[petsc-users] Question on DMPlexCreateSection for Fortran
Danyang Su danyang.su at gmail.com
Tue Feb 20 12:07:27 CST 2018
On 18-02-20 09:52 AM, Matthew Knepley wrote:
> On Tue, Feb 20, 2018 at 12:30 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>     Hi All,
>     I tried to compile the DMPlexCreateSection code but got error
>     information as shown below.
>     Error: Symbol 'petsc_null_is' at (1) has no IMPLICIT type
>     I tried to use PETSC_NULL_OBJECT instead of PETSC_NULL_IS, then
>     the code can be compiled but run into Segmentation Violation error
>     in DMPlexCreateSection.
> From the webpage
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexCreateSection.html
> The F90 version is DMPlexCreateSectionF90. Doing this with F77 arrays
> would have been too painful.
Hi Matt,
Sorry, I still cannot compile the code if use DMPlexCreateSectionF90
instead of DMPlexCreateSection. Would you please tell me in more details?
undefined reference to `dmplexcreatesectionf90_'
then I #include <petsc/finclude/petscdmplex.h90>, but this throws more
error during compilation.
     Included at
/home/dsu/Soft/PETSc/petsc-3.7.5/include/petsc/finclude/petscdmplex.h90:6:
     Included at ../../solver/solver_ddmethod.F90:62:
           PETSCSECTION_HIDE section
           1
Error: Unclassifiable statement at (1)
/home/dsu/Soft/PETSc/petsc-3.7.5/include/petsc/finclude/ftn-custom/petscdmplex.h90:167.10:
     Included at
           1
/home/dsu/Soft/PETSc/petsc-3.7.5/include/petsc/finclude/ftn-custom/petscdmplex.h90:179.10:
     Included at
>   Thanks,
>      Matt
>     dmda_flow%da is distributed dm object that works fine.
>     The fortran example I follow is
>     http://www.mcs.anl.gov/petsc/petsc-dev/src/dm/impls/plex/examples/tutorials/ex1f90.F90
>     <http://www.mcs.anl.gov/petsc/petsc-dev/src/dm/impls/plex/examples/tutorials/ex1f90.F90>.
>     What parameters should I use if passing null to bcField, bcComps,
>     bcPoints and perm.
>     PetscErrorCode
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscErrorCode.html#PetscErrorCode>  DMPlexCreateSection
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexCreateSection.html#DMPlexCreateSection>(DM
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DM/DM.html#DM>  dm,PetscInt
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt>  dim,PetscInt
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt>  numFields,constPetscInt
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt>  numComp[],constPetscInt
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt>  numDof[],PetscInt
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt>  numBC,constPetscInt
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Vec/PetscInt.html#PetscInt>  bcField[],
>     constIS
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS>  bcComps[], constIS
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS>  bcPoints[],IS
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/IS.html#IS>  perm,PetscSection
>     <https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/IS/PetscSection.html#PetscSection>  *section)
>     #include <petsc/finclude/petscis.h>
>     #include <petsc/finclude/petscis.h90>
>     #include <petsc/finclude/petscdmplex.h>
>     #ifdef USG
>             numFields = 1
>             numComp(1) = 1
>             pNumComp => numComp
>             do i = 1, numFields*(dmda_flow%dim+1)
>               numDof(i) = 0
>             end do
>             numDof(0*(dmda_flow%dim+1)+1) = dmda_flow%dof
>             pNumDof => numDof
>             numBC = 0
>             call DMPlexCreateSection(dmda_flow%da,dmda_flow%dim, &
>     numFields,pNumComp,pNumDof, &
>     numBC,PETSC_NULL_INTEGER, &
>     PETSC_NULL_IS,PETSC_NULL_IS, &             !Error here
>     PETSC_NULL_IS,section,ierr)
>             CHKERRQ(ierr)
>             call PetscSectionSetFieldName(section,0,'flow',ierr)
>             CHKERRQ(ierr)
>             call DMSetDefaultSection(dmda_flow%da,section,ierr)
>             CHKERRQ(ierr)
>             call PetscSectionDestroy(section,ierr)
>             CHKERRQ(ierr)
>     #endif
>     Thanks,
>     Danyang
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180220/52cff154/attachment.html>
