[petsc-users] Makefile for mixed C++ and Fortran code
Danyang Su
danyang.su at gmail.com
Fri Jun 1 12:42:37 CDT 2018
On 18-06-01 10:29 AM, Smith, Barry F. wrote:
> What happens if you add ${DLIB} to the end of the line
>> executable: $(SOURCES) chkopts
>> -${FLINKER} $(FFLAGS) $(FPPFLAGS) $(CPPFLAGS) -o executable.out $(SOURCES) ${PETSC_LIB}
> Send all the output from trying this.
> Barry
Thanks, Barry. Still not work after including ${DLIB}
>> On Jun 1, 2018, at 12:07 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi All,
>> My code needs to link to an external C++ library (CGAL). The code is written in Fortran and I have already written interface to let Fortran call C++ function. For the sequential version without PETSc, it can be compiled without problem using the following makefile. The parallel version without CGAL can also be compiled successfully. However, when I tried to use PETSc together with CGAL library, I cannot compile the code. My questions is: How can I modify the makefile? Do I need to reconfigure PETSc with special flags? All the makefile samples are shown below.
>> #makefile for sequential version
>> FC = gfortran
>> #FC = ifort
>> CXX = g++ -std=c++11
>> DLIB = -lstdc++ -lm -L/usr/local/lib -rdynamic /usr/local/lib/libmpfr.so /usr/local/lib/libgmp.so /usr/local/lib/libCGAL_ImageIO.so.11.0.1 /usr/local/lib/libCGAL.so.11.0.1 /usr/local/lib/libboost_thread.so /usr/local/lib/libboost_system.so -lpthread -lGLU -lGL -lX11 -lXext -lz /usr/local/lib/libCGAL_ImageIO.so.11.0.1 /usr/local/lib/libCGAL.so.11.0.1 /usr/local/lib/libboost_thread.so /usr/local/lib/libboost_system.so -lpthread -lGLU -lGL -lX11 -lXext -lz /usr/local/lib/libmpfr.so /usr/local/lib/libgmp.so /usr/local/lib/libboost_thread.so /usr/local/lib/libboost_system.so -lpthread -Wl,-rpath,/usr/local/lib
>> FFLAGS = -O3
>> CXXFLAGS = -O3
>> FPPFLAGS = -DUSECGAL
>> SRC =./../../
>> SOURCES = $(SRC)usg/math_common.o\
>> $(SRC)usg/geometry_definition.o\
>> $(SRC)usg/cgal_common.o\
>> $(FC) $(FFLAGS) $(FPPFLAGS) -o executable.out $(SOURCES) ${LIS_LIB} $(DLIB)
>> %.o:%.F90
>> $(FC) $(FFLAGS) $(FPPFLAGS) -c -frounding-math $< -o $@
>> %.o:%.cpp
>> $(CXX) $(CXXFLAGS) $(CPPFLAGS) -c -frounding-math $< -o $@
>> #makefile for parallel version with PETSc, without CGAL
>> #FC = ifort
>> #FC = gfortran
>> DLIB = -lm
>> FFLAGS = -O3
>> FPPFLAGS = -DUSEPETSC
>> SRC =./../../
>> #makefile for parallel version with PETSc, with CGAL, CANNOT work
>> #FC = ifort
>> #FC = gfortran
>> DLIB = -lm
>> FFLAGS = -O3
>> FPPFLAGS = -DUSEPETSC -DUSECGAL
>> SRC =./../../
>> %.o:%.F90
>> %.o:%.cpp
>> Thanks,
>> Danyang
