[petsc-users] make: *** No rule to make target `chk_makej', needed by `all'. Stop.
Jose E. Roman jroman at dsic.upv.es
Thu Mar 8 15:14:33 CST 2018
Update the SLEPc repository and try again.
When a change in petsc-master affects SLEPc, you have to allow one or two days for us to re-synchronize.
Jose
> El 9 mar 2018, a las 3:59, Samuel Lanthaler <s.lanthaler at gmail.com> escribió:
> Hi,
> I've just been trying to compile SLEPC on a cluster, and am getting the following error message after I type "make":
> > ./configure
> Checking environment... done
> Checking PETSc installation... done
> Checking LAPACK library... done
> Writing various configuration files... done
> Generating Fortran stubs... done
> SLEPc Configuration
> SLEPc directory:
> /marconi/home/userexternal/slanthal/slepc-git
>  It is a git repository on branch: master
> PETSc directory:
> /marconi/home/userexternal/slanthal/petsc-git
> Architecture "arch-complex" with double precision complex numbers
> xxx=========================================================================xxx
> Configure stage complete. Now build the SLEPc library with (gnumake build):
>   make SLEPC_DIR=$PWD PETSC_DIR=/marconi/home/userexternal/slanthal/petsc-git PETSC_ARCH=arch-complex
> Does someone maybe know what the cause of this could be? Make is correct in that there is no rule for chk_makej, but I'm assuming it should really be some kind of function? However, since I don't understand what the dependency on chk_makej exactly does, I'm a bit lost...
> Thanks for you help in advance!
> Samuel
