[petsc-users] Using C routines in PETSc code
Fazlul Huq huq2090 at gmail.com
Fri Aug 31 12:45:16 CDT 2018
Thanks Barry.
I will try to fix the error.
Sincerely,
Huq
On Fri, Aug 31, 2018 at 12:43 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Aug 31, 2018, at 12:12 PM, Fazlul Huq <huq2090 at gmail.com> wrote:
> > Hello PETSc Developers,
> > Can I use c programming routine in PETSc code and make and run it (since
> PETSc is written in c)?
>    Of course.
> > Last day I tried to do that but I got error message while making the
> file.
>    Must be due to syntax errors in the code. You should read the error
> messages to determine how to fix the code.
>    Barry
> > Thanks.
> > Huq
Fazlul Huq
Graduate Research Assistant
Department of Nuclear, Plasma & Radiological Engineering (NPRE)
University of Illinois at Urbana-Champaign (UIUC)
E-mail: huq2090 at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180831/76976d2f/attachment.html>
