[petsc-users] Geometric multigrid with a cell-centered discretization
Buesing, Henrik
hbuesing at eonerc.rwth-aachen.de
Tue Jan 9 09:30:11 CST 2018
Correction to [3]. This actually is the whole stack down to SNESSolve...
[3]
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Arguments are incompatible
[0]PETSC ERROR: Ratio between levels: (mx - 1)/(Mx - 1) must be integer: mx 1536 Mx 768
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.8.2-48-g851ec02 GIT Date: 2017-12-05 09:52:17 -0600
[0]PETSC ERROR: shem_fw64gnu_const.x on a gnu_openmpi named cluster-x.rz.RWTH-Aachen.DE by hb111949 Tue Jan 9 16:26:56 2018
[0]PETSC ERROR: Configure options --download-fblaslapack --with-cc=mpicc -with-fc=mpif90 --with-cxx=mpicxx --download-hypre --download-superlu_dist --download-suitesparse --download-scalapack --download-blacs --download-hdf5 --download-parmetis --download-metis --with-debugging=0 --download-mumps
[0]PETSC ERROR: #1 DMCreateInjection_DA_3D() line 1195 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/dainterp.c
[0]PETSC ERROR: #2 DMCreateInjection_DA() line 1283 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/dainterp.c
[0]PETSC ERROR: #3 DMCreateInjection() line 1082 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #4 DMCoarsen_DA() line 1219 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/da.c
[0]PETSC ERROR: #5 DMCoarsen() line 2427 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #6 PCSetUp_MG() line 618 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: #7 PCSetUp() line 924 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #8 KSPSetUp() line 381 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #9 KSPSolve() line 612 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 224 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #11 SNESSolve() line 4179 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: #12 User provided function() line 0 in unknown file
Dipl.-Math. Henrik Büsing
Institute for Applied Geophysics and Geothermal Energy
E.ON Energy Research Center
RWTH Aachen University
Mathieustr. 10 | Tel +49 (0)241 80 49907
52074 Aachen, Germany | Fax +49 (0)241 80 49889
http://www.eonerc.rwth-aachen.de/GGE
> -----Ursprüngliche Nachricht-----
> Von: petsc-users [mailto:petsc-users-bounces at mcs.anl.gov] Im Auftrag von
> Buesing, Henrik
> Gesendet: 09 January 2018 16:13
> An: 'Smith, Barry F.' <bsmith at mcs.anl.gov>
> Cc: petsc-users <petsc-users at mcs.anl.gov>
> Betreff: Re: [petsc-users] Geometric multigrid with a cell-centered
> discretization
> Sorry (again), for posting only part of the error message...
> So, here it comes. I will first [1] show the code snippets I am using,
> then second [2] I will show the PETSc options, and finally [3] the error
> message I get.
> The grid is 1536 x 1 x 256 in x,y,z-direction. Thus, we see the first
> level of coarsening in x-direction here.
> Thank you!
> Henrik
> [1]
> CALL
> DMDACreate3d(PETSC_COMM_WORLD,DM_BOUNDARY_GHOSTED,DM_BOUNDARY_GHOSTED,DM
> _BOUNDARY_GHOSTED,&
> DMDA_STENCIL_STAR, I0g,J0g,K0g, PETSC_DECIDE,
> PETSC_DECIDE,PETSC_DECIDE, petsc_two, petsc_one, &
> PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER, petsc_da,
> petsc_ierr)
> CALL DMSetUp(petsc_da,petsc_ierr) ...
> CALL DMSetFromOptions(petsc_da, petsc_ierr)
> CALL DMDASetInterpolationType(petsc_da, DMDA_Q0, petsc_ierr)
> CALL SNESSetDM(petsc_snes, petsc_da, petsc_ierr)
> CALL SNESSetFromOptions(petsc_snes,petsc_ierr)
> [2] -snes_monitor -snes_linesearch_monitor -snes_type newtonls -
> snes_linesearch_type basic -ksp_type fgmres -ksp_max_it 1000 -snes_stol
> 1e-06 -snes_rtol 1e-06 -snes_atol 1e-6 -ksp_gmres_restart 100 -
> ksp_monitor -pc_type mg -da_refine_y 1 -ksp_converged_reason -
> snes_converged_reason -ksp_monitor -ksp_view -pc_mg_levels 2 -
> options_left
> [3]
> [0]PETSC ERROR: Arguments are incompatible [0]PETSC ERROR: Ratio between
> levels: (mx - 1)/(Mx - 1) must be integer: mx 1536 Mx 768 [0]PETSC
> trouble shooting.
> Date: 2017-12-05 09:52:17 -0600 [0]PETSC ERROR:
> /rwthfs/rz/cluster/work/hb111949/EoCoE/aixcelerate17/gge_gnu/bench_run/0
> 00023/000000_copy_sub_launch/work/shem_fw64gnu_const.x on a gnu_openmpi
> named linuxbmc0008.rz.RWTH-Aachen.DE by hb111949 Tue Jan 9 16:04:39
> 2018 [0]PETSC ERROR: Configure options --download-fblaslapack --with-
> debugging=0 --download-mumps [0]PETSC ERROR: #1
> c
> .c
> .c
> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message ----
> Institute for Applied Geophysics and Geothermal Energy E.ON Energy
> Research Center RWTH Aachen University
> > Von: Smith, Barry F. [mailto:bsmith at mcs.anl.gov]
> > Gesendet: 09 January 2018 15:10
> > An: Buesing, Henrik <hbuesing at eonerc.rwth-aachen.de>
> > discretization
> > With cell centered elements each element is sliced in half in each
> > of the three directions for refinement (or you can refine only in 1 or
> > 2 of the dimensions if you like). This means that the ratio of mx to
> > MX needs to be 2 (or 4).So your numbers are fine.
> > > On Jan 9, 2018, at 7:59 AM, Buesing, Henrik <hbuesing at eonerc.rwth-
> > aachen.de> wrote:
> > > Dear all,
> > > I am using DMDACreate3d to generate my domain and a cell-centered
> > > two-point flux approximation as discretization. I use geometric
> > > Multigrid (-pc_type mg) with DMDASetInterpolationType(petsc_da,
> > > DMDA_Q0, petsc_ierr). With DM_BOUNDARY_GHOSTED as boundary type in
> > > DMDACreate3d, I get
> > We need ALL the output from the error (always). It should never be
> > doing this check in your case so something is wrong with the order of
> > your code perhaps.
> > Barry
> > > With DM_BOUNDARY_PERIODIC, I get invalid accesses when I assemble
> > > the
> > matrix.
> > > Can I somehow tell him, that I have a cell-centered grid, or do I
> > > have
> > to resort to using N+1 in my dimensions?
> > > Thank you!
> > > Henrik
