[petsc-users] degub of computating Jacobian for SNES
Hong
hzhang at mcs.anl.gov
Tue Jul 3 12:22:44 CDT 2018
LEI :
> Thank you very much, Hong.
> I just output the local matrix which I inserted into the global matrix A
> just before calling MatSetValues. Every entry of this local matrix is
> correct, without any ‘nan’. There is no other operation on A before
> MatAssemblyBegin(). But the MatView(A) just after MatAssembly shows some
> ‘nan’ included in A. This seems odd.
It can be memory error. Try use 'valgrind'.
Hong
> *From:* Hong [mailto:hzhang at mcs.anl.gov]
> *Sent:* 03 July 2018 17:30
> *To:* WANG, LEI
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] degub of computating Jacobian for SNES
> LEI :
> One strange thing is that the Jacobian stiffness matrix include ‘nan’. I
> output the element stiffness matrix and the element degree of freedom
> before assembly. There is nothing abnormal.
> How do you check the element? Some elements might divide zero.
> But after assembly by
> ierr1 = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr1);
> ierr1 = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr1);
> I got some ‘nan’ in the stiffness matrix A. Any idea on this?
> For sequential run, MatAssemly() does do much. Check every element of your
> matrix.
> With 1 MPI process and LU precondition, the code should work with
> correctly assembled matrix.
> Hong
> Nonlinear solve did not converge due to DIVERGED_FNORM_NAN iterations 0
> SNES Object: 1 MPI processes
> type: newtonls
> maximum iterations=40, maximum function evaluations=40
> tolerances: relative=0.0001, absolute=0.0001, solution=1e-08
> total number of linear solver iterations=0
> total number of function evaluations=1
> norm schedule ALWAYS
> SNESLineSearch Object: 1 MPI processes
> type: basic
> maxstep=1.000000e+08, minlambda=1.000000e-12
> tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
> KSP Object: 1 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=100, initial guess is zero
> tolerances: relative=1e-10, absolute=1e-10, divergence=10000.
> left preconditioning
> using DEFAULT norm type for convergence test
> PC Object: 1 MPI processes
> type: lu
> PC has not been set up so information may be incomplete
> LU: out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> matrix ordering: nd
> linear system matrix = precond matrix:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=78, cols=78
> total: nonzeros=3204, allocated nonzeros=46800
> total number of mallocs used during MatSetValues calls =0
> using I-node routines: found 25 nodes, limit used is 5
> No. of Iterations: 0
> Convergence reason: -4: SNES_DIVERGED_FNORM_NAN
> *Sent:* 03 July 2018 15:31
> *To:* WANG, LEI
> LEI:
> Run your code with option '-snes_converged_reason -ksp_converged_reason
> -ksp_monitor -snes_monitor' to check which solver leads to divergence. Then
> use option '-snes_view' to check what solver is used.
> Hong
> Dear all
> I am using SNES for solving a large nonlinear system for Material Point
> Method. But it always diverged after server steps, I think there are some
> bug in the computation of Jacobian matrix. Do anyone have practical
> approach for identified these bugs in a large matrix? Currently, I saved
> the matrix to a txt file and load it to Matlab for checking. Is there
> function for checking Petsc Mat in Petsc itself?
> Cheers
> Lei
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180703/b5ad8378/attachment.html>
