[petsc-users] Saving output and execution time
Thu Jul 19 19:34:19 CDT 2018
On Thu, Jul 19, 2018 at 1:44 PM Fazlul Huq <huq2090 at gmail.com> wrote:
> Hello all,
> I can run the following code with this command showing output on the
> console: ./poisson_m -ksp_view_solution
What is the question? To put that ASCII output in a file, use
-ksp_view_solution :sol.txt
There is a chapter in the manual on viewing.
    Matt
> The code is:
> static char help[] = "Solves a tridiagonal linear system.\n\n";
> /*T
>    Concepts: KSP^basic parallel example;
>    Processors: n
> T*/
>   Include "petscksp.h" so that we can use KSP solvers.  Note that this file
>   automatically includes:
>      petscsys.h       - base PETSc routines   petscvec.h - vectors
>      petscmat.h - matrices
>      petscis.h     - index sets            petscksp.h - Krylov subspace
> methods
>      petscviewer.h - viewers               petscpc.h  - preconditioners
>   Note:  The corresponding uniprocessor example is ex1.c
> #include <petscksp.h>
> int main(int argc,char **args)
>   Vec            x, b, u;          /* approx solution, RHS, exact solution
>   Mat            A;                /* linear system matrix */
>   KSP            ksp;              /* linear solver context */
>   PC             pc;               /* preconditioner context */
>   PetscReal      norm,tol=1000.*PETSC_MACHINE_EPSILON;  /* norm of
> solution error */
>   PetscErrorCode ierr;
>   PetscInt       i,n = 99,col[3],its,rstart,rend,nlocal;
>   PetscScalar    one = 1.0,hundredth = 0.001,leftbc = 10.001,rightbc =
> 15.001,value[3];
>   ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return ierr;
>   ierr = PetscOptionsGetInt(NULL,NULL,"-n",&n,NULL);CHKERRQ(ierr);
>          Compute the matrix and right-hand-side vector that define
>          the linear system, Ax = b.
>      Create vectors.  Note that we form 1 vector from scratch and
>      then duplicate as needed. For this simple case let PETSc decide how
>      many elements of the vector are stored on each processor. The second
>      argument to VecSetSizes() below causes PETSc to decide.
>   ierr = VecCreate(PETSC_COMM_WORLD,&x);CHKERRQ(ierr);
>   ierr = VecSetSizes(x,PETSC_DECIDE,n);CHKERRQ(ierr);
>   ierr = VecSetFromOptions(x);CHKERRQ(ierr);
>   ierr = VecDuplicate(x,&b);CHKERRQ(ierr);
>   ierr = VecDuplicate(x,&u);CHKERRQ(ierr);
>   /* Identify the starting and ending mesh points on each
>      processor for the interior part of the mesh. We let PETSc decide
>      above. */
>   ierr = VecGetOwnershipRange(x,&rstart,&rend);CHKERRQ(ierr);
>   ierr = VecGetLocalSize(x,&nlocal);CHKERRQ(ierr);
>      Create matrix.  When using MatCreate(), the matrix format can
>      be specified at runtime.
>      Performance tuning note:  For problems of substantial size,
>      preallocation of matrix memory is crucial for attaining good
>      performance. See the matrix chapter of the users manual for details.
>      We pass in nlocal as the "local" size of the matrix to force it
>      to have the same parallel layout as the vector created above.
>   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>   ierr = MatSetSizes(A,nlocal,nlocal,n,n);CHKERRQ(ierr);
>   ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>   ierr = MatSetUp(A);CHKERRQ(ierr);
>      Assemble matrix.
>      The linear system is distributed across the processors by
>      chunks of contiguous rows, which correspond to contiguous
>      sections of the mesh on which the problem is discretized.
>      For matrix assembly, each processor contributes entries for
>      the part that it owns locally.
>   if (!rstart) {
>     rstart = 1;
>     i      = 0; col[0] = 0; col[1] = 1; value[0] = 2.0; value[1] = -1.0;
>     ierr   = MatSetValues(A,1,&i,2,col,value,INSERT_VALUES);CHKERRQ(ierr);
>   if (rend == n) {
>     rend = n-1;
>     i    = n-1; col[0] = n-2; col[1] = n-1; value[0] = -1.0; value[1] =
> 2.0;
>   /* Set entries corresponding to the mesh interior */
>   value[0] = -1.0; value[1] = 2.0; value[2] = -1.0;
>   for (i=rstart; i<rend; i++) {
>     col[0] = i-1; col[1] = i; col[2] = i+1;
>     ierr   = MatSetValues(A,1,&i,3,col,value,INSERT_VALUES);CHKERRQ(ierr);
>   /* Assemble the matrix */
>   ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>   ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>      Set exact solution; then compute right-hand-side vector.
>   ierr = VecSet(u,one);CHKERRQ(ierr);
>   i=0;
>     ierr = VecSetValues(b, 1, &i, &leftbc, INSERT_VALUES);CHKERRQ(ierr);
>   for (i=1; i<n-1; i++){
>     ierr = VecSetValues(b, 1, &i, &hundredth, INSERT_VALUES);CHKERRQ(ierr);
>   i=n-1;
>     ierr = VecSetValues(b, 1, &i, &rightbc, INSERT_VALUES);CHKERRQ(ierr);
>     ierr = VecAssemblyBegin(b);CHKERRQ(ierr);
>     ierr = VecAssemblyEnd(b);CHKERRQ(ierr);
>   // ierr = MatMult(A,u,b);CHKERRQ(ierr);
>                 Create the linear solver and set various options
>      Create linear solver context
>   ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>      Set operators. Here the matrix that defines the linear system
>      also serves as the preconditioning matrix.
>   ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>      Set linear solver defaults for this problem (optional).
>      - By extracting the KSP and PC contexts from the KSP context,
>        we can then directly call any KSP and PC routines to set
>        various options.
>      - The following four statements are optional; all of these
>        parameters could alternatively be specified at runtime via
>        KSPSetFromOptions();
>   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>   ierr = PCSetType(pc,PCJACOBI);CHKERRQ(ierr);
>   ierr =
> KSPSetTolerances(ksp,1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
>     Set runtime options, e.g.,
>         -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
>     These options will override those specified above as long as
>     KSPSetFromOptions() is called _after_ any other customization
>     routines.
>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>                       Solve the linear system
>      Solve linear system
>   ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>      View solver info; we could instead use the option -ksp_view to
>      print this info to the screen at the conclusion of KSPSolve().
>   ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>                       Check solution and clean up
>      Check the error
>   ierr = VecAXPY(x,-1.0,u);CHKERRQ(ierr);
>   ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
>   ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
>   if (norm > tol) {
>     ierr = PetscPrintf(PETSC_COMM_WORLD,"Norm of error %g, Iterations
> %D\n",(double)norm,its);CHKERRQ(ierr);
>      Free work space.  All PETSc objects should be destroyed when they
>      are no longer needed.
>   ierr = VecDestroy(&x);CHKERRQ(ierr); ierr = VecDestroy(&u);CHKERRQ(ierr);
>   ierr = VecDestroy(&b);CHKERRQ(ierr); ierr = MatDestroy(&A);CHKERRQ(ierr);
>   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>      Always call PetscFinalize() before exiting a program.  This routine
>        - finalizes the PETSc libraries as well as MPI
>        - provides summary and diagnostic information if certain runtime
>          options are chosen (e.g., -log_view).
>   ierr = PetscFinalize();
>   return ierr;
> Now I am trying to save this output in a file (say in a .csv file) at
> runtime along with execution time but I can't.
> Any suggestion please!
> Sincerely,
> Huq
> Fazlul Huq
> Graduate Research Assistant
> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> University of Illinois at Urbana-Champaign (UIUC)
> E-mail: huq2090 at gmail.com
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180719/a342bf8f/attachment.html>
