[petsc-users] Tweaking my code for CUDA
Matthew Knepley
knepley at gmail.com
Wed Mar 14 13:10:10 CDT 2018
On Thu, Mar 15, 2018 at 2:46 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
wrote:
> Ok lets try that, if i go to /home/valera/testpetsc/
> arch-linux2-c-opt/tests/src/snes/examples/tutorials there is runex19.sh
> and a lot of other ex19 variantes, but if i run that i get:
knepley/feature-plex-functionals *$:/PETSc3/petsc/petsc-dev$ pushd
src/snes/examples/tutorials/
*$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
PETSC_ARCH=arch-master-debug make ex19
*$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex19 -dm_vec_type
seqcusp -dm_mat_type seqaijcusp
Matt
> [valera at node50 tutorials]$ ./runex19.sh
> not ok snes_tutorials-ex19_1
> # mpiexec was unable to launch the specified application as it could not
> access
> # or execute an executable:
> # Executable: ../ex19
> # Node: node50
> # while attempting to start process rank 0.
> # 2 total processes failed to start
> ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
> is this the one i should be running ?
> On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>> wrote:
>>> Ok thanks Matt, i made a smaller case with only the linear solver and a
>>> 25x25 matrix, the error i have in this case is:
>> Ah, it appears that not all parts of your problem are taking the type
>> options. If you want the
>> linear algebra objects to change type, you need to have
>> VecSetFromOptions() and MatSetFromOptions()
>> called after you create them, but before sizes are set and data is
>> entered. However, it should
>> not be possible to have a seq Vec with the seqcusp AXPY routine set.
>> Something else is wrong...
>> Did you try a PETSc example, such as SNES ex19, with this?
>> Thanks,
>> Matt
>>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp -mat_type
>>> aijcusparse
>>> laplacian.petsc !
>>> TrivSoln loaded, size: 125 / 125
>>> RHS loaded, size: 125 / 125
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a
>>> GIT Date: 2018-02-28 10:19:08 -0600
>>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
>>> 10:24:35 2018
>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>>> [0]PETSC ERROR: Invalid argument
>>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>>> 10:24:35 2018
>>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>>> [0]PETSC ERROR: #4 VecAXPY() line 612 in /home/valera/petsc/src/vec/vec
>>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>>> [0]PETSC ERROR: #7 KSPSolve() line 669 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> soln maxval: 0.0000000000000000
>>> soln minval: 0.0000000000000000
>>> Norm: 11.180339887498949
>>> Its: 0
>>> WARNING! There are options you set that were not used!
>>> WARNING! could be spelling mistake, etc!
>>> Option left: name:-mat_type value: aijcusparse
>>> I also see the configure options are not correct, so i guess is still
>>> linking a different petsc installation, but maybe we can try to make it
>>> work as it is, i will let you know if i am able to link the correct petsc
>>> installation here,
>>> Best,
>>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>>>> wrote:
>>>>> Hello all,
>>>>> I am working on porting a linear solver into GPUs for timing purposes,
>>>>> so far i've been able to compile and run the CUSP libraries and compile
>>>>> PETSc to be used with CUSP and ViennaCL, after the initial runs i noticed
>>>>> some errors, they are different for different flags and i would appreciate
>>>>> any help interpreting them,
>>>>> The only elements in this program that use PETSc are the laplacian
>>>>> matrix (sparse), the RHS and X vectors and a scatter petsc object, so i
>>>>> would say it's safe to pass the command line arguments for the
>>>>> Mat/VecSetType()s instead of changing the source code,
>>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type
>>>>> viennacl -mat_type aijviennacl *i get the following:
>>>> These systems do not properly propagate errors. My only advice is to
>>>> run a smaller problem and see.
>>>>> [0]PETSC ERROR: ------------------------------
>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>>> probably memory access out of range
>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>> -on_error_attach_debugger
>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>> ocumentation/faq.html#valgrind
>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>>>> OS X to find memory corruption errors
>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>> [0]PETSC ERROR: --------------------- Stack Frames
>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>> available,
>>>>> [0]PETSC ERROR: INSTEAD the line number of the start of the
>>>>> function
>>>>> [0]PETSC ERROR: is given.
>>>>> [0]PETSC ERROR: [0] VecSetValues line 847
>>>>> [0]PETSC ERROR: [0] VecSetType line 36 /home/valera/petsc/src/vec/vec
>>>>> /interface/vecreg.c
>>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>>> [0]PETSC ERROR: Signal received
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by valera Thu
>>>>> Mar 8 09:50:51 2018
>>>>> [0]PETSC ERROR: #5 User provided function() line 0 in unknown file
>>>>> This seems to be a memory out of range, maybe my vector is too big for
>>>>> my CUDA system? how do i assess that?
>>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get something
>>>>> different and more interesting:
>>>> We need to see the entire error message, since it has the stack.
>>>> This seems like a logic error, but could definitely be on our end. Here
>>>> is how I think about these:
>>>> 1) We have nightly test solves, so at least some solver configuration
>>>> works
>>>> 2) Some vector which is marked read-only (happens for input to
>>>> solvers), but someone is trying to update it.
>>>> The stack will tell me where this is happening.
>>>> Thanks,
>>>> Matt
>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>> [0]PETSC ERROR: Vec is locked read only, argument # 3
>>>>> Mar 8 10:02:19 2018
>>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>> PETSC_SOLVER_ONLY 6.8672990892082453E-005 s
>>>>> Mar 8 10:02:19 2018
>>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscattercusp.cu
>>>>> And it yields a "solution" to the system and also a log at the end:
>>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by valera Thu
>>>>> Mar 8 10:02:24 2018
>>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a GIT Date:
>>>>> Max Max/Min Avg Total
>>>>> Time (sec): 4.573e+00 1.00000 4.573e+00
>>>>> Objects: 8.100e+01 1.00000 8.100e+01
>>>>> Flop: 3.492e+07 1.00000 3.492e+07 3.492e+07
>>>>> Flop/sec: 7.637e+06 1.00000 7.637e+06 7.637e+06
>>>>> Memory: 2.157e+08 1.00000 2.157e+08
>>>>> MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
>>>>> MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
>>>>> MPI Reductions: 0.000e+00 0.00000
>>>>> Flop counting convention: 1 flop = 1 real number operation of type
>>>>> (multiply/divide/add/subtract)
>>>>> e.g., VecAXPY() for real vectors of length
>>>>> N --> 2N flop
>>>>> and VecAXPY() for complex vectors of
>>>>> length N --> 8N flop
>>>>> Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages
>>>>> --- -- Message Lengths -- -- Reductions --
>>>>> Avg %Total Avg %Total counts
>>>>> %Total Avg %Total counts %Total
>>>>> 0: Main Stage: 4.5729e+00 100.0% 3.4924e+07 100.0% 0.000e+00
>>>>> 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
>>>>> See the 'Profiling' chapter of the users' manual for details on
>>>>> interpreting output.
>>>>> Phase summary info:
>>>>> Count: number of times phase was executed
>>>>> Time and Flop: Max - maximum over all processors
>>>>> Ratio - ratio of maximum to minimum over all
>>>>> processors
>>>>> Mess: number of messages sent
>>>>> Avg. len: average message length (bytes)
>>>>> Reduct: number of global reductions
>>>>> Global: entire computation
>>>>> Stage: stages of a computation. Set stages with PetscLogStagePush()
>>>>> and PetscLogStagePop().
>>>>> %T - percent time in this phase %F - percent flop in
>>>>> this phase
>>>>> %M - percent messages in this phase %L - percent message
>>>>> lengths in this phase
>>>>> %R - percent reductions in this phase
>>>>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>>>>> # WARNING!!! #
>>>>> # This code was compiled with a debugging option, #
>>>>> # To get timing results run ./configure #
>>>>> # using --with-debugging=no, the performance will #
>>>>> # be generally two or three times faster. #
>>>>> Event Count Time (sec) Flop
>>>>> --- Global --- --- Stage --- Total
>>>>> Max Ratio Max Ratio Max Ratio Mess Avg
>>>>> len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>>>>> --- Event Stage 0: Main Stage
>>>>> MatLUFactorNum 1 1.0 4.9502e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 1100 0 0 0 1100 0 0 0 706
>>>>> MatILUFactorSym 1 1.0 1.9642e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>> MatAssemblyBegin 2 1.0 6.9141e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>> MatAssemblyEnd 2 1.0 2.6612e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 6 0 0 0 0 6 0 0 0 0 0
>>>>> MatGetRowIJ 1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00
>>>>> MatGetOrdering 1 1.0 1.7186e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>> MatLoad 1 1.0 1.1575e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
>>>>> MatView 1 1.0 8.0877e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
>>>>> MatCUSPCopyTo 1 1.0 2.4664e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 5 0 0 0 0 5 0 0 0 0 0
>>>>> VecSet 68 1.0 5.1665e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>> VecAssemblyBegin 17 1.0 5.2691e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>> VecAssemblyEnd 17 1.0 4.3631e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>> VecScatterBegin 15 1.0 1.5345e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>> VecCUSPCopyFrom 1 1.0 1.1199e-03 1.0 0.00e+00 0.0 0.0e+00
>>>>> KSPSetUp 1 1.0 5.1929e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>> PCSetUp 2 1.0 8.6590e-02 1.0 3.49e+07 1.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 2100 0 0 0 2100 0 0 0 403
>>>>> Memory usage is given in bytes:
>>>>> Object Type Creations Destructions Memory Descendants'
>>>>> Mem.
>>>>> Reports information only for process 0.
>>>>> Matrix 3 1 52856972 0.
>>>>> Matrix Null Space 1 1 608 0.
>>>>> Vector 66 3 3414600 0.
>>>>> Vector Scatter 1 1 680 0.
>>>>> Viewer 3 2 1680 0.
>>>>> Krylov Solver 1 0 0 0.
>>>>> Preconditioner 2 1 864 0.
>>>>> Index Set 4 1 800 0.
>>>>> Average time to get PetscTime(): 9.53674e-08
>>>>> #PETSc Option Table entries:
>>>>> -ksp_view
>>>>> -log_view
>>>>> -matload_block_size 1
>>>>> -vec_type cusp
>>>>> #End of PETSc Option Table entries
>>>>> Compiled without FORTRAN kernels
>>>>> Compiled with full precision matrices (default)
>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc --with-cxx=mpic++
>>>>> --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>>> Libraries compiled on Mon Mar 5 16:37:18 2018 on node50
>>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>>> Using PETSc directory: /home/valera/petsc
>>>>> Using PETSc arch: cuda
>>>>> Using C compiler: mpicc -fPIC -Wall -Wwrite-strings
>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>> -fvisibility=hidden -O3
>>>>> Using Fortran compiler: mpifort -fPIC -Wall -ffree-line-length-0
>>>>> -Wno-unused-dummy-argument -O3
>>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>>> -I/usr/local/cuda/include
>>>>> Using C linker: mpicc
>>>>> Using Fortran linker: mpifort
>>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack -lfblas
>>>>> -lm -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>>> -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>>>>> -lpthread -lstdc++ -ldl
>>>>> Thanks for your help,
>>>>> Manuel
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/7b547e23/attachment-0001.html>
