include -I/usr/local/cuda/include
-I/usr/lib64/openmpi/include `pwd`/ex19.c
/usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O2 -o ex19
ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
-Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
-L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64 -L/usr/lib64
-Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64
-L/usr/lib64/openmpi/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
-Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack -lblas -lm
-lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
-lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
-lpthread -lstdc++ -ldl
/usr/bin/rm -f ex19.o
[valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp -dm_mat_type
seqaijcusp
lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Unknown type. Check for miss-spelling or missing package:
http://www.mcs.anl.gov/petsc/documentation/installation.html#external
[0]PETSC ERROR: Unknown vector type: seqcusp
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab GIT
Date: 2018-03-12 13:30:25 -0500
[0]PETSC ERROR: ./ex19 on a named node50 by valera Wed Mar 14 11:12:11 2018
[0]PETSC ERROR: Configure options
--prefix=/usr/local/petsc.cod/petsc-install
--with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
--download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
[0]PETSC ERROR: #1 VecSetType() line 42 in
/home/valera/testpetsc/src/vec/vec/interface/vecreg.c
[0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
/home/valera/testpetsc/src/dm/impls/da/dadist.c
[0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
/home/valera/testpetsc/src/dm/interface/dm.c
[0]PETSC ERROR: #4 main() line 158 in
/home/valera/testpetsc/src/snes/examples/tutorials/ex19.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -dm_mat_type seqaijcusp
[0]PETSC ERROR: -dm_vec_type seqcusp
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 86.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
> wrote:
>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>> -linux2-c-opt/tests/src/snes/examples/tutorials there is runex19.sh and
>> a lot of other ex19 variantes, but if i run that i get:
> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$ pushd
> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
> PETSC_ARCH=arch-master-debug make ex19
> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
> Thanks,
> Matt
>> [valera at node50 tutorials]$ ./runex19.sh
>> not ok snes_tutorials-ex19_1
>> # mpiexec was unable to launch the specified application as it could not
>> access
>> # or execute an executable:
>> # Executable: ../ex19
>> # Node: node50
>> # while attempting to start process rank 0.
>> # 2 total processes failed to start
>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>> is this the one i should be running ?
>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>>> wrote:
>>>> Ok thanks Matt, i made a smaller case with only the linear solver and a
>>>> 25x25 matrix, the error i have in this case is:
>>> Ah, it appears that not all parts of your problem are taking the type
>>> options. If you want the
>>> linear algebra objects to change type, you need to have
>>> VecSetFromOptions() and MatSetFromOptions()
>>> called after you create them, but before sizes are set and data is
>>> entered. However, it should
>>> not be possible to have a seq Vec with the seqcusp AXPY routine set.
>>> Something else is wrong...
>>> Did you try a PETSc example, such as SNES ex19, with this?
>>> Thanks,
>>> Matt
>>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp -mat_type
>>>> aijcusparse
>>>> laplacian.petsc !
>>>> TrivSoln loaded, size: 125 / 125
>>>> RHS loaded, size: 125 / 125
>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>> for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>>> GIT Date: 2018-02-28 10:19:08 -0600
>>>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
>>>> 10:24:35 2018
>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>>>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>>>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>> [0]PETSC ERROR: Invalid argument
>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>> 10:24:35 2018
>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in /home/valera/petsc/src/vec/vec
>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in /home/valera/petsc/src/ksp/ksp
>>>> /interface/itfunc.c
>>>> soln maxval: 0.0000000000000000
>>>> soln minval: 0.0000000000000000
>>>> Norm: 11.180339887498949
>>>> Its: 0
>>>> WARNING! There are options you set that were not used!
>>>> WARNING! could be spelling mistake, etc!
>>>> Option left: name:-mat_type value: aijcusparse
>>>> I also see the configure options are not correct, so i guess is still
>>>> linking a different petsc installation, but maybe we can try to make it
>>>> work as it is, i will let you know if i am able to link the correct petsc
>>>> installation here,
>>>> Best,
>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <mvalera-w at mail.sdsu.edu
>>>>> > wrote:
>>>>>> Hello all,
>>>>>> I am working on porting a linear solver into GPUs for timing
>>>>>> purposes, so far i've been able to compile and run the CUSP libraries and
>>>>>> compile PETSc to be used with CUSP and ViennaCL, after the initial runs i
>>>>>> noticed some errors, they are different for different flags and i would
>>>>>> appreciate any help interpreting them,
>>>>>> The only elements in this program that use PETSc are the laplacian
>>>>>> matrix (sparse), the RHS and X vectors and a scatter petsc object, so i
>>>>>> would say it's safe to pass the command line arguments for the
>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>> These systems do not properly propagate errors. My only advice is to
>>>>> run a smaller problem and see.
>>>>>> [0]PETSC ERROR: ------------------------------
>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>>>> probably memory access out of range
>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>> -on_error_attach_debugger
>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>> ocumentation/faq.html#valgrind
>>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>>>> Mac OS X to find memory corruption errors
>>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>>> [0]PETSC ERROR: --------------------- Stack Frames
>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>> available,
>>>>>> [0]PETSC ERROR: INSTEAD the line number of the start of the
>>>>>> function
>>>>>> [0]PETSC ERROR: is given.
>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>> [0]PETSC ERROR: [0] VecSetType line 36 /home/valera/petsc/src/vec/vec
>>>>>> /interface/vecreg.c
>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>> [0]PETSC ERROR: Signal received
>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by valera Thu
>>>>>> Mar 8 09:50:51 2018
>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in unknown file
>>>>>> This seems to be a memory out of range, maybe my vector is too big
>>>>>> for my CUDA system? how do i assess that?
>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get
>>>>>> something different and more interesting:
>>>>> We need to see the entire error message, since it has the stack.
>>>>> This seems like a logic error, but could definitely be on our end.
>>>>> Here is how I think about these:
>>>>> 1) We have nightly test solves, so at least some solver
>>>>> configuration works
>>>>> 2) Some vector which is marked read-only (happens for input to
>>>>> solvers), but someone is trying to update it.
>>>>> The stack will tell me where this is happening.
>>>>> Thanks,
>>>>> Matt
>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>> [0]PETSC ERROR: Vec is locked read only, argument # 3
>>>>>> Mar 8 10:02:19 2018
>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>> PETSC_SOLVER_ONLY 6.8672990892082453E-005 s
>>>>>> Mar 8 10:02:19 2018
>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscattercusp.cu
>>>>>> And it yields a "solution" to the system and also a log at the end:
>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by valera Thu
>>>>>> Mar 8 10:02:24 2018
>>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a GIT Date:
>>>>>> Max Max/Min Avg Total
>>>>>> Time (sec): 4.573e+00 1.00000 4.573e+00
>>>>>> Objects: 8.100e+01 1.00000 8.100e+01
>>>>>> Flop: 3.492e+07 1.00000 3.492e+07 3.492e+07
>>>>>> Flop/sec: 7.637e+06 1.00000 7.637e+06 7.637e+06
>>>>>> Memory: 2.157e+08 1.00000 2.157e+08
>>>>>> MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
>>>>>> MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
>>>>>> MPI Reductions: 0.000e+00 0.00000
>>>>>> Flop counting convention: 1 flop = 1 real number operation of type
>>>>>> (multiply/divide/add/subtract)
>>>>>> e.g., VecAXPY() for real vectors of
>>>>>> length N --> 2N flop
>>>>>> and VecAXPY() for complex vectors of
>>>>>> length N --> 8N flop
>>>>>> Summary of Stages: ----- Time ------ ----- Flop ----- ---
>>>>>> Messages --- -- Message Lengths -- -- Reductions --
>>>>>> Avg %Total Avg %Total counts
>>>>>> %Total Avg %Total counts %Total
>>>>>> 0: Main Stage: 4.5729e+00 100.0% 3.4924e+07 100.0% 0.000e+00
>>>>>> 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
>>>>>> See the 'Profiling' chapter of the users' manual for details on
>>>>>> interpreting output.
>>>>>> Phase summary info:
>>>>>> Count: number of times phase was executed
>>>>>> Time and Flop: Max - maximum over all processors
>>>>>> Ratio - ratio of maximum to minimum over all
>>>>>> processors
>>>>>> Mess: number of messages sent
>>>>>> Avg. len: average message length (bytes)
>>>>>> Reduct: number of global reductions
>>>>>> Global: entire computation
>>>>>> Stage: stages of a computation. Set stages with
>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>> %T - percent time in this phase %F - percent flop in
>>>>>> this phase
>>>>>> %M - percent messages in this phase %L - percent message
>>>>>> lengths in this phase
>>>>>> %R - percent reductions in this phase
>>>>>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>>>>>> # WARNING!!! #
>>>>>> # This code was compiled with a debugging option, #
>>>>>> # To get timing results run ./configure #
>>>>>> # using --with-debugging=no, the performance will #
>>>>>> # be generally two or three times faster. #
>>>>>> Event Count Time (sec) Flop
>>>>>> --- Global --- --- Stage --- Total
>>>>>> Max Ratio Max Ratio Max Ratio Mess Avg
>>>>>> len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>>>>>> --- Event Stage 0: Main Stage
>>>>>> MatLUFactorNum 1 1.0 4.9502e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 1100 0 0 0 1100 0 0 0 706
>>>>>> MatILUFactorSym 1 1.0 1.9642e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>>> MatAssemblyBegin 2 1.0 6.9141e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>>> MatAssemblyEnd 2 1.0 2.6612e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 6 0 0 0 0 6 0 0 0 0 0
>>>>>> MatGetRowIJ 1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>>> MatGetOrdering 1 1.0 1.7186e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>> MatLoad 1 1.0 1.1575e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
>>>>>> MatView 1 1.0 8.0877e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
>>>>>> MatCUSPCopyTo 1 1.0 2.4664e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 5 0 0 0 0 5 0 0 0 0 0
>>>>>> VecSet 68 1.0 5.1665e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>>> VecAssemblyBegin 17 1.0 5.2691e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>>> VecAssemblyEnd 17 1.0 4.3631e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>>> VecScatterBegin 15 1.0 1.5345e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>>> VecCUSPCopyFrom 1 1.0 1.1199e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>>> KSPSetUp 1 1.0 5.1929e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>> PCSetUp 2 1.0 8.6590e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 2100 0 0 0 2100 0 0 0 403
>>>>>> Memory usage is given in bytes:
>>>>>> Object Type Creations Destructions Memory
>>>>>> Descendants' Mem.
>>>>>> Reports information only for process 0.
>>>>>> Matrix 3 1 52856972 0.
>>>>>> Matrix Null Space 1 1 608 0.
>>>>>> Vector 66 3 3414600 0.
>>>>>> Vector Scatter 1 1 680 0.
>>>>>> Viewer 3 2 1680 0.
>>>>>> Krylov Solver 1 0 0 0.
>>>>>> Preconditioner 2 1 864 0.
>>>>>> Index Set 4 1 800 0.
>>>>>> Average time to get PetscTime(): 9.53674e-08
>>>>>> #PETSc Option Table entries:
>>>>>> -ksp_view
>>>>>> -log_view
>>>>>> -matload_block_size 1
>>>>>> -vec_type cusp
>>>>>> #End of PETSc Option Table entries
>>>>>> Compiled without FORTRAN kernels
>>>>>> Compiled with full precision matrices (default)
>>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc --with-cxx=mpic++
>>>>>> --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>>>> Libraries compiled on Mon Mar 5 16:37:18 2018 on node50
>>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>> Using PETSc arch: cuda
>>>>>> Using C compiler: mpicc -fPIC -Wall -Wwrite-strings
>>>>>> -fvisibility=hidden -O3
>>>>>> Using Fortran compiler: mpifort -fPIC -Wall -ffree-line-length-0
>>>>>> -Wno-unused-dummy-argument -O3
>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>> Using C linker: mpicc
>>>>>> Using Fortran linker: mpifort
>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack -lfblas
>>>>>> -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>>>> Thanks for your help,
>>>>>> Manuel
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.caam.rice.edu/~mk51/>
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180314/a52d7494/attachment-0001.html>
