[petsc-users] interpolate HDF5 mesh
Thu Dec 20 09:40:57 CST 2018
On Thu, Dec 20, 2018 at 9:33 AM Yann JOBIC via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear Petsc Users,
> When i'm using DMPlexCreateBoxMesh, my code works fine. However, when i
> load the "exact" same mesh from an HDF5 file, it's not working anymore
> (Nonlinear solve did not converge due to DIVERGED_FNORM_NAN iterations 0).
> The mesh view when i use DMPlexCreateBoxMesh looks like (i labeled my
> boudary nodes):
> /* generated with DMPlexCreateBoxMesh */
> DM Object: Mesh 1 MPI processes
>    type: plex
> Mesh in 3 dimensions:
>    0-cells: 216
>    1-cells: 540
>    2-cells: 450
>    3-cells: 125
> Labels:
>    Faces: 6 strata with value/size (2 (121), 4 (121), 3 (121), 6 (121),
> 5 (121), 7 (121))
>    boundary: 1 strata with value/size (1 (602))
>    depth: 4 strata with value/size (0 (216), 1 (540), 2 (450), 3 (125))
>    Face Sets: 6 strata with value/size (6 (25), 5 (25), 3 (25), 4 (25),
> 1 (25), 2 (25))
>    marker: 1 strata with value/size (1 (450))
> And when i use DMPlexCreateFromFile, or DMLoad, i have :
> /* generated with H5 file */
> fin label DM
>    type: plex
>    0-cells: 216
>    1-cells: 540
>    2-cells: 450
>    3-cells: 125
> Labels:
>    Faces: 6 strata with value/size (2 (121), 4 (121), 6 (121), 7 (121),
> 5 (121), 3 (121))
> It looks like my DM is not interpolated. Am i wrong ?
Its interpolated (you have 4 kinds of k-cells, instead of 2). However, you
are missing your
Face Sets marker, which probably means boundary conditions are not getting
applied.
    Matt
> It's strange, because when i use DMPlexCreateFromFile, i put PETSC_TRUE
> for interpolation.
> Even after loading the mesh, i used DMPlexInterpolate, which return a
> new DM (not null).
> Do you know what's happening here ?
> Maybe my DIVERGED_FNORM_NAN comes from another part of the code ?
> (however only the mesh is changing)
> Thanks,
> Yann
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/733969e8/attachment.html>
