[petsc-users] Tweaking my code for CUDA
Manuel Valera mvalera-w at mail.sdsu.edu
Wed Mar 14 12:46:46 CDT 2018
Ok lets try that, if i go
to /home/valera/testpetsc/arch-linux2-c-opt/tests/src/snes/examples/tutorials
there is runex19.sh and a lot of other ex19 variantes, but if i run that i
get:
[valera at node50 tutorials]$ ./runex19.sh
not ok snes_tutorials-ex19_1
# mpiexec was unable to launch the specified application as it could not
access
# or execute an executable:
# Executable: ../ex19
# Node: node50
# while attempting to start process rank 0.
# 2 total processes failed to start
ok snes_tutorials-ex19_1 # SKIP Command failed so no diff
is this the one i should be running ?
On Wed, Mar 14, 2018 at 10:39 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 15, 2018 at 2:27 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
> wrote:
>> Ok thanks Matt, i made a smaller case with only the linear solver and a
>> 25x25 matrix, the error i have in this case is:
> Ah, it appears that not all parts of your problem are taking the type
> options. If you want the
> linear algebra objects to change type, you need to have
>   VecSetFromOptions()  and MatSetFromOptions()
> called after you create them, but before sizes are set and data is
> entered. However, it should
> not be possible to have a seq Vec with the seqcusp AXPY routine set.
> Something else is wrong...
> Did you try a PETSc example, such as SNES ex19, with this?
>   Thanks,
>     Matt
>> [valera at node50 alone]$ mpirun -n 1 ./linsolve -vec_type cusp -mat_type
>> aijcusparse
>>  laplacian.petsc !
>>  TrivSoln loaded, size:          125 /         125
>>  RHS loaded, size:          125 /         125
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>> [0]PETSC ERROR: Null Pointer: Parameter # 4
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-1817-g96b6f8a  GIT
>> Date: 2018-02-28 10:19:08 -0600
>> [0]PETSC ERROR: ./linsolve on a cuda named node50 by valera Wed Mar 14
>> 10:24:35 2018
>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --with-cc=mpicc
>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>> --FOPTFLAGS=-O3 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>> --with-cuda-arch=sm_60 --with-cusp=1 --with-cusp-dir=/home/valera/cusp
>> --with-vienacl=1 --download-fblaslapack=1 --download-hypre
>> [0]PETSC ERROR: #1 VecSetValues() line 851 in
>> /home/valera/petsc/src/vec/vec/interface/rvector.c
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Object (seq) is not seqcusp or mpicusp
>> 10:24:35 2018
>> [0]PETSC ERROR: #2 VecCUSPGetArrayRead() line 1792 in
>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/veccusp2.cu
>> [0]PETSC ERROR: #3 VecAXPY_SeqCUSP() line 314 in
>> [0]PETSC ERROR: #4 VecAXPY() line 612 in /home/valera/petsc/src/vec/vec
>> [0]PETSC ERROR: #5 KSPSolve_GCR_cycle() line 60 in
>> /home/valera/petsc/src/ksp/ksp/impls/gcr/gcr.c
>> [0]PETSC ERROR: #6 KSPSolve_GCR() line 114 in
>> [0]PETSC ERROR: #7 KSPSolve() line 669 in /home/valera/petsc/src/ksp/ksp
>> /interface/itfunc.c
>>  soln maxval:   0.0000000000000000
>>  soln minval:   0.0000000000000000
>>  Norm:   11.180339887498949
>>  Its:           0
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> Option left: name:-mat_type value: aijcusparse
>> I also see the configure options are not correct, so i guess is still
>> linking a different petsc installation, but maybe we can try to make it
>> work as it is, i will let you know if i am able to link the correct petsc
>> installation here,
>> Best,
>> On Sun, Mar 11, 2018 at 9:00 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Mar 9, 2018 at 3:05 AM, Manuel Valera <mvalera-w at mail.sdsu.edu>
>>> wrote:
>>>> Hello all,
>>>> I am working on porting a linear solver into GPUs for timing purposes,
>>>> so far i've been able to compile and run the CUSP libraries and compile
>>>> PETSc to be used with CUSP and ViennaCL, after the initial runs i noticed
>>>> some errors, they are different for different flags and i would appreciate
>>>> any help interpreting them,
>>>> The only elements in this program that use PETSc are the laplacian
>>>> matrix (sparse), the RHS and X vectors and a scatter petsc object, so i
>>>> would say it's safe to pass the command line arguments for the
>>>> Mat/VecSetType()s instead of changing the source code,
>>>> If i use *-vec_type cuda -mat_type aijcusparse* or *-vec_type viennacl
>>>> -mat_type aijviennacl *i get the following:
>>> These systems do not properly propagate errors. My only advice is to run
>>> a smaller problem and see.
>>>> [0]PETSC ERROR: ------------------------------
>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably memory access out of range
>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>> ocumentation/faq.html#valgrind
>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>>> OS X to find memory corruption errors
>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,
>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>>> function
>>>> [0]PETSC ERROR:       is given.
>>>> [0]PETSC ERROR: [0] VecSetValues line 847 /home/valera/petsc/src/vec/vec
>>>> [0]PETSC ERROR: [0] VecSetType line 36 /home/valera/petsc/src/vec/vec
>>>> /interface/vecreg.c
>>>> [0]PETSC ERROR: [0] VecSetTypeFromOptions_Private line 1230
>>>> /home/valera/petsc/src/vec/vec/interface/vector.c
>>>> [0]PETSC ERROR: [0] VecSetFromOptions line 1271
>>>> [0]PETSC ERROR: Signal received
>>>> GIT Date: 2018-02-28 10:19:08 -0600
>>>> [0]PETSC ERROR: ./gcmSeamount on a cuda named node50 by valera Thu Mar
>>>> 8 09:50:51 2018
>>>> [0]PETSC ERROR: #5 User provided function() line 0 in  unknown file
>>>> This seems to be a memory out of range, maybe my vector is too big for
>>>> my CUDA system? how do i assess that?
>>>> Next, if i use *-vec_type cusp -mat_type aijcusparse *i get something
>>>> different and more interesting:
>>> We need to see the entire error message, since it has the stack.
>>> This seems like a logic error, but could definitely be on our end. Here
>>> is how I think about these:
>>>   1) We have nightly test solves, so at least some solver configuration
>>> works
>>>   2) Some vector which is marked read-only (happens for input to
>>> solvers), but someone is trying to update it.
>>>       The stack will tell me where this is happening.
>>>   Thanks,
>>>      Matt
>>>> [0]PETSC ERROR: Object is in wrong state
>>>> [0]PETSC ERROR:  Vec is locked read only, argument # 3
>>>> 8 10:02:19 2018
>>>> [0]PETSC ERROR: #48 KSPSolve() line 615 in
>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>  PETSC_SOLVER_ONLY   6.8672990892082453E-005 s
>>>> 8 10:02:19 2018
>>>> [0]PETSC ERROR: #49 VecCUSPGetArrayReadWrite() line 1718 in
>>>> [0]PETSC ERROR: #50 VecScatterCUSP_StoS() line 269 in
>>>> /home/valera/petsc/src/vec/vec/impls/seq/seqcusp/vecscattercusp.cu
>>>> And it yields a "solution" to the system and also a log at the end:
>>>> ./gcmSeamount on a cuda named node50 with 1 processor, by valera Thu
>>>> Mar  8 10:02:24 2018
>>>> Using Petsc Development GIT revision: v3.8.3-1817-g96b6f8a  GIT Date:
>>>>                          Max       Max/Min        Avg      Total
>>>> Time (sec):           4.573e+00      1.00000   4.573e+00
>>>> Objects:              8.100e+01      1.00000   8.100e+01
>>>> Flop:                 3.492e+07      1.00000   3.492e+07  3.492e+07
>>>> Flop/sec:            7.637e+06      1.00000   7.637e+06  7.637e+06
>>>> Memory:               2.157e+08      1.00000              2.157e+08
>>>> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
>>>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
>>>> MPI Reductions:       0.000e+00      0.00000
>>>> Flop counting convention: 1 flop = 1 real number operation of type
>>>> (multiply/divide/add/subtract)
>>>>                             e.g., VecAXPY() for real vectors of length
>>>> N --> 2N flop
>>>>                             and VecAXPY() for complex vectors of length
>>>> N --> 8N flop
>>>> Summary of Stages:   ----- Time ------  ----- Flop -----  --- Messages
>>>> ---  -- Message Lengths --  -- Reductions --
>>>>                         Avg     %Total     Avg     %Total   counts
>>>>  %Total     Avg         %Total   counts   %Total
>>>>  0:      Main Stage: 4.5729e+00 100.0%  3.4924e+07 100.0%  0.000e+00
>>>>  0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>>>> See the 'Profiling' chapter of the users' manual for details on
>>>> interpreting output.
>>>> Phase summary info:
>>>>    Count: number of times phase was executed
>>>>    Time and Flop: Max - maximum over all processors
>>>>                    Ratio - ratio of maximum to minimum over all
>>>> processors
>>>>    Mess: number of messages sent
>>>>    Avg. len: average message length (bytes)
>>>>    Reduct: number of global reductions
>>>>    Global: entire computation
>>>>    Stage: stages of a computation. Set stages with PetscLogStagePush()
>>>> and PetscLogStagePop().
>>>>       %T - percent time in this phase         %F - percent flop in this
>>>> phase
>>>>       %M - percent messages in this phase     %L - percent message
>>>> lengths in this phase
>>>>       %R - percent reductions in this phase
>>>>    Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>>>>       #                          WARNING!!!                    #
>>>>       #   This code was compiled with a debugging option,      #
>>>>       #   To get timing results run ./configure                #
>>>>       #   using --with-debugging=no, the performance will      #
>>>>       #   be generally two or three times faster.              #
>>>> Event                Count      Time (sec)     Flop
>>>>          --- Global ---  --- Stage ---   Total
>>>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
>>>> len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>> --- Event Stage 0: Main Stage
>>>> MatLUFactorNum         1 1.0 4.9502e-02 1.0 3.49e+07 1.0 0.0e+00
>>>> 0.0e+00 0.0e+00  1100  0  0  0   1100  0  0  0   706
>>>> MatILUFactorSym        1 1.0 1.9642e-02 1.0 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>> MatAssemblyBegin       2 1.0 6.9141e-06 1.0 0.00e+00 0.0 0.0e+00
>>>> MatAssemblyEnd         2 1.0 2.6612e-01 1.0 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
>>>> MatGetRowIJ            1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00
>>>> MatGetOrdering         1 1.0 1.7186e-02 1.0 0.00e+00 0.0 0.0e+00
>>>> MatLoad                1 1.0 1.1575e-01 1.0 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>>>> MatView                1 1.0 8.0877e-02 1.0 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>> MatCUSPCopyTo          1 1.0 2.4664e-01 1.0 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
>>>> VecSet                68 1.0 5.1665e-02 1.0 0.00e+00 0.0 0.0e+00
>>>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>>>> VecAssemblyBegin      17 1.0 5.2691e-05 1.0 0.00e+00 0.0 0.0e+00
>>>> VecAssemblyEnd        17 1.0 4.3631e-05 1.0 0.00e+00 0.0 0.0e+00
>>>> VecScatterBegin       15 1.0 1.5345e-03 1.0 0.00e+00 0.0 0.0e+00
>>>> VecCUSPCopyFrom        1 1.0 1.1199e-03 1.0 0.00e+00 0.0 0.0e+00
>>>> KSPSetUp               1 1.0 5.1929e-02 1.0 0.00e+00 0.0 0.0e+00
>>>> PCSetUp                2 1.0 8.6590e-02 1.0 3.49e+07 1.0 0.0e+00
>>>> 0.0e+00 0.0e+00  2100  0  0  0   2100  0  0  0   403
>>>> Memory usage is given in bytes:
>>>> Object Type          Creations   Destructions     Memory  Descendants'
>>>> Mem.
>>>> Reports information only for process 0.
>>>>               Matrix     3              1     52856972     0.
>>>>    Matrix Null Space     1              1          608     0.
>>>>               Vector    66              3      3414600     0.
>>>>       Vector Scatter     1              1          680     0.
>>>>               Viewer     3              2         1680     0.
>>>>        Krylov Solver     1              0            0     0.
>>>>       Preconditioner     2              1          864     0.
>>>>            Index Set     4              1          800     0.
>>>> Average time to get PetscTime(): 9.53674e-08
>>>> #PETSc Option Table entries:
>>>> -ksp_view
>>>> -log_view
>>>> -matload_block_size 1
>>>> -vec_type cusp
>>>> #End of PETSc Option Table entries
>>>> Compiled without FORTRAN kernels
>>>> Compiled with full precision matrices (default)
>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>> Configure options: PETSC_ARCH=cuda --with-cc=mpicc --with-cxx=mpic++
>>>> --with-fc=mpifort --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>> Libraries compiled on Mon Mar  5 16:37:18 2018 on node50
>>>> Machine characteristics: Linux-3.10.0-693.17.1.el7.x86_
>>>> 64-x86_64-with-centos-7.2.1511-Core
>>>> Using PETSc directory: /home/valera/petsc
>>>> Using PETSc arch: cuda
>>>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>> -fvisibility=hidden -O3
>>>> Using Fortran compiler: mpifort  -fPIC -Wall -ffree-line-length-0
>>>> -Wno-unused-dummy-argument -O3
>>>> Using include paths: -I/home/valera/petsc/cuda/include
>>>> -I/home/valera/petsc/include -I/home/valera/petsc/include
>>>> -I/home/valera/petsc/cuda/include -I/home/valera/cusp/
>>>> -I/usr/local/cuda/include
>>>> Using C linker: mpicc
>>>> Using Fortran linker: mpifort
>>>> Using libraries: -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>> -L/home/valera/petsc/cuda/lib -lpetsc -Wl,-rpath,/home/valera/petsc/cuda/lib
>>>> -L/home/valera/petsc/cuda/lib -Wl,-rpath,/usr/local/cuda/lib64
>>>> -L/usr/local/cuda/lib64 -Wl,-rpath,/usr/lib64/openmpi/lib
>>>> -L/usr/lib64/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -lflapack -lfblas -lm
>>>> -lcufft -lcublas -lcudart -lcusparse -lX11 -lstdc++ -ldl -lmpi_usempi
>>>> -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>>>> -lpthread -lstdc++ -ldl
>>>> Thanks for your help,
>>>> Manuel
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180314/05d71a08/attachment-0001.html>
