[petsc-users] Makefile for mixed C++ and Fortran code
Danyang Su
danyang.su at gmail.com
Fri Jun 1 12:37:21 CDT 2018
Follow up:
With following command
executable: $(SOURCES) chkopts
-${FLINKER} $(FFLAGS) $(FPPFLAGS) $(CPPFLAGS) -o executable.out
$(SOURCES) ${PETSC_LIB}
%.o:%.F90
$(FLINKER) $(FFLAGS) $(FPPFLAGS) -c -frounding-math $< -o $@
%.o:%.cpp
$(CLINKER) $(CXXFLAGS) $(CPPFLAGS) -c -frounding-math $< -o $@
The compiler return error: no match function.
../../usg/cgal_triangulation_2d.cpp: In function ‘void
outputTriangulation2d(in\
t, const char*, int, const char*)’:
../../usg/cgal_triangulation_2d.cpp:485:20: error: no matching function
for cal\
l to ‘std::basic_ofstream<char>::open(std::string&)’
out.open(strfile);
Danyang
On 18-06-01 10:07 AM, Danyang Su wrote:
> Hi All,
> My code needs to link to an external C++ library (CGAL). The code is
> written in Fortran and I have already written interface to let Fortran
> call C++ function. For the sequential version without PETSc, it can be
> compiled without problem using the following makefile. The parallel
> version without CGAL can also be compiled successfully. However, when
> I tried to use PETSc together with CGAL library, I cannot compile the
> code. My questions is: How can I modify the makefile? Do I need to
> reconfigure PETSc with special flags? All the makefile samples are
> shown below.
> #makefile for sequential version
> FC = gfortran
> #FC = ifort
> CXX = g++ -std=c++11
> DLIB = -lstdc++ -lm -L/usr/local/lib -rdynamic
> /usr/local/lib/libmpfr.so /usr/local/lib/libgmp.so
> /usr/local/lib/libCGAL_ImageIO.so.11.0.1
> /usr/local/lib/libCGAL.so.11.0.1 /usr/local/lib/libboost_thread.so
> /usr/local/lib/libboost_system.so -lpthread -lGLU -lGL -lX11 -lXext
> -lz /usr/local/lib/libCGAL_ImageIO.so.11.0.1
> -lz /usr/local/lib/libmpfr.so /usr/local/lib/libgmp.so
> /usr/local/lib/libboost_thread.so /usr/local/lib/libboost_system.so
> -lpthread -Wl,-rpath,/usr/local/lib
> FFLAGS = -O3
> CXXFLAGS = -O3
> FPPFLAGS = -DUSECGAL
> SRC =./../../
> SOURCES = $(SRC)usg/math_common.o\
> $(SRC)usg/geometry_definition.o\
> $(SRC)usg/cgal_common.o\
> $(FC) $(FFLAGS) $(FPPFLAGS) -o executable.out $(SOURCES)
> ${LIS_LIB} $(DLIB)
> %.o:%.F90
> $(FC) $(FFLAGS) $(FPPFLAGS) -c -frounding-math $< -o $@
> %.o:%.cpp
> $(CXX) $(CXXFLAGS) $(CPPFLAGS) -c -frounding-math $< -o $@
> #makefile for parallel version with PETSc, without CGAL
> #FC = ifort
> #FC = gfortran
> DLIB = -lm
> FFLAGS = -O3
> FPPFLAGS = -DUSEPETSC
> SRC =./../../
> #makefile for parallel version with PETSc, with CGAL, CANNOT work
> #FC = ifort
> #FC = gfortran
> DLIB = -lm
> FFLAGS = -O3
> FPPFLAGS = -DUSEPETSC -DUSECGAL
> SRC =./../../
> %.o:%.F90
> %.o:%.cpp
> Thanks,
> Danyang
