[petsc-users] advice about preconditioning
Oleksandr Koshkarov olk548 at mail.usask.ca
Fri Aug 31 20:31:07 CDT 2018
Dear All,
I hope you can help me with some advice on how to proceed with
constructing a preconditioner for my petsc based simulation.
I have a large nonlinear system dU/dt = L(U) + N(U,U), with U being a
state vector, L linear operator and N nonlinear one. It comes from
discretizing hyperbolic PDE with finite volume. L is advection and N is
some nonlinear source which does not have spatial derivatives. My U is
PETSc 3D DMDA with dof = from 1e2 up to 2e3. I solve it with petsc TS
object and with Crank Nicolson method. In order to save space, I do use
finite difference Jacobian, which petsc generates itself. Something like
this
     MatCreateSNESMF(snes,&J);
     SNESSetJacobian(snes,J,J,MatMFFDComputeJacobian,0);
Now I want to precondition my linear solves inside Newton iterations
with linearized Jacobian, i.e, with something like this
  P_n = 1 - dt/2 * ( L + N(U^n,*) + N(*,U^n) )        // where U^n is
state from previous time step
I first checked, that this works on small test problem. I used matrix
free preconditioner (PCSHELL) inside which I inverted P_n with KSP.
Where  P_n is matrix free matrix (shell matrix). It reduces the number
of KSP dramatically, which is not a surprise - it was just a sanity check.
Now I am trying to understand how to proceed... and I am not sure what
to do. In my head I have two options:
1) Try to construct matrix-free preconditioner. For example, I can keep
inverting P_n every iteration inside the preconditioner with KSP (or
some other method) but now precondition it with something else, to make
it cheap. So I would have double preconditioner...  I am not sure if
this is a right direction, and it is even possible to make effective
matrix-free preconditioner in my case
2) Construct P_n as real matrix, and feed it to petsc
(SNESSetJacobian(snes,J,P,MatMFFDComputeJacobian,0);) and ask to perform
something like LU for preconditioning. It is very expensive (as I have
huge system) and I would need to probably contract P_n only every 100
steps or something like this... It is probably the right direction I
have to go, but it seems it will take too much memory.
Is there other better way? :)
Small question. If I will need to construct P_n element by element, does
petsc provide some help with DMDA indexing. I usually access state U
with x-index (xi), y-index (yi), z-index(zi), and dof like
u[zi][yi][xi][dof]. Can I use similar indexing to access matrix elements?
Thank you and best regards,
Oleksandr.
