[petsc-users] Preconditioned residuals for FGMRES
Amneet Pal Bhalla
apbhalla at lbl.gov
Fri Jun 22 15:51:23 CDT 2018
Like using the Krylov preconditioner as a Richardson KSP solver with max_its = N?
> On Jun 22, 2018, at 1:49 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 22, 2018 at 1:47 PM Boyce Griffith <griffith at cims.nyu.edu <mailto:griffith at cims.nyu.edu>> wrote:
> Can you set up the preconditioner so that you can just use GMRES?
> So I think what Boyce is saying is, can't you fix the number of iterates in the inner Krylov solvers so that it becomes a linear
> operator and you can use GMRES?
> Thanks,
> Matt
> On Jun 22, 2018, at 4:33 PM, Nishant Nangia <nishantnangia329 at gmail.com <mailto:nishantnangia329 at gmail.com>> wrote:
>> Hi,
>> I am solving a saddle point system using a shell preconditioner (which itself uses Krylov solvers, hence the use of FGMRES). I had added the option to re-scale parts of the saddle point system to minimize loss of floating point precision for cases where there are varying orders of magnitude in the system/unknowns.
>> I wanted to show that re-scaling can alleviate large differences between the preconditioned and unpreconditioned residual norms. However, I notice that FGMRES only supports right preconditioning, meaning the preconditioned residual is never formed/used (I think).
>> Is there any way to form the preconditioned norm for FGMRES, or does it just not make sense in the context of right-preconditioned iterative solvers? Is there any way to show that the re-scaling is improving the solver convergence (i.e. showing that it ensures that the true and relative residual are close to each other)?
>> Nishant Nangia
>> Northwestern University
>> Ph.D. Candidate | Engineering Sciences and Applied Mathematics
>> Tech L386
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180622/bcb8f647/attachment-0001.html>
