[petsc-users] Preconditioned residuals for FGMRES
Boyce Griffith
griffith at cims.nyu.edu
Fri Jun 22 15:47:42 CDT 2018
Can you set up the preconditioner so that you can just use GMRES?
> On Jun 22, 2018, at 4:33 PM, Nishant Nangia <nishantnangia329 at gmail.com> wrote:
> Hi,
> I am solving a saddle point system using a shell preconditioner (which itself uses Krylov solvers, hence the use of FGMRES). I had added the option to re-scale parts of the saddle point system to minimize loss of floating point precision for cases where there are varying orders of magnitude in the system/unknowns.
> I wanted to show that re-scaling can alleviate large differences between the preconditioned and unpreconditioned residual norms. However, I notice that FGMRES only supports right preconditioning, meaning the preconditioned residual is never formed/used (I think).
> Is there any way to form the preconditioned norm for FGMRES, or does it just not make sense in the context of right-preconditioned iterative solvers? Is there any way to show that the re-scaling is improving the solver convergence (i.e. showing that it ensures that the true and relative residual are close to each other)?
> Nishant Nangia
> Northwestern University
> Ph.D. Candidate | Engineering Sciences and Applied Mathematics
> Tech L386
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180622/c21765c3/attachment.html>
