[petsc-users] Tweaking my code for CUDA
Wed Mar 14 13:16:55 CDT 2018
On Thu, Mar 15, 2018 at 3:12 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
wrote:
> Thanks, got this error:
Did you not configure with CUSP? It looks like you have CUDA, so use
  -dm_vec_type seqcuda
    Matt
> [valera at node50 testpetsc]$ cd src/snes/examples/tutorials/
> [valera at node50 tutorials]$ PETSC_ARCH="" make ex19
> /usr/lib64/openmpi/bin/mpicc -o ex19.o -c -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
> -fvisibility=hidden -O2   -I/home/valera/testpetsc/include
> -I/home/valera/testpetsc/arch-linux2-c-opt/include
> -I/usr/local/petsc.cod/petsc-install/include -I/usr/local/cuda/include
> -I/usr/lib64/openmpi/include    `pwd`/ex19.c
> /usr/lib64/openmpi/bin/mpicc -Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O2  -o ex19
> ex19.o -L/home/valera/testpetsc/arch-linux2-c-opt/lib
> -Wl,-rpath,/usr/local/petsc.cod/petsc-install/lib
> -L/usr/local/petsc.cod/petsc-install/lib -Wl,-rpath,/usr/lib64
> -L/usr/lib64 -Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64
> -L/usr/lib64/openmpi/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
> -Wl,-rpath,/usr/lib64/openmpi/lib -lpetsc -lHYPRE -llapack -lblas -lm
> -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
> -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
> -lpthread -lstdc++ -ldl
> /usr/bin/rm -f ex19.o
> [valera at node50 tutorials]$ ./ex19 -dm_vec_type seqcusp -dm_mat_type
> seqaijcusp
> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing package:
> http://www.mcs.anl.gov/petsc/documentation/installation.html#external
> [0]PETSC ERROR: Unknown vector type: seqcusp
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2027-g045eeab  GIT
> Date: 2018-03-12 13:30:25 -0500
> [0]PETSC ERROR: ./ex19 on a  named node50 by valera Wed Mar 14 11:12:11
> 2018
> [0]PETSC ERROR: Configure options --prefix=/usr/local/petsc.cod/petsc-install
> --with-mpi-dir=/usr/lib64/openmpi --with-blaslapack-dir=/usr/lib64
> COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=0
> --download-hypre --with-debugging=0 --with-cuda=1 --with-cuda-arch=sm_60
> [0]PETSC ERROR: #1 VecSetType() line 42 in /home/valera/testpetsc/src/
> vec/vec/interface/vecreg.c
> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 39 in
> /home/valera/testpetsc/src/dm/impls/da/dadist.c
> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 865 in
> /home/valera/testpetsc/src/dm/interface/dm.c
> [0]PETSC ERROR: #4 main() line 158 in /home/valera/testpetsc/src/
> snes/examples/tutorials/ex19.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -dm_mat_type seqaijcusp
> [0]PETSC ERROR: -dm_vec_type seqcusp
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 86.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> On Wed, Mar 14, 2018 at 11:10 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>> wrote:
>>> Ok lets try that, if i go to /home/valera/testpetsc/arch
>>> -linux2-c-opt/tests/src/snes/examples/tutorials there is runex19.sh and
>>> a lot of other ex19 variantes, but if i run that i get:
>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$ pushd
>> knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>> PETSC_ARCH=arch-master-debug make ex19
>> ./ex19 -dm_vec_type seqcusp -dm_mat_type seqaijcusp
>>   Thanks,
>>      Matt
>>> [valera at node50 tutorials]$ ./runex19.sh
>>> not ok snes_tutorials-ex19_1
>>> # mpiexec was unable to launch the specified application as it could
>>> not access
>>> # or execute an executable:
>>> # Executable: ../ex19
>>> # Node: node50
>>> # while attempting to start process rank 0.
>>> # 2 total processes failed to start
>>> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
>>> is this the one i should be running ?
>>> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <mvalera-w at mail.sdsu.edu
>>>> > wrote:
>>>>> Ok thanks Matt, i made a smaller case with only the linear solver and
>>>>> a 25x25 matrix, the error i have in this case is:
>>>> Ah, it appears that not all parts of your problem are taking the type
>>>> options. If you want the
>>>> linear algebra objects to change type, you need to have
>>>>   VecSetFromOptions()  and MatSetFromOptions()
>>>> called after you create them, but before sizes are set and data is
>>>> entered. However, it should
>>>> not be possible to have a seq Vec with the seqcusp AXPY routine set.
>>>> Something else is wrong...
>>>> Did you try a PETSc example, such as SNES ex19, with this?
>>>>   Thanks,
>>>>     Matt
>>>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp
>>>>> -mat_type aijcusparse
>>>>>  laplacian.petsc !
>>>>>  TrivSoln loaded, size:          125 /         125
>>>>>  RHS loaded, size:          125 /         125
>>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>>>> GIT Date: 2018-02-28 10:19:08 -0600
>>>>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
>>>>> 10:24:35 2018
>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>>>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>>>>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>>>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>>>>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>>>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>>>> [0]PETSC ERROR: Invalid argument
>>>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>>>> 10:24:35 2018
>>>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in /home/valera/petsc/src/vec/vec
>>>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in
>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>  soln maxval:   0.0000000000000000
>>>>>  soln minval:   0.0000000000000000
>>>>>  Norm:   11.180339887498949
>>>>>  Its:           0
>>>>> WARNING! There are options you set that were not used!
>>>>> WARNING! could be spelling mistake, etc!
>>>>> Option left: name:-mat_type value: aijcusparse
>>>>> I also see the configure options are not correct, so i guess is still
>>>>> linking a different petsc installation, but maybe we can try to make it
>>>>> work as it is, i will let you know if i am able to link the correct petsc
>>>>> installation here,
>>>>> Best,
>>>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <
>>>>>> mvalera-w at mail.sdsu.edu> wrote:
>>>>>>> Hello all,
>>>>>>> I am working on porting a linear solver into GPUs for timing
>>>>>>> purposes, so far i've been able to compile and run the CUSP libraries and
>>>>>>> compile PETSc to be used with CUSP and ViennaCL, after the initial runs i
>>>>>>> noticed some errors, they are different for different flags and i would
>>>>>>> appreciate any help interpreting them,
>>>>>>> The only elements in this program that use PETSc are the laplacian
>>>>>>> matrix (sparse), the RHS and X vectors and a scatter petsc object, so i
>>>>>>> would say it's safe to pass the command line arguments for the
>>>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>>>> These systems do not properly propagate errors. My only advice is to
>>>>>> run a smaller problem and see.
>>>>>>> [0]PETSC ERROR: ------------------------------
>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation, probably memory access out of range
>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> -on_error_attach_debugger
>>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>>> ocumentation/faq.html#valgrind
>>>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>>>>> Mac OS X to find memory corruption errors
>>>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>> available,
>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>> function
>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>>>> [0]PETSC ERROR: [0] VecSetType line 36 /home/valera/petsc/src/vec/vec
>>>>>>> /interface/vecreg.c
>>>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>> v3.8.3-1817-g96b6f8a  GIT Date: 2018-02-28 10:19:08 -0600
>>>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by valera Thu
>>>>>>> Mar  8 09:50:51 2018
>>>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in  unknown file
>>>>>>> This seems to be a memory out of range, maybe my vector is too big
>>>>>>> for my CUDA system? how do i assess that?
>>>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get
>>>>>>> something different and more interesting:
>>>>>> We need to see the entire error message, since it has the stack.
>>>>>> This seems like a logic error, but could definitely be on our end.
>>>>>> Here is how I think about these:
>>>>>>   1) We have nightly test solves, so at least some solver
>>>>>> configuration works
>>>>>>   2) Some vector which is marked read-only (happens for input to
>>>>>> solvers), but someone is trying to update it.
>>>>>>       The stack will tell me where this is happening.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>> [0]PETSC ERROR:  Vec is locked read only, argument # 3
>>>>>>> Mar  8 10:02:19 2018
>>>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>>>>  PETSC_SOLVER_ONLY   6.8672990892082453E-005 s
>>>>>>> Mar  8 10:02:19 2018
>>>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscattercusp.cu
>>>>>>> And it yields a "solution" to the system and also a log at the end:
>>>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by valera Thu
>>>>>>> Mar  8 10:02:24 2018
>>>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a  GIT
>>>>>>>                          Max       Max/Min        Avg      Total
>>>>>>> Time (sec):           4.573e+00      1.00000   4.573e+00
>>>>>>> Objects:              8.100e+01      1.00000   8.100e+01
>>>>>>> Flop:                 3.492e+07      1.00000   3.492e+07  3.492e+07
>>>>>>> Flop/sec:            7.637e+06      1.00000   7.637e+06  7.637e+06
>>>>>>> Memory:               2.157e+08      1.00000              2.157e+08
>>>>>>> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
>>>>>>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
>>>>>>> MPI Reductions:       0.000e+00      0.00000
>>>>>>> Flop counting convention: 1 flop = 1 real number operation of type
>>>>>>> (multiply/divide/add/subtract)
>>>>>>>                             e.g., VecAXPY() for real vectors of
>>>>>>> length N --> 2N flop
>>>>>>>                             and VecAXPY() for complex vectors of
>>>>>>> length N --> 8N flop
>>>>>>> Summary of Stages:   ----- Time ------  ----- Flop -----  ---
>>>>>>> Messages ---  -- Message Lengths --  -- Reductions --
>>>>>>>                         Avg     %Total     Avg     %Total   counts
>>>>>>>  %Total     Avg         %Total   counts   %Total
>>>>>>>  0:      Main Stage: 4.5729e+00 100.0%  3.4924e+07 100.0%
>>>>>>> 0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>>>>>>> See the 'Profiling' chapter of the users' manual for details on
>>>>>>> interpreting output.
>>>>>>> Phase summary info:
>>>>>>>    Count: number of times phase was executed
>>>>>>>    Time and Flop: Max - maximum over all processors
>>>>>>>                    Ratio - ratio of maximum to minimum over all
>>>>>>> processors
>>>>>>>    Mess: number of messages sent
>>>>>>>    Avg. len: average message length (bytes)
>>>>>>>    Reduct: number of global reductions
>>>>>>>    Global: entire computation
>>>>>>>    Stage: stages of a computation. Set stages with
>>>>>>> PetscLogStagePush() and PetscLogStagePop().
>>>>>>>       %T - percent time in this phase         %F - percent flop in
>>>>>>> this phase
>>>>>>>       %M - percent messages in this phase     %L - percent message
>>>>>>> lengths in this phase
>>>>>>>       %R - percent reductions in this phase
>>>>>>>    Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max
>>>>>>> time over all processors)
>>>>>>>       #                          WARNING!!!                    #
>>>>>>>       #   This code was compiled with a debugging option,      #
>>>>>>>       #   To get timing results run ./configure                #
>>>>>>>       #   using --with-debugging=no, the performance will      #
>>>>>>>       #   be generally two or three times faster.              #
>>>>>>> Event                Count      Time (sec)     Flop
>>>>>>>            --- Global ---  --- Stage ---   Total
>>>>>>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
>>>>>>> len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>>>>> --- Event Stage 0: Main Stage
>>>>>>> MatLUFactorNum         1 1.0 4.9502e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  1100  0  0  0   1100  0  0  0   706
>>>>>>> MatILUFactorSym        1 1.0 1.9642e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>>>> MatAssemblyBegin       2 1.0 6.9141e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> MatAssemblyEnd         2 1.0 2.6612e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
>>>>>>> MatGetRowIJ            1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> MatGetOrdering         1 1.0 1.7186e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> MatLoad                1 1.0 1.1575e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>>>>>>> MatView                1 1.0 8.0877e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>>>>> MatCUSPCopyTo          1 1.0 2.4664e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
>>>>>>> VecSet                68 1.0 5.1665e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>>>>>>> VecAssemblyBegin      17 1.0 5.2691e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> VecAssemblyEnd        17 1.0 4.3631e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> VecScatterBegin       15 1.0 1.5345e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> VecCUSPCopyFrom        1 1.0 1.1199e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> KSPSetUp               1 1.0 5.1929e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> PCSetUp                2 1.0 8.6590e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00  2100  0  0  0   2100  0  0  0   403
>>>>>>> Memory usage is given in bytes:
>>>>>>> Object Type          Creations   Destructions     Memory
>>>>>>> Descendants' Mem.
>>>>>>> Reports information only for process 0.
>>>>>>>               Matrix     3              1     52856972     0.
>>>>>>>    Matrix Null Space     1              1          608     0.
>>>>>>>               Vector    66              3      3414600     0.
>>>>>>>       Vector Scatter     1              1          680     0.
>>>>>>>               Viewer     3              2         1680     0.
>>>>>>>        Krylov Solver     1              0            0     0.
>>>>>>>       Preconditioner     2              1          864     0.
>>>>>>>            Index Set     4              1          800     0.
>>>>>>> Average time to get PetscTime(): 9.53674e-08
>>>>>>> #PETSc Option Table entries:
>>>>>>> -ksp_view
>>>>>>> -log_view
>>>>>>> -matload_block_size 1
>>>>>>> -vec_type cusp
>>>>>>> #End of PETSc Option Table entries
>>>>>>> Compiled without FORTRAN kernels
>>>>>>> Compiled with full precision matrices (default)
>>>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc --with-cxx=mpic++
>>>>>>> --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>>>>> Libraries compiled on Mon Mar  5 16:37:18 2018 on node50
>>>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>>>>> Using PETSc directory: /home/valera/petsc
>>>>>>> Using PETSc arch: cuda
>>>>>>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
>>>>>>> -fvisibility=hidden -O3
>>>>>>> Using Fortran compiler: mpifort  -fPIC -Wall -ffree-line-length-0
>>>>>>> -Wno-unused-dummy-argument -O3
>>>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>>>> Using C linker: mpicc
>>>>>>> Using Fortran linker: mpifort
>>>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack -lfblas
>>>>>>> -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>>>>> Thanks for your help,
>>>>>>> Manuel
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/2293258c/attachment-0001.html>
