[petsc-users] Geometric multigrid with a cell-centered discretization
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Jan 9 10:14:46 CST 2018
Ok, so the problem is that for Q0 we do not handle injection correctly (it is not really injection with cell centered it is an average over multiple class) and hence we cannot handle coordinates correctly you need to not attach any coordinates to your DMDA and it should work. See for example src/ksp/ksp/examples/tutorials/ex32.c
Barry
Sorry about this, someone needs to fix the injection for Q0 case.
> On Jan 9, 2018, at 9:12 AM, Buesing, Henrik <hbuesing at eonerc.rwth-aachen.de> wrote:
> Sorry (again), for posting only part of the error message...
> So, here it comes. I will first [1] show the code snippets I am using, then second [2] I will show the PETSc options, and finally [3] the error message I get.
> The grid is 1536 x 1 x 256 in x,y,z-direction. Thus, we see the first level of coarsening in x-direction here.
> Thank you!
> Henrik
> [1]
> CALL DMDACreate3d(PETSC_COMM_WORLD,DM_BOUNDARY_GHOSTED,DM_BOUNDARY_GHOSTED,DM_BOUNDARY_GHOSTED,&
> DMDA_STENCIL_STAR, I0g,J0g,K0g, PETSC_DECIDE, PETSC_DECIDE,PETSC_DECIDE, petsc_two, petsc_one, &
> PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER, petsc_da, petsc_ierr)
> CALL DMSetUp(petsc_da,petsc_ierr)
> CALL DMSetFromOptions(petsc_da, petsc_ierr)
> CALL DMDASetInterpolationType(petsc_da, DMDA_Q0, petsc_ierr)
> CALL SNESSetDM(petsc_snes, petsc_da, petsc_ierr)
> CALL SNESSetFromOptions(petsc_snes,petsc_ierr)
> [2] -snes_monitor -snes_linesearch_monitor -snes_type newtonls -snes_linesearch_type basic -ksp_type fgmres -ksp_max_it 1000 -snes_stol 1e-06 -snes_rtol 1e-06 -snes_atol 1e-6 -ksp_gmres_restart 100 -ksp_monitor -pc_type mg -da_refine_y 1 -ksp_converged_reason -snes_converged_reason -ksp_monitor -ksp_view -pc_mg_levels 2 -options_left
> [3]
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: Ratio between levels: (mx - 1)/(Mx - 1) must be integer: mx 1536 Mx 768
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.2-48-g851ec02 GIT Date: 2017-12-05 09:52:17 -0600
> [0]PETSC ERROR: /rwthfs/rz/cluster/work/hb111949/EoCoE/aixcelerate17/gge_gnu/bench_run/000023/000000_copy_sub_launch/work/shem_fw64gnu_const.x on a gnu_openmpi named linuxbmc0008.rz.RWTH-Aachen.DE by hb111949 Tue Jan 9 16:04:39 2018
> [0]PETSC ERROR: Configure options --download-fblaslapack --with-cc=mpicc -with-fc=mpif90 --with-cxx=mpicxx --download-hypre --download-superlu_dist --download-suitesparse --download-scalapack --download-blacs --download-hdf5 --download-parmetis --download-metis --with-debugging=0 --download-mumps
> [0]PETSC ERROR: #1 DMCreateInjection_DA_3D() line 1195 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/dainterp.c
> [0]PETSC ERROR: #2 DMCreateInjection_DA() line 1283 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/dainterp.c
> [0]PETSC ERROR: #3 DMCreateInjection() line 1082 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/interface/dm.c
> [0]PETSC ERROR: #4 DMCoarsen_DA() line 1219 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/da.c
> [0]PETSC ERROR: #5 DMCoarsen() line 2427 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/interface/dm.c
> [0]PETSC ERROR: #6 PCSetUp_MG() line 618 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #7 PCSetUp() line 924 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #8 KSPSetUp() line 381 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #9 KSPSolve() line 612 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> Dipl.-Math. Henrik Büsing
> Institute for Applied Geophysics and Geothermal Energy
> E.ON Energy Research Center
> RWTH Aachen University
> Mathieustr. 10 | Tel +49 (0)241 80 49907
> 52074 Aachen, Germany | Fax +49 (0)241 80 49889
> http://www.eonerc.rwth-aachen.de/GGE
>> -----Ursprüngliche Nachricht-----
>> Von: Smith, Barry F. [mailto:bsmith at mcs.anl.gov]
>> Gesendet: 09 January 2018 15:10
>> An: Buesing, Henrik <hbuesing at eonerc.rwth-aachen.de>
>> Cc: petsc-users <petsc-users at mcs.anl.gov>
>> Betreff: Re: [petsc-users] Geometric multigrid with a cell-centered
>> discretization
>> With cell centered elements each element is sliced in half in each of
>> the three directions for refinement (or you can refine only in 1 or 2 of
>> the dimensions if you like). This means that the ratio of mx to MX needs
>> to be 2 (or 4).So your numbers are fine.
>>> On Jan 9, 2018, at 7:59 AM, Buesing, Henrik <hbuesing at eonerc.rwth-
>> aachen.de> wrote:
>>> Dear all,
>>> I am using DMDACreate3d to generate my domain and a cell-centered
>>> two-point flux approximation as discretization. I use geometric
>>> Multigrid (-pc_type mg) with DMDASetInterpolationType(petsc_da,
>>> DMDA_Q0, petsc_ierr). With DM_BOUNDARY_GHOSTED as boundary type in
>>> DMDACreate3d, I get
>>> [0]PETSC ERROR: Arguments are incompatible [0]PETSC ERROR: Ratio
>> We need ALL the output from the error (always). It should never be
>> doing this check in your case so something is wrong with the order of
>> your code perhaps.
>> Barry
>>> With DM_BOUNDARY_PERIODIC, I get invalid accesses when I assemble the
>> matrix.
>>> Can I somehow tell him, that I have a cell-centered grid, or do I have
>> to resort to using N+1 in my dimensions?
>>> Thank you!
>>> Henrik
>>> Institute for Applied Geophysics and Geothermal Energy E.ON Energy
>>> Research Center RWTH Aachen University
