[petsc-users] interpolate HDF5 mesh
Yann JOBIC yann.jobic at univ-amu.fr
Thu Dec 20 08:33:04 CST 2018
Dear Petsc Users,
When i'm using DMPlexCreateBoxMesh, my code works fine. However, when i
load the "exact" same mesh from an HDF5 file, it's not working anymore
(Nonlinear solve did not converge due to DIVERGED_FNORM_NAN iterations 0).
The mesh view when i use DMPlexCreateBoxMesh looks like (i labeled my
boudary nodes):
/* generated with DMPlexCreateBoxMesh */
DM Object: Mesh 1 MPI processes
   type: plex
Mesh in 3 dimensions:
   0-cells: 216
   1-cells: 540
   2-cells: 450
   3-cells: 125
Labels:
   Faces: 6 strata with value/size (2 (121), 4 (121), 3 (121), 6 (121),
5 (121), 7 (121))
   boundary: 1 strata with value/size (1 (602))
   depth: 4 strata with value/size (0 (216), 1 (540), 2 (450), 3 (125))
   Face Sets: 6 strata with value/size (6 (25), 5 (25), 3 (25), 4 (25),
1 (25), 2 (25))
   marker: 1 strata with value/size (1 (450))
And when i use DMPlexCreateFromFile, or DMLoad, i have :
/* generated with H5 file */
fin label DM
   type: plex
   0-cells: 216
   1-cells: 540
   2-cells: 450
   3-cells: 125
Labels:
   Faces: 6 strata with value/size (2 (121), 4 (121), 6 (121), 7 (121),
5 (121), 3 (121))
It looks like my DM is not interpolated. Am i wrong ?
It's strange, because when i use DMPlexCreateFromFile, i put PETSC_TRUE
for interpolation.
Even after loading the mesh, i used DMPlexInterpolate, which return a
new DM (not null).
Do you know what's happening here ?
Maybe my DIVERGED_FNORM_NAN comes from another part of the code ?
(however only the mesh is changing)
Yann
