[petsc-users] Error when use DMPlexGetVertexNumbering
Danyang Su
danyang.su at gmail.com
Fri Feb 16 12:56:10 CST 2018
On 18-02-16 10:50 AM, Matthew Knepley wrote:
> On Fri, Feb 16, 2018 at 1:45 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
> Hi Matt,
> I try to get the global vertex index and cell index from local
> mesh and run into problem. What I need is local to global index
> (the original index used in DMPlexCreateFromCellList is best, as
> user know exactly where the node/cell is) for vertices and cells,
> which will be used to assign material properties and some
> parameters to the specified cell/vertex.
> I would recommend doing this before you distribute the mesh. Just set
> these properties using a DMLabel and it will be automatically distributed.
I will try this. Thanks.
> I can use coordinates to select vertex/cell which has already
> included, but still want to keep this feature. This is pretty
> straightforward when using structured grid. For the unstructured
> grid, I just got compiling error saying "You need a ISO C
> conforming compiler to use the glibc headers"
> For any compilation problem, you have to send the configure.log and
> make.log. However, it appears that you are not using the same compiler
> that you configured with.
Sorry for confusion. There are linux-gnu-dbg (debug version) and
linux-gnu-opt (optimized version) configuration, the one I used to
compile is debug version and the attached one is optimized version. I
will try you recommendation first.
Danyang
> Matt
> Would you please let me know if I need to change the configuration
> of PETSc or is there any alternative ways to avoid using
> DMPlexGetVertexNumbering and DMPlexGetCellNumbering but get local
> to global index?
> The error information during compilation is shown below, followed
> by PETSc configuration.
> -o ../../solver/solver_ddmethod.o ../../solver/solver_ddmethod.F90
> In file included from /usr/include/features.h:375:0,
> from /usr/include/stdio.h:28,
> from
> /home/dsu/Soft/PETSc/petsc-3.7.5/include/petscsys.h:161,
> from
> /home/dsu/Soft/PETSc/petsc-3.7.5/include/petscis.h:8,
> from
> /home/dsu/Soft/PETSc/petsc-3.7.5/include/petscvec.h:10,
> from
> /home/dsu/Soft/PETSc/petsc-3.7.5/include/petscmat.h:7,
> from
> /home/dsu/Soft/PETSc/petsc-3.7.5/include/petsc/private/dmpleximpl.h:5,
> from ../../solver/solver_ddmethod.F90:4122:
> /usr/include/x86_64-linux-gnu/sys/cdefs.h:30:3: error: #error "You
> need a ISO C conforming compiler to us\
> # error "You need a ISO C conforming compiler to use the glibc
> headers"
> In file included from /usr/include/features.h:399:0,
> from
> from
> from
> from
> from
> /usr/include/x86_64-linux-gnu/gnu/stubs.h:7:0: fatal error:
> gnu/stubs-32.h: No such file or directory
> # include <gnu/stubs-32.h>
> compilation terminated.
> make: [../../solver/solver_ddmethod.o] Error 1 (ignored)
> PETSc configuration
> --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mumps
> --download-scalapack --download-parmetis --download-metis
> --download-ptscotch --download-fblaslapack --download-mpich
> --download-hypre --download-superlu_dist --download-hdf5=yes
> --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
> Thanks and regards,
> Danyang
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180216/4380b892/attachment-0001.html>
