[petsc-users] make: *** No rule to make target `chk_makej', needed by `all'. Stop.
Jed Brown
jed at jedbrown.org
Thu Mar 8 15:26:37 CST 2018
Thanks, Jose.
"Jose E. Roman" <jroman at dsic.upv.es> writes:
> Update the SLEPc repository and try again.
> When a change in petsc-master affects SLEPc, you have to allow one or two days for us to re-synchronize.
> Jose
>> El 9 mar 2018, a las 3:59, Samuel Lanthaler <s.lanthaler at gmail.com> escribió:
>> Hi,
>> I've just been trying to compile SLEPC on a cluster, and am getting the following error message after I type "make":
>> > ./configure
>> Checking environment... done
>> Checking PETSc installation... done
>> Checking LAPACK library... done
>> Writing various configuration files... done
>> Generating Fortran stubs... done
>> SLEPc Configuration
>> SLEPc directory:
>> /marconi/home/userexternal/slanthal/slepc-git
>> It is a git repository on branch: master
>> PETSc directory:
>> /marconi/home/userexternal/slanthal/petsc-git
>> Architecture "arch-complex" with double precision complex numbers
>> xxx=========================================================================xxx
>> Configure stage complete. Now build the SLEPc library with (gnumake build):
>> make SLEPC_DIR=$PWD PETSC_DIR=/marconi/home/userexternal/slanthal/petsc-git PETSC_ARCH=arch-complex
>> Does someone maybe know what the cause of this could be? Make is correct in that there is no rule for chk_makej, but I'm assuming it should really be some kind of function? However, since I don't understand what the dependency on chk_makej exactly does, I'm a bit lost...
>> Thanks for you help in advance!
>> Samuel
