[petsc-users] Periodic domains in DMPlex / petsc4py
Artur Palha Da Silva Clérigo - LR A.PalhaDaSilvaClerigo at tudelft.nl
Wed Dec 12 08:12:46 CST 2018
Dear Matt,
Thank you for your quick reply. As for your question: "why would there be a difference? They should be numbered in the same way.”
I see the degrees of freedom living on the periodic domain as the ones living at boundaries between interior elements. This is what I expect for non-periodic domain for nodal scalar field:
Non-periodic:
1                3                5
X-------------X-------------X
0                2                 4
Periodic (vertical boundaries, topologically, the domain is a cylinder)
1                3                1
0                2                 0
This is not the expected behaviour?
Once again thank you for your help.
-artur palha
On 12 Dec 2018, at 15:04, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Dec 12, 2018 at 9:01 AM Artur Palha Da Silva Clérigo - LR via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear All,
I having been trying to add periodic domain functionality to my code. I am able to generate a periodic mesh with gmsh and load it using dmplex. The problem is that I am unable to have a numbering of the degrees of freedom that reflects the periodicity (they are numbered as if there was no periodicity).
Why would there be a difference? They should be numbered in the same way.
I read this thread: https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2018-October/036539.html
There it is mentioned that DMLocalizeCoordinates is required after loading the mesh.
Yes, this makes cell-wise coordinates, which have a jump at the periodic boundary.
My questions are the following:
1. Is it correct that I need to run DMLocalizeCoordinates on my DM?
Yes.
2. I am currently using petsc4py but I am unable to find DMLocalizeCoordinates. Is this functionality missing or is there an alternative to it?\
Its possible no wrapper has been written for this yet. Lisandro, is it missing? (I am at a meeting, or I would check).
    Matt
Thank you for your time.
Kind regards,
-artur palha
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181212/3e644b8a/attachment.html>
