[petsc-users] Saving output and execution time
Fazlul Huq huq2090 at gmail.com
Fri Jul 27 13:47:34 CDT 2018
Thanks Matthew.
By the way, how can I find the execution time of the processor?
On Thu, Jul 19, 2018 at 7:34 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jul 19, 2018 at 1:44 PM Fazlul Huq <huq2090 at gmail.com> wrote:
>> Hello all,
>> I can run the following code with this command showing output on the
>> console: ./poisson_m -ksp_view_solution
> What is the question? To put that ASCII output in a file, use
> -ksp_view_solution :sol.txt
> There is a chapter in the manual on viewing.
>   Thanks,
>     Matt
>> The code is:
>> static char help[] = "Solves a tridiagonal linear system.\n\n";
>> /*T
>>    Concepts: KSP^basic parallel example;
>>    Processors: n
>> T*/
>>   Include "petscksp.h" so that we can use KSP solvers.  Note that this
>> file
>>   automatically includes:
>>      petscsys.h       - base PETSc routines   petscvec.h - vectors
>>      petscmat.h - matrices
>>      petscis.h     - index sets            petscksp.h - Krylov subspace
>> methods
>>      petscviewer.h - viewers               petscpc.h  - preconditioners
>>   Note:  The corresponding uniprocessor example is ex1.c
>> #include <petscksp.h>
>> int main(int argc,char **args)
>>   Vec            x, b, u;          /* approx solution, RHS, exact
>> solution */
>>   Mat            A;                /* linear system matrix */
>>   KSP            ksp;              /* linear solver context */
>>   PC             pc;               /* preconditioner context */
>>   PetscReal      norm,tol=1000.*PETSC_MACHINE_EPSILON;  /* norm of
>> solution error */
>>   PetscErrorCode ierr;
>>   PetscInt       i,n = 99,col[3],its,rstart,rend,nlocal;
>>   PetscScalar    one = 1.0,hundredth = 0.001,leftbc = 10.001,rightbc =
>> 15.001,value[3];
>>   ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return
>> ierr;
>>   ierr = PetscOptionsGetInt(NULL,NULL,"-n",&n,NULL);CHKERRQ(ierr);
>>          Compute the matrix and right-hand-side vector that define
>>          the linear system, Ax = b.
>>      Create vectors.  Note that we form 1 vector from scratch and
>>      then duplicate as needed. For this simple case let PETSc decide how
>>      many elements of the vector are stored on each processor. The second
>>      argument to VecSetSizes() below causes PETSc to decide.
>>   ierr = VecCreate(PETSC_COMM_WORLD,&x);CHKERRQ(ierr);
>>   ierr = VecSetSizes(x,PETSC_DECIDE,n);CHKERRQ(ierr);
>>   ierr = VecSetFromOptions(x);CHKERRQ(ierr);
>>   ierr = VecDuplicate(x,&b);CHKERRQ(ierr);
>>   ierr = VecDuplicate(x,&u);CHKERRQ(ierr);
>>   /* Identify the starting and ending mesh points on each
>>      processor for the interior part of the mesh. We let PETSc decide
>>      above. */
>>   ierr = VecGetOwnershipRange(x,&rstart,&rend);CHKERRQ(ierr);
>>   ierr = VecGetLocalSize(x,&nlocal);CHKERRQ(ierr);
>>      Create matrix.  When using MatCreate(), the matrix format can
>>      be specified at runtime.
>>      Performance tuning note:  For problems of substantial size,
>>      preallocation of matrix memory is crucial for attaining good
>>      performance. See the matrix chapter of the users manual for details.
>>      We pass in nlocal as the "local" size of the matrix to force it
>>      to have the same parallel layout as the vector created above.
>>   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>   ierr = MatSetSizes(A,nlocal,nlocal,n,n);CHKERRQ(ierr);
>>   ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>>   ierr = MatSetUp(A);CHKERRQ(ierr);
>>      Assemble matrix.
>>      The linear system is distributed across the processors by
>>      chunks of contiguous rows, which correspond to contiguous
>>      sections of the mesh on which the problem is discretized.
>>      For matrix assembly, each processor contributes entries for
>>      the part that it owns locally.
>>   if (!rstart) {
>>     rstart = 1;
>>     i      = 0; col[0] = 0; col[1] = 1; value[0] = 2.0; value[1] = -1.0;
>>     ierr   = MatSetValues(A,1,&i,2,col,value,INSERT_VALUES);CHKERRQ(
>> ierr);
>>   if (rend == n) {
>>     rend = n-1;
>>     i    = n-1; col[0] = n-2; col[1] = n-1; value[0] = -1.0; value[1] =
>> 2.0;
>>     ierr = MatSetValues(A,1,&i,2,col,value,INSERT_VALUES);CHKERRQ(ierr);
>>   /* Set entries corresponding to the mesh interior */
>>   value[0] = -1.0; value[1] = 2.0; value[2] = -1.0;
>>   for (i=rstart; i<rend; i++) {
>>     col[0] = i-1; col[1] = i; col[2] = i+1;
>>     ierr   = MatSetValues(A,1,&i,3,col,value,INSERT_VALUES);CHKERRQ(
>> ierr);
>>   /* Assemble the matrix */
>>   ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>   ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>      Set exact solution; then compute right-hand-side vector.
>>   ierr = VecSet(u,one);CHKERRQ(ierr);
>>   i=0;
>>     ierr = VecSetValues(b, 1, &i, &leftbc, INSERT_VALUES);CHKERRQ(ierr);
>>   for (i=1; i<n-1; i++){
>>     ierr = VecSetValues(b, 1, &i, &hundredth,
>>   i=n-1;
>>     ierr = VecSetValues(b, 1, &i, &rightbc, INSERT_VALUES);CHKERRQ(ierr);
>>     ierr = VecAssemblyBegin(b);CHKERRQ(ierr);
>>     ierr = VecAssemblyEnd(b);CHKERRQ(ierr);
>>   // ierr = MatMult(A,u,b);CHKERRQ(ierr);
>>                 Create the linear solver and set various options
>>      Create linear solver context
>>   ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>      Set operators. Here the matrix that defines the linear system
>>      also serves as the preconditioning matrix.
>>   ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>>      Set linear solver defaults for this problem (optional).
>>      - By extracting the KSP and PC contexts from the KSP context,
>>        we can then directly call any KSP and PC routines to set
>>        various options.
>>      - The following four statements are optional; all of these
>>        parameters could alternatively be specified at runtime via
>>        KSPSetFromOptions();
>>   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>   ierr = PCSetType(pc,PCJACOBI);CHKERRQ(ierr);
>>   ierr = KSPSetTolerances(ksp,1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,
>> PETSC_DEFAULT);CHKERRQ(ierr);
>>     Set runtime options, e.g.,
>>         -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
>>     These options will override those specified above as long as
>>     KSPSetFromOptions() is called _after_ any other customization
>>     routines.
>>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>                       Solve the linear system
>>      Solve linear system
>>   ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>>      View solver info; we could instead use the option -ksp_view to
>>      print this info to the screen at the conclusion of KSPSolve().
>>   ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>                       Check solution and clean up
>>      Check the error
>>   ierr = VecAXPY(x,-1.0,u);CHKERRQ(ierr);
>>   ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
>>   ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
>>   if (norm > tol) {
>>     ierr = PetscPrintf(PETSC_COMM_WORLD,"Norm of error %g, Iterations
>> %D\n",(double)norm,its);CHKERRQ(ierr);
>>      Free work space.  All PETSc objects should be destroyed when they
>>      are no longer needed.
>>   ierr = VecDestroy(&x);CHKERRQ(ierr); ierr =
>> VecDestroy(&u);CHKERRQ(ierr);
>>   ierr = VecDestroy(&b);CHKERRQ(ierr); ierr =
>> MatDestroy(&A);CHKERRQ(ierr);
>>   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>>      Always call PetscFinalize() before exiting a program.  This routine
>>        - finalizes the PETSc libraries as well as MPI
>>        - provides summary and diagnostic information if certain runtime
>>          options are chosen (e.g., -log_view).
>>   ierr = PetscFinalize();
>>   return ierr;
>> Now I am trying to save this output in a file (say in a .csv file) at
>> runtime along with execution time but I can't.
>> Any suggestion please!
>> Sincerely,
>> Huq
>> Fazlul Huq
>> Graduate Research Assistant
>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>> University of Illinois at Urbana-Champaign (UIUC)
>> E-mail: huq2090 at gmail.com
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180727/5b33a58a/attachment.html>
