[petsc-users] Periodic domains in DMPlex / petsc4py
Wed Dec 12 08:14:23 CST 2018
On Wed, Dec 12, 2018 at 9:12 AM Artur Palha Da Silva Clérigo - LR <
A.PalhaDaSilvaClerigo at tudelft.nl> wrote:
> Dear Matt,
> Thank you for your quick reply. As for your question: "why would there be
> a difference? They should be numbered in the same way.”
> I see the degrees of freedom living on the periodic domain as the ones
> living at boundaries between interior elements. This is what I expect for
> non-periodic domain for nodal scalar field:
> Non-periodic:
> 1                3                5
> X-------------X-------------X
> 0                2                 4
> Periodic (vertical boundaries, topologically, the domain is a cylinder)
> 1                3                1
> 0                2                 0
> This is not the expected behaviour?
What I mean is that each vertex in the periodic domain gets 1 dof. Same
procedure as non-periodic.
We do not duplicate vertices or anything like that.
    Matt
> Once again thank you for your help.
> -artur palha
> On 12 Dec 2018, at 15:04, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 12, 2018 at 9:01 AM Artur Palha Da Silva Clérigo - LR via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Dear All,
>> I having been trying to add periodic domain functionality to my code. I
>> am able to generate a periodic mesh with gmsh and load it using dmplex. The
>> problem is that I am unable to have a numbering of the degrees of freedom
>> that reflects the periodicity (they are numbered as if there was no
>> periodicity).
> Why would there be a difference? They should be numbered in the same way.
>> I read this thread:
>> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2018-October/036539.html
>> There it is mentioned that DMLocalizeCoordinates is required after
>> loading the mesh.
> Yes, this makes cell-wise coordinates, which have a jump at the periodic
> boundary.
>> My questions are the following:
>> 1. Is it correct that I need to run DMLocalizeCoordinates on my DM?
> Yes.
>> 2. I am currently using petsc4py but I am unable to find
>> DMLocalizeCoordinates. Is this functionality missing or is there an
>> alternative to it?\
> Its possible no wrapper has been written for this yet. Lisandro, is it
> missing? (I am at a meeting, or I would check).
>   Thanks,
>     Matt
>> Thank you for your time.
>> Kind regards,
>> -artur palha
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181212/41fc0dbc/attachment-0001.html>
