[petsc-users] Preconditioned residuals for FGMRES
Matthew Knepley
knepley at gmail.com
Fri Jun 22 15:49:18 CDT 2018
On Fri, Jun 22, 2018 at 1:47 PM Boyce Griffith <griffith at cims.nyu.edu>
wrote:
> Can you set up the preconditioner so that you can just use GMRES?
So I think what Boyce is saying is, can't you fix the number of iterates in
the inner Krylov solvers so that it becomes a linear
operator and you can use GMRES?
Matt
> On Jun 22, 2018, at 4:33 PM, Nishant Nangia <nishantnangia329 at gmail.com>
> wrote:
> Hi,
> I am solving a saddle point system using a shell preconditioner (which
> itself uses Krylov solvers, hence the use of FGMRES). I had added the
> option to re-scale parts of the saddle point system to minimize loss of
> floating point precision for cases where there are varying orders of
> magnitude in the system/unknowns.
> I wanted to show that re-scaling can alleviate large differences between
> the preconditioned and unpreconditioned residual norms. However, I notice
> that FGMRES only supports right preconditioning, meaning the preconditioned
> residual is never formed/used (I think).
> Is there any way to form the preconditioned norm for FGMRES, or does it
> just not make sense in the context of right-preconditioned iterative
> solvers? Is there any way to show that the re-scaling is improving the
> solver convergence (i.e. showing that it ensures that the true and relative
> residual are close to each other)?
> *Nishant Nangia*
> Northwestern University
> Ph.D. Candidate | Engineering Sciences and Applied Mathematics
> Tech L386
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180622/cffacbff/attachment.html>
