[petsc-users] Question on DMPlexCreateSection for Fortran
Matthew Knepley
knepley at gmail.com
Tue Feb 20 11:52:02 CST 2018
On Tue, Feb 20, 2018 at 12:30 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi All,
> I tried to compile the DMPlexCreateSection code but got error information
> as shown below.
> Error: Symbol 'petsc_null_is' at (1) has no IMPLICIT type
> I tried to use PETSC_NULL_OBJECT instead of PETSC_NULL_IS, then the code
> can be compiled but run into Segmentation Violation error in
> DMPlexCreateSection.
>From the webpage
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexCreateSection.html
The F90 version is DMPlexCreateSectionF90. Doing this with F77 arrays would
have been too painful.
Matt
> dmda_flow%da is distributed dm object that works fine.
> The fortran example I follow is http://www.mcs.anl.gov/petsc/
> petsc-dev/src/dm/impls/plex/examples/tutorials/ex1f90.F90.
> What parameters should I use if passing null to bcField, bcComps, bcPoints
> and perm.
> PetscErrorCode <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscErrorCode.html#PetscErrorCode> DMPlexCreateSection <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexCreateSection.html#DMPlexCreateSection>(DM <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DM/DM.html#DM> dm, PetscInt <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> dim, PetscInt <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numFields,const PetscInt <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numComp[],const PetscInt <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numDof[], PetscInt <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numBC,const PetscInt <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> bcField[],
> const IS <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS> bcComps[], const IS <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS> bcPoints[], IS <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS> perm, PetscSection <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/PetscSection.html#PetscSection> *section)
> #include <petsc/finclude/petscis.h>
> #include <petsc/finclude/petscis.h90>
> #include <petsc/finclude/petscdmplex.h>
> #ifdef USG
> numFields = 1
> numComp(1) = 1
> pNumComp => numComp
> do i = 1, numFields*(dmda_flow%dim+1)
> numDof(i) = 0
> end do
> numDof(0*(dmda_flow%dim+1)+1) = dmda_flow%dof
> pNumDof => numDof
> numBC = 0
> call DMPlexCreateSection(dmda_flow%da,dmda_flow%dim, &
> numFields,pNumComp,pNumDof,
> numBC,PETSC_NULL_INTEGER,
> PETSC_NULL_IS,PETSC_NULL_IS,
> & !Error here
> PETSC_NULL_IS,section,ierr)
> CHKERRQ(ierr)
> call PetscSectionSetFieldName(section,0,'flow',ierr)
> CHKERRQ(ierr)
> call DMSetDefaultSection(dmda_flow%da,section,ierr)
> CHKERRQ(ierr)
> call PetscSectionDestroy(section,ierr)
> CHKERRQ(ierr)
> #endif
> Thanks,
> Danyang
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180220/9d9778a4/attachment.html>
