[petsc-users] Question on DMPlexCreateSection for Fortran
Danyang Su
danyang.su at gmail.com
Tue Feb 20 11:30:15 CST 2018
Hi All,
I tried to compile the DMPlexCreateSection code but got error
information as shown below.
Error: Symbol 'petsc_null_is' at (1) has no IMPLICIT type
I tried to use PETSC_NULL_OBJECT instead of PETSC_NULL_IS, then the code
can be compiled but run into Segmentation Violation error in
DMPlexCreateSection.
dmda_flow%da is distributed dm object that works fine.
The fortran example I follow is
http://www.mcs.anl.gov/petsc/petsc-dev/src/dm/impls/plex/examples/tutorials/ex1f90.F90.
What parameters should I use if passing null to bcField, bcComps,
bcPoints and perm.
PetscErrorCode
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscErrorCode.html#PetscErrorCode> DMPlexCreateSection
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexCreateSection.html#DMPlexCreateSection>(DM
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DM/DM.html#DM> dm,PetscInt
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> dim,PetscInt
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numFields,constPetscInt
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numComp[],constPetscInt
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numDof[],PetscInt
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> numBC,constPetscInt
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt> bcField[],
constIS
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS> bcComps[], constIS
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS> bcPoints[],IS
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS> perm,PetscSection
<https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/PetscSection.html#PetscSection> *section)
#include <petsc/finclude/petscis.h>
#include <petsc/finclude/petscis.h90>
#include <petsc/finclude/petscdmplex.h>
#ifdef USG
numFields = 1
numComp(1) = 1
pNumComp => numComp
do i = 1, numFields*(dmda_flow%dim+1)
numDof(i) = 0
end do
numDof(0*(dmda_flow%dim+1)+1) = dmda_flow%dof
pNumDof => numDof
numBC = 0
call DMPlexCreateSection(dmda_flow%da,dmda_flow%dim, &
numFields,pNumComp,pNumDof, &
numBC,PETSC_NULL_INTEGER, &
PETSC_NULL_IS,PETSC_NULL_IS, & !Error here
PETSC_NULL_IS,section,ierr)
CHKERRQ(ierr)
call PetscSectionSetFieldName(section,0,'flow',ierr)
CHKERRQ(ierr)
call DMSetDefaultSection(dmda_flow%da,section,ierr)
CHKERRQ(ierr)
call PetscSectionDestroy(section,ierr)
CHKERRQ(ierr)
#endif
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180220/6763c5b5/attachment.html>
